rporter Posted September 30, 2005 Share Posted September 30, 2005 Powdercoat Ron Link to comment Share on other sites More sharing options...
nKoan Posted September 30, 2005 Share Posted September 30, 2005 If you want to try and "do it yourself" subydude carries touch up paint for all the rota colors. Link to comment Share on other sites More sharing options...
Mach V Dan Posted September 30, 2005 Share Posted September 30, 2005 Rota D2's in 18x8 5x100 will be coming around mid-November. We have several sets pre-ordered. They'll be +48 and should fit over Legacy brakes just fine. Formula Mesh are also 18x8, but I don't see a huge problem with running them (with a 225/40R18) on an older BD/BG or BE/BH car. If I get around to it, I'll pull a wheel off my BP and try it on my BG wagon. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
Rommel Posted September 30, 2005 Share Posted September 30, 2005 Jedi - refinishing them would probably cost you as much as buying a piece Link to comment Share on other sites More sharing options...
Drift Monkey Posted September 30, 2005 Share Posted September 30, 2005 Rota D2's in 18x8 5x100 will be coming around mid-November. We have several sets pre-ordered. They'll be +48 and should fit over Legacy brakes just fine. Formula Mesh are also 18x8, but I don't see a huge problem with running them (with a 225/40R18) on an older BD/BG or BE/BH car. If I get around to it, I'll pull a wheel off my BP and try it on my BG wagon. --Dan Mach V FastWRX.com Might have to pickup another set of wheels... Link to comment Share on other sites More sharing options...
Gire Posted September 30, 2005 Share Posted September 30, 2005 Rota D2's in 18x8 5x100 will be coming around mid-November. We have several sets pre-ordered. They'll be +48 and should fit over Legacy brakes just fine. Formula Mesh are also 18x8, but I don't see a huge problem with running them (with a 225/40R18) on an older BD/BG or BE/BH car. If I get around to it, I'll pull a wheel off my BP and try it on my BG wagon. --Dan Mach V FastWRX.com Dan- that is great news! You made my day. I see a Christmas present to myself... Glad to hear Rota is bringing this great set out in 18". If they got around to doing the G-Force in 18", it might be a tough choice indeed! Link to comment Share on other sites More sharing options...
Legasee Posted September 30, 2005 Share Posted September 30, 2005 Rota D2's in 18x8 5x100 will be coming around mid-November. We have several sets pre-ordered. They'll be +48 and should fit over Legacy brakes just fine. --Dan Mach V FastWRX.com oh...you'd better not be lying!!! ...I'll be looking forward to those! In Taiwan now... Link to comment Share on other sites More sharing options...
PGT Posted September 30, 2005 Share Posted September 30, 2005 Why would it rub with people in the back? Also, what does the width have to do with it? The wheel is +48....there shouldn't be any fitmet issues besides not clearing the brakes... I need to roll my rear fenders because 18x8 ET48 with a 245/35/18 absolutely, positively, 100% chance will rub when the back end is loaded down. I loaded up the area behind the seats with top soil, grass seed and manure.....I had to pull the weatherstripping off and go real slow to make it home. Maybe 300lbs back there. I should have layed the seats down and moved the load between the axles, but now I know it's an issue. Link to comment Share on other sites More sharing options...
Gire Posted September 30, 2005 Share Posted September 30, 2005 Jeez, next Jedi will tell us all to get Outbacks or something! "No clearance issues over here, guys!" -Jedi Link to comment Share on other sites More sharing options...
froggert Posted September 30, 2005 Share Posted September 30, 2005 i've had my wagon loaded down with no rubbing at all. i think it depends on the tire used. not every 245/35-18 is the same width. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 30, 2005 Share Posted September 30, 2005 Hey, no sarcasm in a post with the word Outback in it. These are serious cars I like the powdercoating idea, but wouldn't they have to be sanded down and all with chips, etc fixed first? nKoan, thanks for that suggestion- it might be the best solution for my needs Link to comment Share on other sites More sharing options...
PGT Posted October 1, 2005 Share Posted October 1, 2005 i've had my wagon loaded down with no rubbing at all. i think it depends on the tire used. not every 245/35-18 is the same width. I also have Spec B suspension....sits a little lower in the rear to start (but stiffer than stock). Toyo T1R's are 9.6" wide while my F1's are 9.7". Link to comment Share on other sites More sharing options...
ralphyralph5 Posted October 1, 2005 Share Posted October 1, 2005 hey jedi, try these guys, i saw their work at a local car show, looked pretty darn good. they charge around 75 bucks a wheel and it's a 4-6 day turn around www.kspowdercoating.com they are in poughkeepsie Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted October 1, 2005 Share Posted October 1, 2005 hey jedi, try these guys, i saw their work at a local car show, looked pretty darn good. they charge around 75 bucks a wheel and it's a 4-6 day turn around www.kspowdercoating.com they are in poughkeepsie Thanks man- I'll check 'em out. BTW, you gonna make the next meet? We need a new thread for the October one. Link to comment Share on other sites More sharing options...
ralphyralph5 Posted October 1, 2005 Share Posted October 1, 2005 def ,,,,,,when is it......lets make it happen i'll be away the next weekend(oct 8-10) but i'll be available oct 16th and the following weekends. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted October 2, 2005 Share Posted October 2, 2005 I'm up for the 16th on- let's make a thread Link to comment Share on other sites More sharing options...
leeberbs Posted October 2, 2005 Share Posted October 2, 2005 my black 02 wagon with bronze rota actions Link to comment Share on other sites More sharing options...
wingedmoon Posted October 3, 2005 Share Posted October 3, 2005 Nice! leeberbs Link to comment Share on other sites More sharing options...
PhilT Posted October 3, 2005 Share Posted October 3, 2005 i guess wagons rule G-Force in Bronze 17x8 ET48 http://img.photobucket.com/albums/v291/urabus/d415/gf_8.jpg Where did you take that pic Drewster ? Looks like one of my old ships in the background, Mitsui OSK Lines. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
ralphyralph5 Posted October 3, 2005 Share Posted October 3, 2005 yeah lee, very nice!!!!!!!!!!! damn that tint is dark(i see what you mean) advertisement plug*** if anyone in the tri-state area needs their car tinted.......def go see lee in jersey. He did my car today....WOW SHE LOOKS SEXY....he did a superb job on the car and he is a very nice person. it's nice to have nice people work on your car!!!!! 2 THUMBS UP FOR LEE Link to comment Share on other sites More sharing options...
drewster Posted October 3, 2005 Share Posted October 3, 2005 Where did you take that pic Drewster ? Looks like one of my old ships in the background, Mitsui OSK Lines. port of Seattle, same location as the ship in this link: http://maps.google.com/maps?ll=47.574427,-122.359307&spn=0.007247,0.015044&t=k&hl=en Link to comment Share on other sites More sharing options...
PhilT Posted October 3, 2005 Share Posted October 3, 2005 port of Seattle, same location as the ship in this link: http://maps.google.com/maps?ll=47.574427,-122.359307&spn=0.007247,0.015044&t=k&hl=en You must have some friends in high places to get into the Port, with all the new security rules now. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Drift Monkey Posted October 3, 2005 Share Posted October 3, 2005 I need to roll my rear fenders because 18x8 ET48 with a 245/35/18 absolutely, positively, 100% chance will rub when the back end is loaded down. I loaded up the area behind the seats with top soil, grass seed and manure.....I had to pull the weatherstripping off and go real slow to make it home. Maybe 300lbs back there. I should have layed the seats down and moved the load between the axles, but now I know it's an issue. You're a wagon. Link to comment Share on other sites More sharing options...
RADON Posted October 3, 2005 Share Posted October 3, 2005 I want the G-force in 18's. Come on Rota! Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted October 3, 2005 Share Posted October 3, 2005 You're a wagon. You're a bad lil horsey. Link to comment Share on other sites More sharing options...
