05MNLGT Posted October 3, 2022 Author Share Posted October 3, 2022 spent most of my time working on the lamp harness. another friend is helping develop a plug -n- play harness that will work with the washer lamps. they are different then the post lamps without the washers. will get the post drl to work with the ebrake too. Link to comment Share on other sites More sharing options...
05MNLGT Posted October 3, 2022 Author Share Posted October 3, 2022 back under it goes. will be back at it in a couple weeks. cheers. Link to comment Share on other sites More sharing options...
05MNLGT Posted October 3, 2022 Author Share Posted October 3, 2022 (edited) 10 hours ago, CEVENN said: Fantastic job on this car, thanks for doing it! Any chance to know side mirror color code? sorry no paint code for the mirror caps. It will go to the subaru sti designers grave. i bought the caps long ago from someone that worked at the plant. they were brand new and still in the labeled plastic. they are a pearl silver, not the metallic silver on the LGTs. you could use the subaru silver if you wanted, its a subtle difference between the two silvers Edited October 3, 2022 by 05MNLGT 2 Link to comment Share on other sites More sharing options...
Kalien32 Posted January 11, 2023 Share Posted January 11, 2023 (edited) On 10/13/2021 at 12:14 PM, 05MNLGT said: infosecdad you know i did the jdm/udm rear foglight control? now that's some fun at a stoplight or for that tailgater. Hey. I have the EDM stalk for the rear fog light control. Care to elaborate on what pin you tapped into from the module? I have the relay sketch from Aden. But it doesnt tell you what pin the rear fog control comes from. Im banking on you having had taken some photos. Edited January 11, 2023 by Kalien32 3 Link to comment Share on other sites More sharing options...
CEVENN Posted January 22, 2023 Share Posted January 22, 2023 On 10/4/2022 at 12:53 AM, 05MNLGT said: sorry no paint code for the mirror caps. It will go to the subaru sti designers grave. i bought the caps long ago from someone that worked at the plant. they were brand new and still in the labeled plastic. they are a pearl silver, not the metallic silver on the LGTs. you could use the subaru silver if you wanted, its a subtle difference between the two silvers Hi. I found the originals S402 covers on Amayama. Waiting for delivery. It's not for a S402 or a fantastic replica like yours, just for my 2007 Spec B 5EAT. Thanks for the help. Link to comment Share on other sites More sharing options...
05MNLGT Posted February 7, 2023 Author Share Posted February 7, 2023 On 1/22/2023 at 10:45 AM, CEVENN said: Hi. I found the originals S402 covers on Amayama. Waiting for delivery. It's not for a S402 or a fantastic replica like yours, just for my 2007 Spec B 5EAT. Thanks for the help. be careful. lots of sellers use the silver from the silver LGT and pass them off as s402. the s402 are a pearl silver. very slight difference to the untrained eye. only way to be sure is to have both to compare, or one that's factory wrapped with subaru sti s402 code. hope you got the right ones. Link to comment Share on other sites More sharing options...
05MNLGT Posted February 7, 2023 Author Share Posted February 7, 2023 On 1/11/2023 at 12:51 PM, Kalien32 said: Hey. I have the EDM stalk for the rear fog light control. Care to elaborate on what pin you tapped into from the module? I have the relay sketch from Aden. But it doesnt tell you what pin the rear fog control comes from. Im banking on you having had taken some photos. sorry. did the wiring 5 years ago and can't remember squat. can check once i get done with the wagon this spring. Link to comment Share on other sites More sharing options...
Kalien32 Posted February 7, 2023 Share Posted February 7, 2023 5 minutes ago, 05MNLGT said: sorry. did the wiring 5 years ago and can't remember squat. can check once i get done with the wagon this spring. Lol. I thought that would be the case. But if you do remember to check, the info would be extremely helpful. Link to comment Share on other sites More sharing options...
05MNLGT Posted February 7, 2023 Author Share Posted February 7, 2023 worked on the jdm roof spoiler. matching the usdm (stupid-ugly) roof line. the biggest disappointment was not being able to ship over the jdm roof. mapping area for work, then sanding. Link to comment Share on other sites More sharing options...
05MNLGT Posted February 7, 2023 Author Share Posted February 7, 2023 final prep work done. Link to comment Share on other sites More sharing options...
05MNLGT Posted February 7, 2023 Author Share Posted February 7, 2023 lordy can i make a mess. look like a 6'4 blue smurf when I leave the shop. 1 Link to comment Share on other sites More sharing options...
05MNLGT Posted February 7, 2023 Author Share Posted February 7, 2023 using a plastic spreader, I cut the shape to taper the roof line to the spoiler. 1 Link to comment Share on other sites More sharing options...
05MNLGT Posted February 7, 2023 Author Share Posted February 7, 2023 then filler time and miller time. only have so long to work with this crap. acts like caramel. Fyi. the 3m gun was $350 3 yrs ago. and yes, it's looks like the guns from any star wars. 1 Link to comment Share on other sites More sharing options...
05MNLGT Posted February 7, 2023 Author Share Posted February 7, 2023 first pass with the filler. needs to dry. will sand and do a second layer. it is a slow and detailed process to get this right. rush it and you will do it twice. 1 Link to comment Share on other sites More sharing options...
05MNLGT Posted February 7, 2023 Author Share Posted February 7, 2023 got the doors primed. smoothed out the rear body panels. end of feb it should be primed and ready for paint (fingers crossed) Link to comment Share on other sites More sharing options...
05MNLGT Posted February 7, 2023 Author Share Posted February 7, 2023 15 minutes ago, Kalien32 said: Lol. I thought that would be the case. But if you do remember to check, the info would be extremely helpful. ping me in 2 months. jungling 3 builds right now. wagon is the biggest pain right now. having issue with boost, which i'll have to deal with after paint. Link to comment Share on other sites More sharing options...
