dohclgt Posted January 8, 2016 Share Posted January 8, 2016 dohclgt, how do you have the power leads wired up on your Podi gauge? I'm trying to figure out how to get the backlight to dim before I rip my dash apart (replacing my dead SPT gauge in the existing housing). I've seen a couple things about hooking the constant power lead to the dimmer switch, but apparently there's not enough juice there if you dim it too much. The Podi gauge doesn't have an auto-dimming function. You can adjust it manually though; I didn't know that before buying the gauge . No regrets though because it matches the cluster so well I love it. The VEI pressure gauge has an auto-dimming function BUT i haven't found a way to make it work yet. GTEASER got a great idea though. Link to comment Share on other sites More sharing options...
GTEASER Posted January 8, 2016 Share Posted January 8, 2016 Thanks! Yep, I love it. As long as they are lit by LEDs, this will work great. You can just mount it under the dash or behind the fuse box panel, or do as I did and extend the knob with a piece of aluminum rod and mount it behind protruding from a dash switch blank. See my build thread for deets. http://www.autometer.com/led-lighting-dimmer.html GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
dohclgt Posted January 8, 2016 Share Posted January 8, 2016 ...is that the Podi Classic White Needle boost gauge? Yes, even though it said "White Needle", I could change my need to red or white. I could change the backlight to white or red too. Link to comment Share on other sites More sharing options...
Unsp0kn Posted January 8, 2016 Share Posted January 8, 2016 That Podi gauge looks great with the stock cluster, I think I need one. The wife is gonna kill me! EDIT: dohclgt what cluster pod setup is that? I like it. Link to comment Share on other sites More sharing options...
cww516 Posted January 8, 2016 Share Posted January 8, 2016 They're pretty inexpensive by comparison- just tell her how much the Stack gauge is and that you're actually saving money, then run away. Link to comment Share on other sites More sharing options...
dohclgt Posted January 8, 2016 Share Posted January 8, 2016 That Podi gauge looks great with the stock cluster, I think I need one. The wife is gonna kill me! EDIT: dohclgt what cluster pod setup is that? I like it. Thanks Unsp0kn. I really like the podi gauge. It matches my cluster at least 99% imho lol. I had Block8head over at the mazda forum custom made it for me. The vent pod was made by him too. If you plan doing the vent and the cluster bezel pod, I highly suggest you do it at the same time because he needs it angle it together so they match. So one isnt like slightly facing in different direction, hopefully that make sense.. LOL just a tip. Link to comment Share on other sites More sharing options...
Unsp0kn Posted January 8, 2016 Share Posted January 8, 2016 Thanks Unsp0kn. I really like the podi gauge. It matches my cluster at least 99% imho lol. I had Block8head over at the mazda forum custom made it for me. The vent pod was made by him too. If you plan doing the vent and the cluster bezel pod, I highly suggest you do it at the same time because he needs it angle it together so they match. So one isnt like slightly facing in different direction, hopefully that make sense.. LOL just a tip. Yeah I was just planning on one gauge and really like that bezel pod, it's clean and puts the gauge in the perfect spot for me. Link to comment Share on other sites More sharing options...
Syndicate Posted March 9, 2016 Share Posted March 9, 2016 I have one on the way ...any chance you had a chance to install this? Pics? Link to comment Share on other sites More sharing options...
Ellesedil Posted March 9, 2016 Share Posted March 9, 2016 Speaking of gauges, has anyone looked into installing gauges in the opening below the climate control just past the shifter? I used to keep some stuff in there, but it'd always wind up finding the shifter on "spirited" acceleration. So, I'm wondering if it'd be a good spot for some gauges instead. Link to comment Share on other sites More sharing options...
GTEASER Posted March 9, 2016 Share Posted March 9, 2016 I was planning on putting a backup camera screen there originally but plans have changed. Probably put EGT gauges there. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Ellesedil Posted March 9, 2016 Share Posted March 9, 2016 I was planning on putting a backup camera screen there originally but plans have changed. Probably put EGT gauges there. I have factory nav, so... gauges! If they'll fit and can be routed easily enough. Link to comment Share on other sites More sharing options...
s2baru Posted March 9, 2016 Author Share Posted March 9, 2016 ...any chance you had a chance to install this? Pics? I don't have it installed yet. Debating if I want to get the block8 extra pod attached to it before putting it on. I still haven't bought gauges Link to comment Share on other sites More sharing options...
Holmesy89 Posted March 26, 2016 Share Posted March 26, 2016 Speaking of gauges, has anyone looked into installing gauges in the opening below the climate control just past the shifter? I used to keep some stuff in there, but it'd always wind up finding the shifter on "spirited" acceleration. So, I'm wondering if it'd be a good spot for some gauges instead. It's in the works. Will take me a while with my work schedule, but I'll get there. Will take a fair bit of pulling the radio apart to wire them in neatly, but I hope it'll look factory finished my the end Link to comment Share on other sites More sharing options...
