cmdetailing Posted August 27, 2015 Author Share Posted August 27, 2015 Well it has been awhile... I am a very busy man. The engine is in the car, new brakes installed, and wheels are put on. Current issues I am waiting to fix is on the new oil line I accidenttly put to copper washes on the banjo bolt on the back of the passenger head. My wide band gauge isnt turning on so I need to look at that. Lastly my front bumper is still off. Other than that I should have it done Labor day weekend. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 28, 2015 Share Posted August 28, 2015 Keep us updated, sounds like your getting close. That banjo dose get two crush washers...just not on the same side. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted August 29, 2015 Author Share Posted August 29, 2015 Keep us updated, sounds like your getting close. That banjo dose get two crush washers...just not on the same side. Yes I was aware. Apparently I forgot to take off the old one prior to installing the new one. Haha I will blame it on a long night oversight. Does anyone know the best fuse for a AEM wideband gauge and where to ground it? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 29, 2015 Share Posted August 29, 2015 Ground should be to any place on the frame of the car. Not sure about the fuse. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted September 4, 2015 Author Share Posted September 4, 2015 What do you guys think? Needs a bath, but I like my new wheels! Link to comment Share on other sites More sharing options...
cmdetailing Posted September 5, 2015 Author Share Posted September 5, 2015 Picked up some new front Centric rotors and a Whiteline front sway bar to get my suspension needs started off. Link to comment Share on other sites More sharing options...
cmdetailing Posted September 6, 2015 Author Share Posted September 6, 2015 Started it up and no oil leak! There seems to be some smoke coming from the up pipe? Can't determine if it's all the oil from that leaking line or exhaust leak... Also I thought that the Con downpipe doesn't need a gasket for the stock catback? Seems to be a leak? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 6, 2015 Share Posted September 6, 2015 I run a Grimmspeed 2X gasket at the DP to stock midpipe. Underdog can get you one. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted September 6, 2015 Author Share Posted September 6, 2015 I run a Grimmspeed 2X gasket at the DP to stock midpipe. Underdog can get you one. I saw those, will I need the adaptor as well? Any thoughts on the smoke? Thanks Link to comment Share on other sites More sharing options...
cmdetailing Posted September 7, 2015 Author Share Posted September 7, 2015 I have a video of the smoke if any one would like to take a look? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2015 Share Posted September 8, 2015 My Invidia DP mates up cleanly with the stock mid pipe using the 2X gasket. No adapter needed. You need to get under the up pipe with a good flash light and check out if you have a leak above it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted September 10, 2015 Author Share Posted September 10, 2015 My Invidia DP mates up cleanly with the stock mid pipe using the 2X gasket. No adapter needed. You need to get under the up pipe with a good flash light and check out if you have a leak above it. I have to look at it when I get home in a few weeks. Thanks for the advice throughout the build. It is nice to have some feedback. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 11, 2015 Share Posted September 11, 2015 Your Welcome. That's why most of us hang around here, to help and get help. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted October 22, 2015 Author Share Posted October 22, 2015 Hey guys I am looking for a stock air box. If anyone could direct me in the right direction that would be awesome! Also if anyone is interested in my perrin intake up for offers! Link to comment Share on other sites More sharing options...
quick4dr Posted October 22, 2015 Share Posted October 22, 2015 Hey Guy I am looking for a stock air box. If anyone could direct me in the right direction that would be awesome! Also if anyone is interested in my perrin intake up for offers! gotta check my basement but i believe i have my full stock intake including snorkel. located in 10954 Link to comment Share on other sites More sharing options...
cmdetailing Posted October 22, 2015 Author Share Posted October 22, 2015 gotta check my basement but i believe i have my full stock intake including snorkel. located in 10954[/QUOT Does that include the bolts? My legacy when I purchased it came with an aftermarket intake, so I have no idea of the orientation. I can pay today if you find it. Link to comment Share on other sites More sharing options...
quick4dr Posted October 22, 2015 Share Posted October 22, 2015 wont get a chance to get into my basement till after work tonight. if correct its the box with the maf tube, and snorkel, should have the hardware too, not sure how much shipping will be its rather bulky, ill get it all out tonight and see. txt me for faster relplies, and not to clogg up this thread. 1-845-three two three 255 three Link to comment Share on other sites More sharing options...
cmdetailing Posted October 22, 2015 Author Share Posted October 22, 2015 What are everyone's thought on the under tray cover? Mine is cracked and torn into various bits. Is it worth installing or should I leave it off? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 22, 2015 Share Posted October 22, 2015 car-parts.com for a used one from a junk yard. They do serve a purpose, they help with air flow. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted October 22, 2015 Author Share Posted October 22, 2015 car-parts.com for a used one from a junk yard. They do serve a purpose, they help with air flow. What would be the correct name for this part? I know I saw a company that makes an aluminum plate. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 23, 2015 Share Posted October 23, 2015 Oh yea, may be call a local yard and see if they can find you an lower engine cover. I just went through that thought process looking for a use propeller shaft, they don't have a listing for that either. Some of the yards had them listed under rear driveshaft. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmdetailing Posted November 15, 2015 Author Share Posted November 15, 2015 Does anyone know where to get a good quality cabin filter? I suppose I could to an auto store, but was curious if anyone had any recommendations? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 15, 2015 Share Posted November 15, 2015 You can cut up a furnace filter from home depot, they are a few bucks. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rmoore5 Posted November 15, 2015 Share Posted November 15, 2015 I buy these : [ame=http://www.amazon.com/TYC-800005P-Toyota-Replacement-Filter/dp/B000VKTUD2/ref=as_sl_pc_wdgt_ex?&linkCode=wsw&tag=themenillhaph-20]Amazon.com: TYC 800005P Toyota Replacement Cabin Air Filter: Automotive[/ame] Link to comment Share on other sites More sharing options...
cmdetailing Posted November 15, 2015 Author Share Posted November 15, 2015 You can cut up a furnace filter from home depot, they are a few bucks. That is an interesting idea. Would have never thought of that. I saw on an episode on Mighty Car Mods that all your need to do is remove the glove compartment to get to the filter. Is it really that easy? Link to comment Share on other sites More sharing options...
