cmdetailing Posted November 15, 2015 Author Share Posted November 15, 2015 I buy these : Amazon.com: TYC 800005P Toyota Replacement Cabin Air Filter: Automotive Thanks for the link! Link to comment Share on other sites More sharing options...
Max Capacity Posted November 15, 2015 Share Posted November 15, 2015 That is an interesting idea. Would have never thought of that. I saw on an episode on Mighty Car Mods that all your need to do is remove the glove compartment to get to the filter. Is it really that easy? Depends on the model year. 05's suck, Subaru fixed that on later years, a couple screws and its out. 05's you start at the center consul and work your way to it. There is a retro fit kit. But I never bought it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted November 15, 2015 Author Share Posted November 15, 2015 Depends on the model year. 05's suck, Subaru fixed that on later years, a couple screws and its out. 05's you start at the center consul and work your way to it. There is a retro fit kit. But I never bought it. I believe theirs was an 03 but the same model. I was hoping I wouldn't have to take the center console off. Oh well I will give it a go this winter. Link to comment Share on other sites More sharing options...
cmdetailing Posted November 26, 2015 Author Share Posted November 26, 2015 Status update, well everything is buttoned up for the most part. Few issues tho, one my temp gauge on my dash is right below the red after a short drive, two I still have an exhaust leak after putting on grimmspeed gasket, and three car is kinda slow to respond with throttle. Maybe that is due to the tune not being complete? Link to comment Share on other sites More sharing options...
cmdetailing Posted November 29, 2015 Author Share Posted November 29, 2015 I am thinking maybe that my thermostat is not opening? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 1, 2015 Share Posted December 1, 2015 I assume you don't have air in the coolant system ? Jack up the right front corner of the car, remove the cap from the turbo coolant tank and start the car, watch for bubbles as you squeeze the top hose, open the heater too to high too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted December 4, 2015 Author Share Posted December 4, 2015 I assume you don't have air in the coolant system ? Jack up the right front corner of the car, remove the cap from the turbo coolant tank and start the car, watch for bubbles as you squeeze the top hose, open the heater too to high too. I will try that, for some reason tho I still think that the thermostat is not opening. I might get a new oem one just to try it and see. Link to comment Share on other sites More sharing options...
cmdetailing Posted December 9, 2015 Author Share Posted December 9, 2015 Does anyone have Invidia's Q300 catback exhaust on there car? I am thinking this would help with the exhaust leak where the downpipe and midpipe meet at. Also I think the quad tip would look sexy! I have read that long hangers were recommend with this cat back. Any thoughts? Link to comment Share on other sites More sharing options...
cmdetailing Posted December 13, 2015 Author Share Posted December 13, 2015 Both of my lower grounds were rusted and broken. I was wondering if anyone knew what was a good alternative to replace them with that wont wear as quickly? Thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted December 15, 2015 Share Posted December 15, 2015 Where have you been, just about anything will work. http://i185.photobucket.com/albums/x40/92Si/DSCN5218_zps47b42c1c.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted December 15, 2015 Share Posted December 15, 2015 Next time I'll use these. http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Battery-Cable-Grounding-Straps-Cables-Phillips-Industries/_/R-PHI9151_0008248539 We use them at work as the ground wire for a 480 volt transformer on a product we build for the US Navy. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted December 15, 2015 Author Share Posted December 15, 2015 Where have you been, just about anything will work. http://i185.photobucket.com/albums/x40/92Si/DSCN5218_zps47b42c1c.jpg I have been busy with finals and graduation. Those Phillips cables look like they will do the trick. Hitting the car hardcore next week. Link to comment Share on other sites More sharing options...
cmdetailing Posted December 27, 2015 Author Share Posted December 27, 2015 After installing the new thermostat and burping the system my subaru is where is should be cooling wise. Now a new issue has arisen, I know right shocker! After a quick drive down the road I ran into an issue in which I got a check engine light, ABS light, and my cruise light flashing. After checking my AP for what the code is it read P0500 Speed Sensor. Also I am getting this terrible grind noise up from like the brake area when the car is in motion. Would the faulty speed sensor cause this to happen? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 27, 2015 Share Posted December 27, 2015 If something is broken or loose in one of the wheels, I'm guessing yes. I think you need to pull the wheel and take a look. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted December 27, 2015 Author Share Posted December 27, 2015 Is there a way to determine whY speed sensor it is? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 28, 2015 Share Posted December 28, 2015 I know there is an expensive computer that repair shops have that will tell you as you drive the car. I can borrow one...but that wouldn't help you. See if a local repair shop will plug it in and drive the car and tell you which one. It may cost a few $$. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted December 29, 2015 Author Share Posted December 29, 2015 I know there is an expensive computer that repair shops have that will tell you as you drive the car. I can borrow one...but that wouldn't help you. See if a local repair shop will plug it in and drive the car and tell you which one. It may cost a few $$. I read somewhere that you can plug the doagnostic green cables together and it will give you a code as to which sensor it is. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 29, 2015 Share Posted December 29, 2015 http://i185.photobucket.com/albums/x40/92Si/CELcodereaderina05_zpseda523cf.png Try that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted December 30, 2015 Author Share Posted December 30, 2015 http://i185.photobucket.com/albums/x40/92Si/CELcodereaderina05_zpseda523cf.png Try that. Thanks a ton! I will have to try that in the morning. Today I took the wheels off to see if I could determine what was making that loud spueaking noise. On the passenger side that dust shield behind the rotor was pressed against the rotor. Could this have been the issue? The shield grinding against the rotor and causing the wheel to slow down tripping the speed sensor? Everything else looked okay. Link to comment Share on other sites More sharing options...
cmdetailing Posted December 30, 2015 Author Share Posted December 30, 2015 http://i185.photobucket.com/albums/x40/92Si/CELcodereaderina05_zpseda523cf.png Try that. Thanks that worked! I got the code C0108, which I have narrowed down to the front left sensor. I also got the code P0328 while take a quick drive, and I am not entirely sure what this code refers to. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 31, 2015 Share Posted December 31, 2015 http://legacygt.com/forums/showthread.php/trouble-codes-cels-26113.html 328 is a knock sensor. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted December 31, 2015 Author Share Posted December 31, 2015 http://legacygt.com/forums/showthread.php/trouble-codes-cels-26113.html 328 is a knock sensor. Have any idea have to fix it? I talk to David from Cryotuning, as he will be doing the final tune on my car. He said that it could be the sensor or the connection itself. I think I have an idea where this sensor is on the motor. After I get my new speed sensor in I will take the car out and see if I get the check engine light again and deal with the sensor. Hopefully I wont have to buy a new sensor. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 4, 2016 Share Posted January 4, 2016 On the oppossedforces web site in the sticky at the top of the very first forum you can find all the pieces and parts you ever want to know about. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted January 13, 2016 Author Share Posted January 13, 2016 Anyone have any tips for how to fix an exhaust leak where the downpipe and cat back meet? It seems to be at the lower end of the connection. I have installed a new donut with a grimmspeed gasket to try and fix it. I am going to take a wire brush to the old catback to see if that helps the seal. I really do not want to go to an exhaust shop as I dont want them messing up my new Cobb downpipe. Link to comment Share on other sites More sharing options...
rmoore5 Posted January 13, 2016 Share Posted January 13, 2016 Can you try bolting them together before putting the hanger bolt in. I'm not remembering the exact assembly, but I assume the cobb isn't meeting the exhaust pipe square. Otherwise a thicker more compliant homemade gasket. Link to comment Share on other sites More sharing options...
