DoctorDaveLGT Posted October 31, 2019 Share Posted October 31, 2019 Wanted to share a solution I found for all the wagon owners (usdm/oem bumper) out there with the Q300 exhaust and tucked tips. Found some perfect sized slip-on exhaust tips that look better than the Q300 tips as well...at least imo. No longer have to worry about melting my bumper more then it already is. Burger Motorsports E-Chasis N51/N52 Slip-On Exhaust Tips I have them pushed on as far as they will go and they are very snug while technically not even being 'fully seated'. No clamps, no screw/bolt to hold them on and have never had to adjust them. Link to comment Share on other sites More sharing options...
ashwinearl Posted November 1, 2019 Share Posted November 1, 2019 Thank you very much for this link. Link to comment Share on other sites More sharing options...
DaveWaters Posted November 1, 2019 Share Posted November 1, 2019 That looks great! Thank you!! Link to comment Share on other sites More sharing options...
awfulwaffle Posted November 1, 2019 Share Posted November 1, 2019 So much better than the typical pokey wagon length tips on other exhausts, too. Link to comment Share on other sites More sharing options...
amm203 Posted November 4, 2019 Share Posted November 4, 2019 Wow. That looks infinitely better than the straight-cut tips. May have to cut back the tips on my sedan and use these! Thank you Link to comment Share on other sites More sharing options...
seanyb505 Posted September 8, 2020 Share Posted September 8, 2020 Posted this in the wdydty4glt thread, but posting here too. The burger tips in the OP are no longer available, but Dave directed me to these alternatives: https://www.amazon.com/ESPEEDER-Pair-Muffler-Exhaust-Pipes/dp/B0757K9KZM. Pics: Installation only required rubber mallet as pictured. Total for all 4 tips was $55, so not a bad deal even if the rust to bits in a year. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2020 Share Posted September 8, 2020 Looks pretty good. Did they do away with the drone ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
seanyb505 Posted September 8, 2020 Share Posted September 8, 2020 Zero change in sound I think. If anything, it's made it more articulate. But I like the "drone." I rarely have other people in the car, and radio is only maybe 40% of the time? Windows down/sunroof open and audible exhaust is a great combo for me. I get to bounce back and forth between dat boxer rumble yo and inner monologue. Link to comment Share on other sites More sharing options...
DoctorDaveLGT Posted September 8, 2020 Author Share Posted September 8, 2020 What DPs are both of you running? I've got very minimal if any drone and running the GS catted/limited. The shop and I both thought the exhaust was slightly quieter with the tips on but that could easily be a placebo effect. There's random days when I think the car is running louder or quieter than usual. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2020 Share Posted September 8, 2020 Invidia catted on both cars. At least I think I had already changed the wagon to a catted DP before the Q300. The Spec has always had a catted DP. I do get a little popping from the Q300 during shifts at times. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DoctorDaveLGT Posted September 8, 2020 Author Share Posted September 8, 2020 Interesting. I get some pops when shifting as well but only when I'm flooring it and shifting close to red line but even then it rarely happens. I will get light burbles/pops on decel in 1st & 2nd the majority of the time though. Really love it when I'm in navigating a parking lot next to a wall or building and hear it even more. Never ran catless. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2020 Share Posted September 8, 2020 Yes, at high rpm's also. I found that if I lift off the gas, a touch, then shift, it sounds great. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
seanyb505 Posted September 8, 2020 Share Posted September 8, 2020 What DPs are both of you running? I've got very minimal if any drone and running the GS catted/limited. The shop and I both thought the exhaust was slightly quieter with the tips on but that could easily be a placebo effect. There's random days when I think the car is running louder or quieter than usual. Exact same DP here. Idk, maybe I don't have any drone. I've never been in a car where someone pointed out, this is drone. I've been in obnoxiously loud and reverberating cars, I don't think my wagon is either. I do know the exhaust is always audible. I know some people prefer to not hear it if they're just cruising under low load. I also get the pops on command and during certain shift scenarios. I wonder if that's more to do with an unfinished rich tune. Otherwise known as the burble snap/crackle/pop tune. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2020 Share Posted September 8, 2020 I'm not so sure the popping is Tune related in my case, the tune is by one of the best. He did mention that there could be a leak at one of the joints letting in cold air. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Wagonation Posted September 22, 2020 Share Posted September 22, 2020 Those look sweet! Link to comment Share on other sites More sharing options...
