moddingbug Posted July 1, 2015 Share Posted July 1, 2015 http://www.ortizcustompods.com/subaru.html?m this is what I was actually looking at. Appears to be identical Yep, AutoCityImports states it's from Ortiz Custom Pods too! I think I'll buy this one. Looks nice & clean, utilizes the OEM trim for perfect fit! Excited! Link to comment Share on other sites More sharing options...
Zee199969 Posted July 1, 2015 Share Posted July 1, 2015 I was thinking about going the vent pod route... but a single goes for $85 and dual is already $125. I think I like the gauge cluster pod layout more... the enabling continues My "Build" Link to comment Share on other sites More sharing options...
s2baru Posted July 1, 2015 Author Share Posted July 1, 2015 And you weren't going to share it with us? http://ccs.dogpile.com/ClickHandler.ashx?ld=20150701&app=1&c=info.dogpl&s=Dogpile&rc=info.dogpl&dc=&euip=66.234.199.109&pvaid=9494ae515aab4eeab1079d97156b6164&dt=Desktop&sid=1830193568.2882075271224.1435777726&vid=1830193568.2882075271224.1426791451.774&fcoi=417&fcop=topnav&fct.uid=243283b6629b4828aad7994a67130d48&fpid=2&en=0WEFU%2FZhSoTF%2FFm%2BpLeuVl4UPZzISdzyg%2BaGYj7N8ISb7M1aTnzzgA%3D%3D&du=http%3A%2F%2Fwww.knittinghelp.com%2Fforum%2Fimages%2Fsmilies%2Faug08_021.gif&ru=http%3A%2F%2Fwww.knittinghelp.com%2Fforum%2Fimages%2Fsmilies%2Faug08_021.gif&ap=9&coi=772&cop=main-title&npp=9&p=0&pp=0&ep=9&mid=9&hash=8640C72496F88F7B8CC463C77B3F5AD4 Nope. Link to comment Share on other sites More sharing options...
eyekon Posted July 4, 2015 Share Posted July 4, 2015 If you guys are interested in gauges Podi.ca is a great company that makes gauges. Winston is extremely knowledgeable with the in's and outs if any of you have questions as well. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
brandon.mol Posted July 4, 2015 Share Posted July 4, 2015 I find the scangauge 2 to be quite useful. It can display anything that your ECU reports, including custom stuff if you know the memory address to grab it. It can replace some of the more basic gauges, like voltage, water, arit emps, open/closed loop, etc. Its also handy for doing 0-60 times, 1/4 mi times, etc. I've not tried it yet, but you can extract anything in the CANSF messages, including O2 sensor data, fuel trim, A/F ratios, and commanded A/F. Link to comment Share on other sites More sharing options...
brandon.mol Posted July 5, 2015 Share Posted July 5, 2015 Update: I have it displaying the following now as well: O2 bank 1, sensor 2 0-99% AFR, bank 1 Commanded AFR Short term fuel trim Long term fuel trim Fuel tank level, in percent Link to comment Share on other sites More sharing options...
s2baru Posted July 5, 2015 Author Share Posted July 5, 2015 Pics? Link to comment Share on other sites More sharing options...
s2baru Posted July 6, 2015 Author Share Posted July 6, 2015 http://www.rallysportdirect.com/Innovate-Motorsports-3852-MTX-D-Dual-Function-Oil-Temperature-Pressure-Gauge-52mm Thoughts anyone? Then need to find say AFR & ??? Combo http://www.innovatemotorsports.com/products/psb1.php Link to comment Share on other sites More sharing options...
s2baru Posted July 6, 2015 Author Share Posted July 6, 2015 Orrrr 2 of these bad boys Link to comment Share on other sites More sharing options...
brandon.mol Posted July 6, 2015 Share Posted July 6, 2015 Of a scanGauge 2? They aren't pretty. I have mine mounted on my A-pillar: http://www.scangauge.com/products/scangaugeii/ Apparently I can also get "Catalyst Temperature" with it... not sure if it's useful to know how hot my cat is... Link to comment Share on other sites More sharing options...
s2baru Posted July 6, 2015 Author Share Posted July 6, 2015 I could always get that for the center to full the void between the two pods... Hmmmm Link to comment Share on other sites More sharing options...
brandon.mol Posted July 6, 2015 Share Posted July 6, 2015 It plugs into your OBD2 port, FYI, so you can't have it + AP connected at once, unless you have some port duplicating jiggery-pokery if such a thing exists. Not sure if you are an AP-plugged-in-always kind of guy. I do find this thing nifty with all the functions they have. And they turn on and off with the car, powered off the OBD2 port. Backlight colour and brightness is highly customizable. I have 2 of them.. one in each vehicle. I find the distance to empty and fuel level readings EXTREMELY accurate.. like... down to 1% of fuel (once calibrated). Link to comment Share on other sites More sharing options...
s2baru Posted July 6, 2015 Author Share Posted July 6, 2015 Normally I do have the AP always in or an OBD dongle to run the Torque App. I need to do the trade in for the v3 Link to comment Share on other sites More sharing options...
GTEASER Posted July 6, 2015 Share Posted July 6, 2015 Splitting the ECU signal to dual OBDII ports is technically possible, but others have tried it and apparently it degrades the signal enough that it causes inaccurate data display. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
s2baru Posted July 6, 2015 Author Share Posted July 6, 2015 I won't be attempting that. Link to comment Share on other sites More sharing options...
Zee199969 Posted July 6, 2015 Share Posted July 6, 2015 If you guys are interested in gauges Podi.ca is a great company that makes gauges. Winston is extremely knowledgeable with the in's and outs if any of you have questions as well. Sent from my iPhone using Tapatalk do you have pics of the podi gauges installed? My "Build" Link to comment Share on other sites More sharing options...
Rutchard Posted July 6, 2015 Share Posted July 6, 2015 Apparently I can also get "Catalyst Temperature" with it... not sure if it's useful to know how hot my cat is... Pretty sure there's not a temp sensor anywhere in/on the cat anyways, unless it is figuring something out from the o2 sensors.... Link to comment Share on other sites More sharing options...
dohclgt Posted July 6, 2015 Share Posted July 6, 2015 http://www.rallysportdirect.com/Innovate-Motorsports-3852-MTX-D-Dual-Function-Oil-Temperature-Pressure-Gauge-52mm Thoughts anyone? Then need to find say AFR & ??? Combo http://www.innovatemotorsports.com/products/psb1.php The MTX dual gauge is pretty good. I was going to get that but decided against it because it doesn't dim enough at night. I dont want it to be a distraction. Also the gauge uses a serial port for configuration, a bit out dated. If you don't care about these "flaws", then I think it's a solid gauge to have! Link to comment Share on other sites More sharing options...
s2baru Posted July 6, 2015 Author Share Posted July 6, 2015 The PSB-1 is more appealing to me at the moment Link to comment Share on other sites More sharing options...
Swannee225 Posted July 21, 2015 Share Posted July 21, 2015 What is everyones take on Prosport gauges. I have 2. I haven't installed them yet cause one of the faces has a big scratch in it. I have the 52mm premium oil pressure and boost. Link to comment Share on other sites More sharing options...
GTEASER Posted July 21, 2015 Share Posted July 21, 2015 Personally I wouldnt bother. They are definitely on the inexpensive end of the spectrum. Heard a lot of random failure stories. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
s2baru Posted July 21, 2015 Author Share Posted July 21, 2015 Can't say I'm a fan of prosport either Link to comment Share on other sites More sharing options...
MTBwrench Posted July 21, 2015 Share Posted July 21, 2015 I'll agree too. I know some people that have had great luck with them, but I know way more people that haven't. My personal favorite at the moment is PLX devices. Sent from my iPhone using Tapatalk MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
silentsnow31802 Posted July 21, 2015 Share Posted July 21, 2015 I use the prosport gauges because they match the stock ones. I have not had much time with them but my afr gauge is about .2 off from what my lc1 is data logging. I assume the prosport is the one that is off but I can't confirm that. I do however dislike the external button. It's a pain trying to run that wire from the back to the outside of the gauge. I do like the limited wiring to the back of the gauge though. My mtx devices had huge amounts of wiring coming out the back of them and that made it hard to mount them. Sent from my C6916 using Tapatalk Link to comment Share on other sites More sharing options...
Swannee225 Posted July 21, 2015 Share Posted July 21, 2015 I guess I will install them for the time being. Until I can save up for some Defi gauges. Better having some idea of what's going on than no idea. Link to comment Share on other sites More sharing options...
