valleylegacy Posted January 26, 2017 Share Posted January 26, 2017 (edited) I recently bought a 2005 Legacy BP5 Limited 5MT with 150K on it. The car came from back east without an engine. Perfect shell to my ultimate build project. Creating a LHD 06-08 JDM BP5 Legacy Tuned By STI Wagon. Well as close as I can to it. Stay tuned for pics and progress. I bought a 07 JDM Legacy EJ20Y front clip with the 6MT attached. It had only 27K miles on it. Adan and his team #AQMOTORSPORTS in Torrance, CA will be conducting the build for me. 06-08 JDM Legacy Spec B Transmission Code - TY856WBDAA http://legacygt.com/forums/<a href=https://flic.kr/p/WgEkAh target=_blank> Edited July 9, 2017 by valleylegacy Link to comment Share on other sites More sharing options...
magnusonsubie Posted January 26, 2017 Share Posted January 26, 2017 YES! I can't wait to see what you do with this. Knowing the connections you have to JDM parts galore this will be amazing! 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Kalien32 Posted January 26, 2017 Share Posted January 26, 2017 In for this... I'm excited!! Link to comment Share on other sites More sharing options...
valleylegacy Posted January 27, 2017 Author Share Posted January 27, 2017 (edited) Thank you friends. Here are the first set of pictures I took of the front clip. Edited July 9, 2017 by valleylegacy Link to comment Share on other sites More sharing options...
valleylegacy Posted January 27, 2017 Author Share Posted January 27, 2017 I was very surprised that it was only used for 27K miles and the condition of the motor + 6MT was superb. The entire front end was in really great shape and even the headlight harness is there so I can plug and play the JDM REV D-F HID headlights + leveling function! The challenge will be to get the wiring harness and accessories to be installed the opposite way since it is going into a LHD car. Some of the few things I've already picked up are: 1. 2015 STI 13:1 quick steering rack + coupler joint 2. Cusco LHD steering rack brace 3. Whiteline bushings of course 4. F/R Brembo calipers + brackets + DBA 4000 slotted rotors + stainless steel lines 5. KNS brake shoes 6. Complete EDM LHD center console set up 7. JDM REV D-F Wagon tailights more to come! Link to comment Share on other sites More sharing options...
patrikman Posted January 29, 2017 Share Posted January 29, 2017 Sweetness Link to comment Share on other sites More sharing options...
valleylegacy Posted January 30, 2017 Author Share Posted January 30, 2017 (edited) I sourced the entire LHD EDM Center console system so that I could have the JDM/EDM 06-08 style interior. It was a long haul to get everything but it's so much better than the USDM one. Parts from 4 different countries. Can't wait to get this installed. Also sourced the JDM REV D-F Dual Console box + Tuned By STI Arm Rest (on the way from Japan) which is black alcantara + white stitching instead of just plain rubber. 06-08 EDM Center Console Assembly JDM Dual console Box Part Number - J2017AG000 There are just too many part numbers to list so here are 3 links that give you a complete guide of all part numbers for the parts needed http://opposedforces.com/parts/legacy/en_b13/type_81/body_equipment_interior/instrument_panel/illustration_5/ http://opposedforces.com/parts/legacy/en_b13/type_81/body_equipment_interior/console_box/illustration_5/ http://opposedforces.com/parts/legacy/en_b13/type_81/body_equipment_interior/console_box/illustration_7/ Ended up replacing the cup holder mats Part Number - 92177AG150 And sourced a new cup holder assembly from the S402 since it has the gloss gunmetal color trim Part Number - 66150AG210JC Edited July 9, 2017 by valleylegacy Link to comment Share on other sites More sharing options...
Zac88 Posted January 30, 2017 Share Posted January 30, 2017 Awesome build. Definitely keeping my eye on it. Link to comment Share on other sites More sharing options...
WRX USA Posted January 30, 2017 Share Posted January 30, 2017 How much would it cost to source another LHD EDM center console? Link to comment Share on other sites More sharing options...
magnusonsubie Posted January 30, 2017 Share Posted January 30, 2017 Did you get the glove box and other under dash pieces with it as well or just the center console? 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
valleylegacy Posted January 30, 2017 Author Share Posted January 30, 2017 How much would it cost to source another LHD EDM center console? man...this thing...after all the wait time and back orders on parts, I nearly paid over $600 for source everything needed for a bolt on install. I can find them again but it's just costly if you wanna go that route. It was a combination of Bahrain, Germany, Sweden, Israel to get these parts. Not to mention over 2-3 months of searching. But I do have access to get them Link to comment Share on other sites More sharing options...
valleylegacy Posted January 30, 2017 Author Share Posted January 30, 2017 Did you get the glove box and other under dash pieces with it as well or just the center console? Everything you see in the pictures is what I was told and learned that you need to install it. I will let you know if there is anything further. These parts are actually for the LHD EDM 07 3.0R Spec B. So I was told it is a direct fitment to our USDM LHD cars. I wasn't aware if we needed to get the glove box as well. Ill find out once I get around to installing it. Link to comment Share on other sites More sharing options...
magnusonsubie Posted January 30, 2017 Share Posted January 30, 2017 I was just thinking the way that the trim is. It will just end rather than being carried through with the rest for the pieces. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
tysparks81 Posted January 30, 2017 Share Posted January 30, 2017 (edited) But he should be able to use a glove box from an 08-09 which carries over the trim on the glovebox. But no way to know for sure until it gets put into place. Subbed for greatness that is about to happen. Edited January 30, 2017 by tysparks81 #LGTSTi is still cheaper and nicer then an equal year wrxsti Follow my 2007 Spec B. Build here Link to comment Share on other sites More sharing options...
madrig Posted January 31, 2017 Share Posted January 31, 2017 (edited) man...this thing...after all the wait time and back orders on parts, I nearly paid over $600 for source everything needed for a bolt on install. I can find them again but it's just costly if you wanna go that route. It was a combination of Bahrain, Germany, Sweden, Israel to get these parts. Not to mention over 2-3 months of searching. But I do have access to get them ye the scrapyard from Israël was helpful for me also !! sub for a great built ! Edited January 31, 2017 by madrig incomplete Link to comment Share on other sites More sharing options...
madrig Posted January 31, 2017 Share Posted January 31, 2017 Everything you see in the pictures is what I was told and learned that you need to install it. I will let you know if there is anything further. These parts are actually for the LHD EDM 07 3.0R Spec B. So I was told it is a direct fitment to our USDM LHD cars. I wasn't aware if we needed to get the glove box as well. Ill find out once I get around to installing it. it will fit with usdm glove box and under steering trim . of course from a 2008. everything is bolt on , only the brackets of the center console are différent,nothing serious . Link to comment Share on other sites More sharing options...
madrig Posted January 31, 2017 Share Posted January 31, 2017 i just realise you can use the bracket from your front clip , even is rh drive should be the same parts , also the shifter boot ! Link to comment Share on other sites More sharing options...
valleylegacy Posted January 31, 2017 Author Share Posted January 31, 2017 I was just thinking the way that the trim is. It will just end rather than being carried through with the rest for the pieces. Good point. I will show pictures once I have it installed and see if I need to source more parts. Link to comment Share on other sites More sharing options...
valleylegacy Posted January 31, 2017 Author Share Posted January 31, 2017 Good to hear, thank you. I guess I have to now source a 2008-2009 glove box and...under steering trim? I would guess the under steering trim has to be from LHD? Link to comment Share on other sites More sharing options...
madrig Posted January 31, 2017 Share Posted January 31, 2017 (edited) yes from a lhd i bought the panel new , it was like 45 dollar . use one was more expensive with shipping ! what is expensive are the trim, what subaru call ornament" . forget ! also need for best result cover assembly column , cause the opening in the lower panel is different due to the column that extend for 2008 and tilt for 2006 . Edited January 31, 2017 by madrig incomplete Link to comment Share on other sites More sharing options...
valleylegacy Posted January 31, 2017 Author Share Posted January 31, 2017 (edited) Of course I couldn't help but get the 06-08 JDM BP5 Legacy Wagon Tail Lights. Part Numbers - 84913AG142, 84913AG152 And JDM Engine Bay covers for the battery and power steering area. Part Number Power Steering Cover - 46112AG000 Part Number Battery Cover - 46112AG012 This piece is my favorite. The JDM Transmission Undercover found on the 3.0R Spec B. Part Number - 56410AG130 Edited July 12, 2017 by valleylegacy Link to comment Share on other sites More sharing options...
WRX USA Posted January 31, 2017 Share Posted January 31, 2017 Isn't there a bracket for the transmission under cover? Link to comment Share on other sites More sharing options...
valleylegacy Posted February 1, 2017 Author Share Posted February 1, 2017 (edited) Yes the bracket used is the same design as the JDM 08 STI so I had to get that from Japan to use it. Part Number - 20107FG000 Edited July 9, 2017 by valleylegacy Link to comment Share on other sites More sharing options...
WRX USA Posted February 1, 2017 Share Posted February 1, 2017 Yes the bracket used is the same design as the JDM 08 STI so i had to get that from Japan to use it. Part Number - 20107FG000 Thanks! Do you have the part number for the transmission under cover? Link to comment Share on other sites More sharing options...
valleylegacy Posted February 1, 2017 Author Share Posted February 1, 2017 Thanks! Do you have the part number for the transmission under cover? EDM/JDM Transmission Undercover - 56410AG130 Link to comment Share on other sites More sharing options...
