magnusonsubie Posted November 14, 2016 Share Posted November 14, 2016 That sounds like you have a huge boost leak/vacuum leak. What youre describing is how my car sounds and behaves when I've blown off one of the silicon hoses on my GS TMIC 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Xxchakalatexx Posted November 14, 2016 Author Share Posted November 14, 2016 I only have two connect points, unless i managed to poke a hole in the IC. I'll post a vid in a bit Link to comment Share on other sites More sharing options...
Xxchakalatexx Posted November 17, 2016 Author Share Posted November 17, 2016 Still haven't uploaded that video yet. But now i have a flashing check engine light and the obd2 scanner won't connect to the car, turns on, but doesn't read. Obviously have some misfiring going on. Also got out smelling like gas lol. Where should i start? Link to comment Share on other sites More sharing options...
Xxchakalatexx Posted November 29, 2016 Author Share Posted November 29, 2016 https://youtu.be/bnHE3VfNUqk Here's a link to my idling. It dies when i give it gas sometimes and sometikes it doesn't. I have a misfire code for cylinder 1 and 3 Link to comment Share on other sites More sharing options...
Xxchakalatexx Posted December 1, 2016 Author Share Posted December 1, 2016 On the plus side i forgot to hook up the knock sensor and the plugs for the passenger side coil packs were backwards. After getting everything right, i went for a ride and soon developed just the p0301 code. Already swtiched coil packs between cylinder 1 and 3. And the spark plug looked fine when i pulled it out of cylinder 1. Not quite sure where to go next other than possible timing. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 1, 2016 Share Posted December 1, 2016 Reconnect the injector wire on #1 ??? Might work...? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Xxchakalatexx Posted December 2, 2016 Author Share Posted December 2, 2016 All is well. I cracked the spark plug on cylinder 1 when putting it back on in the dark. No codes, or overheating. Link to comment Share on other sites More sharing options...
Xxchakalatexx Posted December 2, 2016 Author Share Posted December 2, 2016 Got a p2096 but not too worried about it, i need a tune for the short block and all the searching i've done people just clear the code and go on their way. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 3, 2016 Share Posted December 3, 2016 When was the front O2 sensor last replaced ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
