jasejase Posted December 31, 2013 Share Posted December 31, 2013 Anyone have issues with the iphone 5s adapter on the ipod aux cable not working? depends what cord is coming out of the jazzy unit. We had an older jazzy, we needed the 5v adapter, and then we needed the lightning adapter. IIRC Link to comment Share on other sites More sharing options...
Epicmango Posted January 10, 2014 Share Posted January 10, 2014 I JUST SIGNED UP TO ASK YOU THIS! I want a 4th Gen Legacy LGT Limited. Everything is perfect in that car for me EXCEPT that it doesn't have an aux port/subwoofer inputs These are 2 requirements for me in a car, and I am almost going to through out the GT to the curb if I can't get it done... But alas it seems my woes might have a solution! Is this a good solution that is presented here? I want to hook up a subwoofer in the trunk and be able to use my S4 to listen to music!! Link to comment Share on other sites More sharing options...
Arcteryx Posted January 10, 2014 Share Posted January 10, 2014 I JUST SIGNED UP TO ASK YOU THIS! I want a 4th Gen Legacy LGT Limited. Everything is perfect in that car for me EXCEPT that it doesn't have an aux port/subwoofer inputs These are 2 requirements for me in a car, and I am almost going to through out the GT to the curb if I can't get it done... But alas it seems my woes might have a solution! Is this a good solution that is presented here? I want to hook up a subwoofer in the trunk and be able to use my S4 to listen to music!! I can also offer another option if you don't want to have to wait and shell out for an '07-'09 OEM unit - I've got Redfloyd's aux-in kit hooked up with my stock headunit, and I'll be selling it soon. Let me know if you're interested. Link to comment Share on other sites More sharing options...
Socbum Posted January 12, 2014 Share Posted January 12, 2014 Another happy customer:) I bought the board with the GLI and ran a female plug into the center console. Everything fits great Initially I had a problem with the faceplate not working, but after disassembling and reassembling at least 5 times I was able to get the faceplate working. I ended up taking the entire radio frame apart, realigning the circuit boards and the frames. When I put the faceplate back on, instead of being gentle, I pushed real hard on the face where the connections plug into the boards. Thanks for a great product. Link to comment Share on other sites More sharing options...
Totaled04Rex Posted January 15, 2014 Share Posted January 15, 2014 (edited) Nm. Edited January 16, 2014 by Totaled04Rex Link to comment Share on other sites More sharing options...
Sublimejoe Posted January 24, 2014 Share Posted January 24, 2014 Does anyone know where I can find a female 1/8" jack that I can flush mount into the center console? Ideally I would like to have it be female on both ends so I can just plug the other end of the RCA>1/8" male into it, but hide under the console. Link to comment Share on other sites More sharing options...
tdelker Posted January 24, 2014 Share Posted January 24, 2014 Here's a kit: [ame=http://www.amazon.com/iSimple-IS335-Mountable-Auxiliary-Adapter/dp/B003B01AHS/ref=pd_ybh_5]Amazon.com: iSimple IS335 Dash Mountable Auxiliary Input Adapter: Car Electronics[/ame] Link to comment Share on other sites More sharing options...
liquidimpulse Posted January 30, 2014 Share Posted January 30, 2014 In the process of installing the pro kit and I've been having major issues. The audio sounds very "faint"- there is really no better way to describe it, but the quality is definitely not CD audio quality. I do think it is mostly because the ribbon cables are not straight- I have not found a way to install the board without twisting it in some way to connect both the ribbon cables as well as the RCA input from the provided GLI. any advice in terms of how you went about installing this? Details from the manual are vague and it appears the board i have is different than the one mentioned in the manual. thanks! Link to comment Share on other sites More sharing options...
Sublimejoe Posted February 1, 2014 Share Posted February 1, 2014 Just finished installing my kit. Can't wait to instal it into the car tomorrow. Fingers crossed I didn't screw anything up. Link to comment Share on other sites More sharing options...
Sublimejoe Posted February 1, 2014 Share Posted February 1, 2014 just finished putting new head unit in and I'm having some issues. Initially when I hooked the new head unit up with the jazzy mod the cd changer worked fine and the aux Input was working but only coming out of the passenger side speakers. I took the head unit back out to verify that the jazzy board was correct and it was. After reinstalling the cd changer no longer works at all, I just get a few dashes across the screen when I press the cd button then it just switches back to FM. I took it back out and back apart twice to try to figure out the issue to no avail. Any ideas? Link to comment Share on other sites More sharing options...
jasejase Posted February 2, 2014 Share Posted February 2, 2014 Take it out a third time, something's not right! Link to comment Share on other sites More sharing options...
Sublimejoe Posted February 2, 2014 Share Posted February 2, 2014 (edited) Take it out a third time, something's not right! It's out now. Looked at it side by side with my other one and I can't figure out what's wrong. Thinking maybe I used a long screw where I should have used a short one and it's grounding out. Edit: Well I guess the old saying is true, third times a charm. Took it apart and put it back together the exact same way except this time it works. Edited February 2, 2014 by Sublimejoe Link to comment Share on other sites More sharing options...
tdelker Posted February 2, 2014 Share Posted February 2, 2014 Yes, here is a long screw vs short screw issue that can prevent the CD from working properly. Link to comment Share on other sites More sharing options...
NastyLGT Posted February 22, 2014 Share Posted February 22, 2014 Anyone hear of jazzy lately? Looking to order from his site but don't want to throw away money... Link to comment Share on other sites More sharing options...
Totaled04Rex Posted February 25, 2014 Share Posted February 25, 2014 Last I heard he had some life stuff going on. I ordered mine and got it almost 2 weeks later and he is 2 hours south of me same state. Sent from my iPhone using Tapatalk - now Free Link to comment Share on other sites More sharing options...
NastyLGT Posted February 25, 2014 Share Posted February 25, 2014 That's unfortunate. Classifieds, here I come! Sent from my SCH-I605 using Tapatalk Link to comment Share on other sites More sharing options...
Sublimejoe Posted February 26, 2014 Share Posted February 26, 2014 I ordered without talking to him and had mine in under a week. Link to comment Share on other sites More sharing options...
NastyLGT Posted February 26, 2014 Share Posted February 26, 2014 Sublimejoe, can I ask when you ordered it? Sent from my SCH-I605 using Tapatalk Link to comment Share on other sites More sharing options...
Sublimejoe Posted February 26, 2014 Share Posted February 26, 2014 Looks like I ordered on 1/24 Link to comment Share on other sites More sharing options...
NastyLGT Posted February 26, 2014 Share Posted February 26, 2014 2014? Sent from my SCH-I605 using Tapatalk Link to comment Share on other sites More sharing options...
Sublimejoe Posted February 26, 2014 Share Posted February 26, 2014 2014? Sent from my SCH-I605 using Tapatalk Yes sir Link to comment Share on other sites More sharing options...
discojon Posted March 4, 2014 Share Posted March 4, 2014 Just placed an order for the pro kit. Thanks Jazzy. I'm going to pair the kit with this input mounted in the glove box. http://ecx.images-amazon.com/images/I/31pu9NE1suL._SX425_.jpg [ame=http://www.amazon.com/gp/product/B0014TSRGK/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1]Amazon.com: ASA Electronics JPORT Auxiliary Input Cable: Sports & Outdoors[/ame] Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted March 4, 2014 I Donated Share Posted March 4, 2014 Just placed an order for the pro kit. Thanks Jazzy. I'm going to pair the kit with this input mounted in the glove box. http://ecx.images-amazon.com/images/I/31pu9NE1suL._SX425_.jpg Amazon.com: ASA Electronics JPORT Auxiliary Input Cable: Sports & Outdoors Why not buy this instead? less wires and works perfectly, I have it in my car sitting in the center console. pro kit with ground loop isolator reaches in there no problem. [ame=http://www.amazon.com/Miccus-Mini-jack-RX-Bluetooth-Receiver/dp/B0038MA11U/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1393952454&sr=1-1-catcorr&keywords=miccus+aux+in]Amazon.com: Miccus Mini-jack RX: Bluetooth Music Receiver pair it with Phones, Tablets, PCs and Apple Devices: MP3 Players & Accessories[/ame] Link to comment Share on other sites More sharing options...
imn8 Posted March 24, 2014 Share Posted March 24, 2014 Why not buy this instead? less wires and works perfectly, I have it in my car sitting in the center console. pro kit with ground loop isolator reaches in there no problem. Amazon.com: Miccus Mini-jack RX: Bluetooth Music Receiver pair it with Phones, Tablets, PCs and Apple Devices: MP3 Players & Accessories That device looks cool. But is it really less wires? It seems like you'd have to leave it hooked up to a dc usb charger all the time... Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted March 24, 2014 I Donated Share Posted March 24, 2014 That device looks cool. But is it really less wires? It seems like you'd have to leave it hooked up to a dc usb charger all the time... I have it hidden inside my center console. I never see it, the jazzy cord runs down underneath my shifter and whatnot straight to there. Link to comment Share on other sites More sharing options...
