Ironworker613 Posted October 15, 2017 Share Posted October 15, 2017 Like the title says but more. The interior needs a serious cleaning with rips in the leather and both front bilsteins are shot, possibly rears too. It has 160k on it. How Much $? Input is needed from you guys! Thanks in advance Link to comment Share on other sites More sharing options...
solidxsnake Posted October 15, 2017 Share Posted October 15, 2017 At most $4k, if even that much. The spec.B, especially if the interior is trashed, really isn't worth much more than a regular LGT, and honestly an LGT in that sort of condition is probably only worth $1.5-2k at most (assuming it's not driving). This is coming from someone who spent $11k on an '07 spec.B about 2.5 years ago Link to comment Share on other sites More sharing options...
Ironworker613 Posted October 15, 2017 Author Share Posted October 15, 2017 Thanks for the reply! The trade in value in fair condition is 2700 and fair condition is only with SOME mechanical problems. This has 2 big ones. He told me I could have it for 3k. I want to give him what its worth, but Nothing more because I know how much work its going to be. Link to comment Share on other sites More sharing options...
rougeben83 Posted October 15, 2017 Share Posted October 15, 2017 I'll be even more pragmatic and say 2k max, basically the only thing it has going for it is the drivetrain - and that's already high mileage and god knows how well it's been maintained (the rest of the car's condition is a good indicator). Link to comment Share on other sites More sharing options...
Max Capacity Posted October 15, 2017 Share Posted October 15, 2017 Assuming you can DIY, it's still going to cost north of 6-7000 dollars. What dose a nice 07 Spec B go for ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MilesA Posted October 15, 2017 Share Posted October 15, 2017 I was going to comment about DIY. That will make a huge difference in cost. Be realistic, this is a used car in "fair" condition and it's being sold because the owner doesn't want to deal with the maintenance and repair costs. I'd almost expect the suspension and turbo to be tired and ready for replacement at 160K. Clutch would be pretty well worn as well. I'd estimate parts cost along this line New Bilstein HDs $600 New Clutch, etc. $400 Used take-off turbo $500 Total $1500 The interior and exterior repair cost Reupholster center section of leather seats at local shop $600 Paint repairs (no idea what it needs) $??? What about other maintenance like timing belt service, seals, belts, hoses, boots, fluid replacement? I'd add that up. Now, subtract all that from the fair price for a car in great condition. That figure would be the most you should pay. Link to comment Share on other sites More sharing options...
05leggtlimited Posted October 15, 2017 Share Posted October 15, 2017 for the turbo replacement factor in all gaskets, hardware and Subaru coolant, it ended up costing more than I anticipated both times I've had the turbo out Link to comment Share on other sites More sharing options...
JmP6889928 Posted October 15, 2017 Share Posted October 15, 2017 IF it ONLY needs a turbo and not a shortblock..... Link to comment Share on other sites More sharing options...
Ironworker613 Posted October 16, 2017 Author Share Posted October 16, 2017 Well the turbo sounds about like a supercharger when it spools. And i'm positive its not a boost leak. Its sitting at my shop right now and I havent had the chance to pull the inlet or downpipe to have a look. I hope its not going to need a motor if we do strike a deal. And even if, is 3k out of the question? Link to comment Share on other sites More sharing options...
JmP6889928 Posted October 16, 2017 Share Posted October 16, 2017 Based on your description, it sounds like it's been rode hard and put away wet. I would look for another car. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 16, 2017 Share Posted October 16, 2017 The 6mt driveline is a nice set up. Depends on how long you plan to keep it, to get back what you put into it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rougeben83 Posted October 16, 2017 Share Posted October 16, 2017 2k and that's basically because OF the 6mt and its driveline...the rest you can throw away/replace. You have to factor in your time to the overall cost of owning this potential rat's nest. Link to comment Share on other sites More sharing options...
lockmedic Posted October 16, 2017 Share Posted October 16, 2017 Clean, one-owner, up to date on maintenance 07 spec B sold for $3600 USD with minty interior and 100k miles on the clock in Vancouver recently. Had a CEL indicating misfire(s), non-technical owner was advised by dealer (same that serviced it for most of its life) it may have needed a valve grind. That's still upwards of a $1000 job even if you DIY it. It sold within a day. I felt like it was a great price and would have bought it in a heartbeat if it were local. A trashed one that needs all you mentioned and possibly more? $2-3k tops. . . mostly for the 6MT but even then you're buying one with 160k. . . and repairs/rebuilds to it are not cheap. Paint isn't cheap if it's any good. Plan on about $400/panel for decent work. Bilsteins are more like a grand to replace. Link to comment Share on other sites More sharing options...
MilesA Posted October 16, 2017 Share Posted October 16, 2017 ...Bilsteins are more like a grand to replace. I priced the Bilstein HDs at Tire Rack not long ago: Rear shock = Bilstein Part #: 24-118323 $99 Front strut left = Bilstein Part 35-118305 $208 Front struct right = Bilstein Part #: 35-118312 $210 Total = $616 If you needed new strut mounts, or had to pay someone to install them, of course that would add to the cost. Link to comment Share on other sites More sharing options...
bergs Posted October 17, 2017 Share Posted October 17, 2017 Well the turbo sounds about like a supercharger when it spools. And i'm positive its not a boost leak. Its sitting at my shop right now and I havent had the chance to pull the inlet or downpipe to have a look. I hope its not going to need a motor if we do strike a deal. And even if, is 3k out of the question? For the same money I could put you into my 2005 that doesn't need anything 'cept an interior detailing. Link to comment Share on other sites More sharing options...
Ironworker613 Posted October 17, 2017 Author Share Posted October 17, 2017 Well I bought it for 1900 and Im putting a new fuel tank in his truck. So about 2300 total. Now I need a turbo and clutch asap! Link to comment Share on other sites More sharing options...
Lgt005 Posted October 17, 2017 Share Posted October 17, 2017 Good luck with the rebuild! I have a 6 speed clutch and flywheel if you need one. Link to comment Share on other sites More sharing options...
MilesA Posted October 17, 2017 Share Posted October 17, 2017 A new adventure begins! 160K is not all that much, based on the experience of people here you could take it to 250K or 300K, but you are getting into heavy maintenance territory. For some reason, I'm reminded of those kind folks that give a neglected or abused animal a good home Link to comment Share on other sites More sharing options...
Ironworker613 Posted October 18, 2017 Author Share Posted October 18, 2017 Thank you all for the input! Link to comment Share on other sites More sharing options...
08SpecB_DE Posted October 31, 2017 Share Posted October 31, 2017 Where in DE are you? I'm usually around kirkwood highway or in the Pike Creek area. Maybe we've crossed paths? Link to comment Share on other sites More sharing options...
Ironworker613 Posted October 31, 2017 Author Share Posted October 31, 2017 I live right off of faulkland Road near prices corner and my shop is off of maryland ave. I just got it back together last night, cant wait to drive it today! Link to comment Share on other sites More sharing options...
Dishwasher Posted October 31, 2017 Share Posted October 31, 2017 I priced the Bilstein HDs at Tire Rack not long ago: Rear shock = Bilstein Part #: 24-118323 $99 Front strut left = Bilstein Part 35-118305 $208 Front struct right = Bilstein Part #: 35-118312 $210 Total = $616 If you needed new strut mounts, or had to pay someone to install them, of course that would add to the cost. Tophats and alignment will put you pretty close to $1k Link to comment Share on other sites More sharing options...
