Sgt.Gator Posted June 20, 2016 Author Share Posted June 20, 2016 Every once in a while we debate here on the forum about whether we really have to replace the oil cooler if your engine blew and you are rebuilding. Here's the answer from OutFront Motorsports, along with more good info: "Thank you for purchasing a Short block from Outfront Motorsports, if your engine is equipped with an oil cooler and the short block was replaced because of rod, main or turbo bearing failure, the oil cooler must be replaced, as there may be debris trapped in the cooler that won’t release until it is subjected to both high oil pressure and heat. These coolers cost around $260 new. If a warrantee arises due to bearing failure, we will request a copy of the cooler purchase. If your engine is equipped with a turbo: a bad/blown turbo can send debris into the crankcase and oiling system. Make sure to clean the turbo drain/feed hoses and nipples before installation. If the short block was replaced because of piston failure, cracking or melting, the intake manifold, exhaust manifolds and cylinder ports must be cleaned and free of debris. Remove the throttle body from the intake to access and clean the plenum of the intake. We have seen particles that have blown from one side of the engine through the intake and lodge itself in the plenum or opposite side intake runners, only to be consumed by the new engine upon start up. We recommend an oil pump of at least a #10 found in the upper left corner of the pump when looking at it. Do not use #7 or #9 pumps. The number refers to the millimeter thickness of the gears inside. On high performance engines, oil pressure will generally be lower at idle than stock engines as we have enlarged the bearing clearances for sustained higher engine RPM operation. If your engine is supplied with high performance pistons, oil consumption can possibly be higher than normal due to a larger piston to cylinder wall clearance used, this consumption could be up to 1 quart per 800 miles. As a standard our motors do not see this type of oil consumption but this is the Subaru spec. If your engine was rebuilt with stock style pistons, oil consumption of up to one quart per 1200 miles is considered within spec, per Subaru’s’ warranty policy 8.4.29. There are many reasons that a rebuilt short block can appear to be defective, among them are overheating, oil contamination, over boosting, poor engine tune and abuse, inadequate fuel supply (especially under boost). We have a limited warranty which covers workmanship and parts used under normal use for 6 months from time of purchase; we do not consider mileage to be a factor as there is no proof either way of how many miles have been driven or what the mileage was upon installation. We do not cover parts or labor to remove a defective short block, or to reinstall the same if we did not perform the original installation. We do not cover shipping to or from us. We must have the short block (or long block) returned to us in the same manner it was sold for disassembling and inspection. We would prefer to have the oil pan and oil pump left installed. No warranty will be covered if you disassemble the short block. We will deny a warranty if the rods or wrist pins are bent, pistons are melted or ring lands are cracked or opened up due to detonation. We will deny a warranty if the pistons and rings show signs of dirt or foreign debris or if the cylinder(s) show excessive cylinder wear/taper (commonly caused by excessive fueling and/or inadequate air filtration). The purpose of this warranty is to cover proper and competent workmanship and any failure of parts that are used in a manner of normal operating conditions, our warranty does not cover this short block if used in race, competition, or an abusive manner. Recommended break in should be 3000 miles driven under normal conditions, do not use synthetic oils during break-in, use good quality multigrade oils such as Motul 10/40 break-in oil, Valvoline or Castrol. We recommend an oil change with filter at 100, 500 and 1000, 2000, and 3000 miles. At 3000 miles you can switch to synthetic oils if you choose to. For the first 500 – 1000 miles try to avoid long periods of time at the same RPM such as freeway driving at 3500 RPM for 30 minutes. You should vary through the RPM range. Stock boost is fine but you should stay away from high boost/high load situations. If a warranty issue is suspect, please call us before removing the engine or sending back to us. There are certain steps that must be taken to process a claim. Any unauthorized work performed will void any claim. " Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
Max Capacity Posted June 27, 2016 Share Posted June 27, 2016 That's pretty much the warranty I'd expect, and pretty much what I did with my ej257. I did use the old oil cooler, I know I had no metal issues going on. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Sgt.Gator Posted July 23, 2016 Author Share Posted July 23, 2016 My break in is complete so I headed up to Cobb Surgeline for a tune. FAIL. My AVCS cams were stuck at 10 degrees on one side and 22 degrees on the other. When I rebuilt the engine I replaced the AVCS oil control solenoids, but did not replace the AVCS cam sprockets. Mistake. I should have either sent them to Outfront motors for a rebuild, see: http://www.outfrontmotorsports.com/avcs-cam-gear-services/avcs-cam-gear-servicing Or replaced them with new. Strangely they set off no CELs. The car actually drove ok. I couldn't tell the AVCS was not working right because I thought it was just the break in tune I was running and no CELs. Since I'm busy re-building my STI race car I took the SpecB to Subaru of Bend. They replaced the AVCS cam sprockets and now the cam timing works per factory spec. They are going to take the stuck cam sprockets apart later to diagnose the issue, which is no doubt bits of metal jammed in them. They will take pics and I'll post them here. So now on my checklist for engines that have failed with metal bits in the oil: Replace or Service the AVCS Cam Sprockets. If I had done it when I rebuilt the engine I would have saved in total about $1,000. ($400 wasted Cobb tuning session, 400 mile round trip, day off from work, and AVCS sprocket replacement labor). Edit: Here's the pic. The tech described it as Nasty-Gooey stuff in there! Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
Max Capacity Posted July 25, 2016 Share Posted July 25, 2016 Kind of the old...pay now or pay me later thing. Hind sight is 20/20. Glad you got it figured out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Sgt.Gator Posted July 26, 2016 Author Share Posted July 26, 2016 Colonel Red Racing is now an official vendor here at LGT Forum. Please see my announcement in the Vendor News Forum: http://legacygt.com/forums/showthread.php/colonel-red-racing-joins-legacy-vendor-program-254750.html Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
Sgt.Gator Posted August 6, 2016 Author Share Posted August 6, 2016 On the Dyno at Cobb - Surgeline. So far so good! Only had to replace a worn MAF sensor. They are doing a very cool trick, using the SI-Drive rotary switch as a turbo boost map selector. Dyno chart tonight. Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 6, 2016 Share Posted August 6, 2016 On the Dyno at Cobb - Surgeline. So far so good! Only had to replace a worn MAF sensor. They are doing a very cool trick, using the SI-Drive rotary switch as a turbo boost map selector. Dyno chart tonight. Yup my tuner did the same thing on my old car. I pretty much never used the high boost setting for fear of cracking a ring land lol 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rebourne Posted August 6, 2016 Share Posted August 6, 2016 Good thread! Read the whole thing tonight. In for dyno sheet! pic thread build thread Link to comment Share on other sites More sharing options...
Sgt.Gator Posted August 7, 2016 Author Share Posted August 7, 2016 Here's the dyno graph. Run 1 is the WG which is on the SI Drive Intelligent setting. Run 2 is the Sport setting Run 3 is the Sport # setting. I told them to tune it conservatively for long life and reliability at 92 Octane, which they did. Plenty of TQ and HP for a street car. Using the NASA ST rules to correct for a Mustang to Dynojet reading it comes in at 328 TQ and 277 HP. Driving back over the Cascade mountains was a blast. Passing vacation traffic in the short straight sections between mountain curves was no problem! The character of the car is completely changed from a bear to drive on the street or highway because of the lag to a nice responsive GT car suitable for long trips in the mountains. Just the engine tune I wanted. There is a slight hesitation in the 2400 to 2700 rpm range they couldn't completely tune out. I'm going to try replacing the fuel line dampers to see if that corrects the problem. The last mod will be to replace the coilovers/tophats with oem Spec B springs/Bilstein HD struts/oem tophats. Then it should ride like a nice GT car too, instead of a track rat. Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
Sgt.Gator Posted August 7, 2016 Author Share Posted August 7, 2016 Here's what's in the car today engine wise: Build #3 and what is in the Spec B today: Electronics/Tuning Cobb Tuning AccessPort v2 (AP-SUB-003) Cobb - Surgeline Tune GrimmSpeed EBCS Turbo/Induction/Exhaust JMP6889928 Rebuilt VF-46 Turbo OEM TMIC Tomioka EL Header + Up pipe (DEI Titanium Heat Wrapped) Turbo XS Catted DP (DEI Titanium Heat Wrapped) Perrin, Mid-Ypipe OEM Mufflers OEM Snorkel and Airbox/Filter OEM BPV GrimmSpeed 8mm Phenolic Spacers Perrin Performance Turbo Inlet Hose (Black) Engine/Fueling OEM Shortblock ARP Head Studs OEM 10mm oil pump Gates Racing Timing Kit Cosworth “like” Heads – 2007 STI V25B modified and purchased from BallPeenHamr (a Cosworth employee whose job is to build all Cosworth heads) on NASIOC.com. 5 angle valve job Ported/Polished/Seat/Bowl blend/Ferrea dual valve springs hardened spring seats and locks, titanium retainers, Stock STI cams. Supertech Inconel Exhaust Valves OEM WRX Water Pump OEM STI Head Gasket STI Oil pan Moroso Pickup Fumoto Oil Drain Plug/Valve NGK Iridium plugs Custom DW 65c fuel pump assembly – With IP&T Pump Housing Bracket Cobb 1000cc Fuel Injectors Infamous Performance Filtered Turbo/AVCS Oil Supply Line v2 OEM PCV Secondary Air Pump Delete TGV Delete Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
rebourne Posted August 7, 2016 Share Posted August 7, 2016 Here's the dyno graph. Run 1 is the WG which is on the SI Drive Intelligent setting. Run 2 is the Sport setting Run 3 is the Sport # setting. I told them to tune it conservatively for long life and reliability at 92 Octane, which they did. Plenty of TQ and HP for a street car. Using the NASA ST rules to correct for a Mustang to Dynojet reading it comes in at 328 TQ and 277 HP. Driving back over the Cascade mountains was a blast. Passing vacation traffic in the short straight sections between mountain curves was no problem! The character of the car is completely changed from a bear to drive on the street or highway because of the lag to a nice responsive GT car suitable for long trips in the mountains. Just the engine tune I wanted. There is a slight hesitation in the 2400 to 2700 rpm range they couldn't completely tune out. I'm going to try replacing the fuel line dampers to see if that corrects the problem. The last mod will be to replace the coilovers/tophats with oem Spec B springs/Bilstein HD struts/oem tophats. Then it should ride like a nice GT car too, instead of a track rat. Dyno numbers look great! love the idea of the 3 maps, although I am not sure what is the point of the first WG map? Fuel economy? I'd want a fuel economy or a maybe a bad gas, 87 octane map. Or 15psi for the first map, 17psi for Sport and E85 for Sport #, lol! pic thread build thread Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 7, 2016 Share Posted August 7, 2016 Dyno numbers look great! love the idea of the 3 maps, although I am not sure what is the point of the first WG map? Fuel economy? I'd want a fuel economy or a maybe a bad gas, 87 octane map. Or 15psi for the first map, 17psi for Sport and E85 for Sport #, lol! The SI-Drive doesn't actually change the maps it just changes the requested torque targets. So a full different tune for E85 wouldn't work. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
Rhitter Posted August 7, 2016 Share Posted August 7, 2016 The SI-Drive doesn't actually change the maps it just changes the requested torque targets. So a full different tune for E85 wouldn't work. I think tuners can modify that, so that it does actually change boost targets. I know cryo mentioned he sets the boost targets slightly higher for S#. My OBXT build Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 7, 2016 Share Posted August 7, 2016 I think tuners can modify that, so that it does actually change boost targets. I know cryo mentioned he sets the boost targets slightly higher for S#. Yes that is possible given the way the SI-Drive tables work, but typically for E85 you alter the entire tune, fuel, timing etc., not just the boost. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
Sgt.Gator Posted August 7, 2016 Author Share Posted August 7, 2016 Ya'll are correct, it's not actually three maps. It's one map that is divided so that the turbo hits three different peak values. There are other maps in the AP like Valet mode and anti-Theft mode. One thing the tuner explained, even if I'm in Intelligent (WG pressure), if I go WOT for 30 seconds the SI drive will auto reset to Sport #. Or maybe it was 20 seconds, I can't remember the exact time. Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
rebourne Posted August 8, 2016 Share Posted August 8, 2016 The SI-Drive doesn't actually change the maps it just changes the requested torque targets. So a full different tune for E85 wouldn't work. Later on I thought about how dumb it would be to have such a drastic tune change be so easy to dial in. Your kid, your elbow, your clown co-worker could switch it to sport# = e85 and kablowee with no harm intended. So, good to know it's not that easy to dial in your doom! pic thread build thread Link to comment Share on other sites More sharing options...
bigBADbenny Posted August 18, 2016 Share Posted August 18, 2016 My tuner, ThrottleHappy, has been doing SI controller as max boost selector for a few years and also has "throttle as boost controller" on top of that, meaning I can't hit max boost per SI setting till 100% throttle angle. Great for babying a flogged clutch! Additionally he's managed to even out the SI throttle angles so each mode is more consistent than the stock application and the car feels great in any mode with less of a need to adjust for the differences. Currently I have 7, 12 and 15 psi and enjoy all levels for different driving situations Link to comment Share on other sites More sharing options...
Sgt.Gator Posted May 3, 2017 Author Share Posted May 3, 2017 Bumping this thread for two reasons: The engine is running great. I'm going to sell the car to pay for my racing! There will be a For Sale thread up late tonight. Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
boxkita Posted May 4, 2017 Share Posted May 4, 2017 Bumping this thread for two reasons: The engine is running great. I'm going to sell the car to pay for my racing! There will be a For Sale thread up late tonight. LOL! I've never sold a car to pay for my racing. Or my office furniture. Or my bikes, snowboards, stocks, etc. If racing was anymore addictive, it'd be illegal. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Sgt.Gator Posted May 4, 2017 Author Share Posted May 4, 2017 LOL! I've never sold a car to pay for my racing. Or my office furniture. Or my bikes, snowboards, stocks, etc. If racing was anymore addictive, it'd be illegal. The for sale thread is up! Buy it and support a racing career. I'll even put your name on the STI as a sponsor (for two years) if you pay full asking price! http://legacygt.com/forums/showthread.php/bend-2008-spec-b-261972.html?p=5626094#post5626094 Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
