stocklgt Posted February 11, 2018 Share Posted February 11, 2018 Yeah that is correct. And not at least with as low as I went. I have 235s and I had to do a lot of fender rolling and cutting to get it all to fit correctly. Either way they look great! Im jelly Link to comment Share on other sites More sharing options...
Shipman Posted February 11, 2018 Share Posted February 11, 2018 Either way they look great! Im jelly Thanks man. I appreciate that. It's not done yet but I'm happy with it as of now. It should only get better. Link to comment Share on other sites More sharing options...
rchayes21 Posted February 14, 2018 Share Posted February 14, 2018 Are these Enkei Kojins? Yes, Enkei Kojin: 18x9.5 Other possible wheel options are on the horizon. Bagged1 (1 of 1) by Chas Hayes, on Flickr Link to comment Share on other sites More sharing options...
Slow Posted February 22, 2018 Share Posted February 22, 2018 Hey guys, it's been a while. New engine and paint in the next couple months, what y'all think about midnight purple? Link to comment Share on other sites More sharing options...
rchayes21 Posted February 23, 2018 Share Posted February 23, 2018 Hey! Looks great the way it is IMO, obsidian black ftw. But purple would be pretty cool. Hope everything goes well with your tune up. Any big changes with that ? Link to comment Share on other sites More sharing options...
Slow Posted February 23, 2018 Share Posted February 23, 2018 (edited) Right now it’s a VF52 at 17.5psi with the Downpipe cut in half but the car is slow because it’s running so rich and the headgaskets are wonky. For 156k miles and seeing redline and high rpm downshifts everyday, my current engine has been solid. My friend even money shifted into 2nd and got it up to 8k. Some people have bad experiences but mines been great so far for my usage scenario lol. When the car is rebuilt I’m going to put a pump and ID1000s on it and shoot for 330whp With an EWG and TGV deletes. I got solid motor mounts so the thing is going to be violent between the dump and vibrations - my transmission mount is group N so it shouldn’t inside the cabin .I also have a meaty clutch so eventually I’ll get an HTZ Blue or something along the lines of 400whp. I’ll have stock connecting rods but forged pistons, bearings, upgraded oil pump and killer b pickup + baffle so it should be fairy solid. Probably replacing most of the bushings with the white line catalog and replacing my rear coil overs with 80k miles while I’m at it. And I don’t like looking like every car on the road, Black is great but it’s a pain in the ass to keep clean and hard to stand out amongst all the other black cars. Sometimes I want to keep it black but it needs a lot of body work and I might as well repaint it while I’m at it. Maybe I’ll change my mind to Java Black before i get it painted. Shipping it to the body shop while the engine is pulled and I’m getting the heads machined. Edited February 23, 2018 by Slow Link to comment Share on other sites More sharing options...
blxcksheep Posted February 24, 2018 Share Posted February 24, 2018 Yes, Enkei Kojin: 18x9.5 Other possible wheel options are on the horizon. Bagged1 (1 of 1) by Chas Hayes, on Flickr What offset are you running? Link to comment Share on other sites More sharing options...
blxcksheep Posted February 24, 2018 Share Posted February 24, 2018 Since this is the Low Legacy thread, I thought I'd add this wide body kit here for anyone who's been looking and didn't know existed Monster Service https://monsterservice.pro/shop/subaru-legacy/bodykit-subaru-legacy-2003-2009/ Mods please delete if not in appropriate place. Link to comment Share on other sites More sharing options...
s2baru Posted February 25, 2018 Share Posted February 25, 2018 Ya we know. It's just us with taste have a reason to not really care Link to comment Share on other sites More sharing options...
boxkita Posted February 25, 2018 Share Posted February 25, 2018 Was looking thru my picture stash and found a pic from the Enkei RPF1 SBC 18x9.5 test fitting. Has Continental 275/30/18 slicks mounted. Still looking for a solution to make this work. The S402 wagon had tubbed rear wheel wells. With a different trailing arm (more curve), this tire/wheel combination would fit. Or add fender flares. It's hard to see in the pic, the rear tire sticks out 2 inches from the fender and rubs on the trailing arm. The front tire had enough clearance on the inside even tho it stuck out a bit. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
madrig Posted February 25, 2018 Share Posted February 25, 2018 Was looking thru my picture stash and found a pic from the Enkei RPF1 SBC 18x9.5 test fitting. Has Continental 275/30/18 slicks mounted. Still looking for a solution to make this work. The S402 wagon had tubbed rear wheel wells. With a different trailing arm (more curve), this tire/wheel combination would fit. Or add fender flares. It's hard to see in the pic, the rear tire sticks out 2 inches from the fender and rubs on the trailing arm. The front tire had enough clearance on the inside even tho it stuck out a bit. i m curious , how do you know s402 have tubbed body wheel ? did subaru really get in trouble to do such modification only for a small run production . you only way to make it fit is to cut fenders and extend ! two inch with zero camber in the rear ? Link to comment Share on other sites More sharing options...
JohnnyWas Posted February 26, 2018 Share Posted February 26, 2018 Ya we know. It's just us with taste have a reason to not really care Honestly. Why must the same kit for every car make every car look exactly the same right now? If your friends jumped off a bridge, would you jump too? Or maybe more appropriately: if youre friends smoked one flavor vape, would you only smoke that flavor too bro? SMDH http://i65.tinypic.com/2vj7l28.jpg Pic of mine before I add my Pandem Kit and air suspension. Link to comment Share on other sites More sharing options...
blxcksheep Posted February 27, 2018 Share Posted February 27, 2018 Honestly. Why must the same kit for every car make every car look exactly the same right now? If your friends jumped off a bridge, would you jump too? Or maybe more appropriately: if youre friends smoked one flavor vape, would you only smoke that flavor too bro? SMDH http://i65.tinypic.com/2vj7l28.jpg Pic of mine before I add my Pandem Kit and air suspension. Who knows why they all have to look the same. I personally don’t like the look of rivets all over my car, but at the same time I don’t hate on those that do... prefer wider bodies that look natural. There's a gray BP I seen that’s a perfect example, I can’t seem to find it tho... Clean wagon btw Link to comment Share on other sites More sharing options...
akarras5 Posted February 27, 2018 Share Posted February 27, 2018 sweet cars! Link to comment Share on other sites More sharing options...
Shipman Posted March 6, 2018 Share Posted March 6, 2018 DSC_1977 by Michael Shipman Photography, on Flickr Link to comment Share on other sites More sharing options...
famaya26 Posted March 6, 2018 Share Posted March 6, 2018 DSC_1977 by Michael Shipman Photography, on Flickr Would you be ok with me using that picture as the cover page for a FB group? Link to comment Share on other sites More sharing options...
madrig Posted March 7, 2018 Share Posted March 7, 2018 that a great pic! why i m not in you fb group !! Link to comment Share on other sites More sharing options...
Shipman Posted March 7, 2018 Share Posted March 7, 2018 Would you be ok with me using that picture as the cover page for a FB group? Yeah no worries broham. that a great pic! Thank you sir. Link to comment Share on other sites More sharing options...
famaya26 Posted March 9, 2018 Share Posted March 9, 2018 If anyone wants to join. https://m.facebook.com/groups/1736641283052974 Thanks Shipman. Link to comment Share on other sites More sharing options...
DementedGT Posted March 14, 2018 Share Posted March 14, 2018 (edited) Edited April 12, 2018 by DementedGT Link to comment Share on other sites More sharing options...
mateodelay Posted March 15, 2018 Share Posted March 15, 2018 This picture is sweet. DSC_1977 by Michael Shipman Photography, on Flickr Link to comment Share on other sites More sharing options...
Shipman Posted March 15, 2018 Share Posted March 15, 2018 This picture is sweet. Thanks kid. Link to comment Share on other sites More sharing options...
Shipman Posted March 16, 2018 Share Posted March 16, 2018 DSC_1975 by Michael Shipman Photography, on Flickr Link to comment Share on other sites More sharing options...
stocklgt Posted March 16, 2018 Share Posted March 16, 2018 im gonna have some issues with my 255 35s...ugh. trying to find your exact setup except in the SBC. So far all I could find is the RPFjuans Link to comment Share on other sites More sharing options...
