islandborn Posted February 24, 2016 Share Posted February 24, 2016 Damn it, all this V3 talk makes me want to trade in my V2... And you don't because????!!!!! Come on wrxwhit!!!!! DO IT!!!! (Enabler hat is on and backwards for this!!!) Link to comment Share on other sites More sharing options...
FLlegacy Posted February 24, 2016 Share Posted February 24, 2016 Unconscious enabling! We have reached a new level of enablement! Link to comment Share on other sites More sharing options...
GTEASER Posted February 24, 2016 Author Share Posted February 24, 2016 Breathe in the vape...you know you want to. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
wrxwhit Posted February 24, 2016 Share Posted February 24, 2016 Well.... because.... I just cleared out the classifieds for heck sake. I got parts sitting all over the place and no time to install them. So NOOOOO, I cannot be enabled, no no no!!! Link to comment Share on other sites More sharing options...
FLlegacy Posted February 24, 2016 Share Posted February 24, 2016 I think I saw an ap v3 in the MP! Link to comment Share on other sites More sharing options...
amidroc Posted February 24, 2016 Share Posted February 24, 2016 Check out pro clips. http://www.proclipusa.com/dashboard-mounts/vehicle/subaru/legacy/2010-2014/proclip-console-mount-834426-13018.cmsv Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
Sarang Posted February 24, 2016 Share Posted February 24, 2016 Check out pro clips. http://www.proclipusa.com/dashboard-mounts/vehicle/subaru/legacy/2010-2014/proclip-console-mount-834426-13018.cmsv Sent from my SM-G900V using Tapatalk Do you have one of those? I'm a little unclear what else I would need to get to get it to work with my Garmin or AP or whatever Link to comment Share on other sites More sharing options...
DeltaSniper Posted February 24, 2016 Share Posted February 24, 2016 http://i1054.photobucket.com/albums/s493/BoxerPower555/IMG_20160224_000803_zpssvwugg8l.jpg http://i1054.photobucket.com/albums/s493/BoxerPower555/IMG_20160224_000756_zpsgyzzv8lh.jpg Mounted on the carbon fiber trim, using Go Pro 3M VHB Tape and the original holder.... I have tried lots and lots and lots of different double sided tape variants and so far this is the most successful one. It's been on there for almost 8 months now lol. Link to comment Share on other sites More sharing options...
BBPeik Posted February 24, 2016 Share Posted February 24, 2016 It helps a lot too if you rough up the back of the included mount before applying the tape. Makes it stick a lot better. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
DeltaSniper Posted February 24, 2016 Share Posted February 24, 2016 TBH, the separation doesnt happen on the mount itself, it usually separates at the trim since its a low surface energy substrate. Funny enough, 3M LSE VHB Tape didnt even work too well for me... Link to comment Share on other sites More sharing options...
Ellesedil Posted February 24, 2016 Share Posted February 24, 2016 Check out pro clips. http://www.proclipusa.com/dashboard-mounts/vehicle/subaru/legacy/2010-2014/proclip-console-mount-834426-13018.cmsv Sent from my SM-G900V using Tapatalk I like this. How difficult would it be to run the cable so that it came out from under the center console on the passenger side? Link to comment Share on other sites More sharing options...
cww516 Posted February 24, 2016 Share Posted February 24, 2016 Not at all. I have mine coming out the driver's side at the moment so I can plop the AP in the cubby in front of the shifter, you can run the cable across the top of the kick panel and duck inside the center console when you get to it. Pull the lid off the console (peel back the rubber in the cubby and pull up inside the slot that opens up, remove the shift knob, disconnect the seat heater switches), route the wire around the shifter box, and push it out the bottom of the side of the console wherever you see fit. Link to comment Share on other sites More sharing options...
jkenefake Posted February 25, 2016 Share Posted February 25, 2016 I used this for my phone on my previous car and liked it a lot. Very solid and a clean look. I need to get this for my Legacy to mount my phone on again. https://www.panavise.com/pdf_indash/75134-310.pdf https://www.panavise.com/index.html# As far as my AP, I just use the windshield suction in the bottom left corner. It tucks in that corner nicely and the cable it routed easily down to the OBDII port. It stays out of my direct line of sight, but I can keep and eye on it easily. Link to comment Share on other sites More sharing options...
Shadow_419 Posted February 25, 2016 Share Posted February 25, 2016 V2 but still I figured I'd post my solution for now. May route the cable through one of the unused areas on the mirror control panel. Link to comment Share on other sites More sharing options...
blklgt05 Posted February 25, 2016 Share Posted February 25, 2016 Here's a pic of mine.... Won't that hit your right leg? mod journal Link to comment Share on other sites More sharing options...
cww516 Posted February 26, 2016 Share Posted February 26, 2016 Finally got around to installing the new mount clip thing. Hard work, moving it from the cupholder to the vent, but I got it done. Added the corner cable tuck, thanks to jkenefake for the inspiration there. Not really a good solution for folks with a vent gauge pod or other gauges in that vicinity (so probably worthless for you, GTEASER...), but unless/until I go that route, it works for me. Link to comment Share on other sites More sharing options...
islandborn Posted February 26, 2016 Share Posted February 26, 2016 Won't that hit your right leg? Nope. Sits close but no interference. Link to comment Share on other sites More sharing options...
solgt Posted February 27, 2016 Share Posted February 27, 2016 I mounted mine over next to the dash cubby. I do not need it in my direct line of site and I just keep it angled toward me. I just used the included mount with good 3m double stick and it works great. http://i1378.photobucket.com/albums/ah113/BBPeik/20160223_164231_zps0qvljrit.jpg Same as mine Link to comment Share on other sites More sharing options...
islandborn Posted February 27, 2016 Share Posted February 27, 2016 Interesting!!!!! http://inner-cool.com/products/obd-2-cable Might have to get it.... Link to comment Share on other sites More sharing options...
acumenhokie Posted February 27, 2016 Share Posted February 27, 2016 Interesting!!!!! http://inner-cool.com/products/obd-2-cable Might have to get it.... Let me know how it does. I need this for my Forester. The AP in the LGT is hard wired so I'm good there. Link to comment Share on other sites More sharing options...
blklgt05 Posted February 29, 2016 Share Posted February 29, 2016 Use proclip, I'll post what I used later. mod journal Link to comment Share on other sites More sharing options...
Fasemelta Posted March 1, 2016 Share Posted March 1, 2016 (edited) The problem most of us face using the AP is the hassle to store it properly when parked. While I drive a 4th gen, the 5th gen interiors are somewhat similar from what I'm seeing in photos. I use the typical vent holder with the ball joint. I feed the cable through the center console and out by the passengers feet. The area to the left of the glove box has the perfect amount of width to fit the AP cable without kinking it. I loosely screwed a plastic cable holder into the underside of the glove box. It is not visible at all and allows for a seamless transition to/from the glove box when parking. While in use the cable is outside the "groove" and hanging from footwell to the mount. For storage, the AP and cable are entirely contained in the glovebox. Two shots under the glove box show one opened and one closed to show that it does not bend or pinch the cord at all. Maybe your design is similar enough to accomplish the same??? Edited March 1, 2016 by Fasemelta Link to comment Share on other sites More sharing options...
s2baru Posted April 2, 2016 Share Posted April 2, 2016 PopSockets | Get a Grip On Your Phone http://www.popsockets.com/ (Share from CM Browser) Been seeing these come in on customers phones lately. Figured it'd be an excellent way to mount other things. 10$ for the device 10$ for the adapter. Link to comment Share on other sites More sharing options...
GTEASER Posted April 29, 2016 Author Share Posted April 29, 2016 This is what I ended up going with. I absolutely love the placement. Installed a Scosche (MAGMD) MagicMount Original for my Cobb AP V3 http://www.scosche.com/magic-mount-cell-phone-holder-tablet-mount Seems to hold it really well with a fairly strong magnet. Still have to route the cord, but at least it covers up that damn stupid useless Fuel Economy gauge. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
foxrider28 Posted April 29, 2016 Share Posted April 29, 2016 http://www.walmart.com/ip/magicMOUNT-Dash-Mount/37551986 I use this to mount my phone when driving. It's stuck to the square in between the seat heater switches and the mount does not come lose actually it's probably gonna take an act of God if not replacing the plastic "tray" to remove if I ever do, but we'll worth the $14. They have a ton of different styles even ones for your vents. Also once you put the steel plate on your device and let it set for 24-48 hours it's pretty much there forever, whatever 3M adhesive they are using is insane. However it is magnetic so I don't know if that would interfere with the AP any but it doesn't affect my S5 at all. Reviving since you finally got an AP mount GTeaser, which just happens to be the exact one I suggested [emoji6]. I've had mine for a year now and it's still going strong. You should have no problems with it and you can always use it for other stuff too since it comes with extra backing plates. I will say it's one of the best vehicle accessories I've ever owned. If I ever get an AP I'm considering the "cigarette lighter" mount they make with the USB power port. Link to comment Share on other sites More sharing options...
