Moderators BarManBean Posted August 12, 2014 Moderators Share Posted August 12, 2014 If you are in annapolis see if you can set up an appointment at IAG. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Merc6 Posted August 12, 2014 Share Posted August 12, 2014 Avoid the dealer find a good local shop. Please. If you were still in Maryland, I would say go Dynamic Power Solutions. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
boostedsubbygt Posted August 12, 2014 Author Share Posted August 12, 2014 IAG is a little far away than I had hoped but dynamic is 20 min from my job. Link to comment Share on other sites More sharing options...
Akasa Posted August 15, 2014 Share Posted August 15, 2014 What's a "subby"? Is that like, a BDSM thing? ^ I burn about a quart every 3,750 miles. Running T6 5w40. You'll burn more oil initially if your car has been serviced with conventional, then you switch to regular. I found that true in my case. So don't worry about it, turbocharged Subaru's (well, subaru's in general) burn oil. Link to comment Share on other sites More sharing options...
snow05gtRI Posted August 15, 2014 Share Posted August 15, 2014 i was going through 2quarts every 3k miles. It would hold oil fine until around 1500-2000 miles then just drink it. various kinds of oil, synthetic and conventional. finally did a compression test, which the results then pointed me to investigate and determine I had a cracked ringland in piston #4. compression test is probably the easiest way to determine if you have real engine issues. Link to comment Share on other sites More sharing options...
Wagonation Posted October 27, 2014 Share Posted October 27, 2014 I'm burning about a quart per 1000 mi now at 113k. Using 5w30 conventional. Guess I should try something else and consider a leak down test. Synthetic would probably run right through it. Any recommendations? Trade it for a Honda? Link to comment Share on other sites More sharing options...
lingling1337 Posted October 28, 2014 Share Posted October 28, 2014 Quart per 1000k miles thats not bad lolololol. Seriously though switching to 5w40 and getting a new pcv helped my consumption pretty significantly Link to comment Share on other sites More sharing options...
Wagonation Posted October 28, 2014 Share Posted October 28, 2014 It like a gradual oil change is all. No worries lol. PCV is worth a shot too, agreed. Link to comment Share on other sites More sharing options...
boostedsubbygt Posted October 28, 2014 Author Share Posted October 28, 2014 This high mileage oil has been working for me so far Link to comment Share on other sites More sharing options...
Merc6 Posted October 28, 2014 Share Posted October 28, 2014 This high mileage oil has been working for me so far Good to hear! Were they any cool STi's, EVO's or random BMW's there when you went to their shop? 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
boostedsubbygt Posted October 31, 2014 Author Share Posted October 31, 2014 My oil pick up tube is cracked. Wow explain s the oil issue Link to comment Share on other sites More sharing options...
boostedsubbygt Posted November 4, 2014 Author Share Posted November 4, 2014 My oil light kept going on and off Link to comment Share on other sites More sharing options...
Max Capacity Posted November 4, 2014 Share Posted November 4, 2014 That's not good. Good you caught it before anything bad happened ... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Merc6 Posted November 5, 2014 Share Posted November 5, 2014 you replace it with a stock one? 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
boostedsubbygt Posted November 6, 2014 Author Share Posted November 6, 2014 Ya I didn't know if it was the sensor. I had it towed to a Subaru mechanic and they replaced it with a stock part. The original lasted 114800 miles Link to comment Share on other sites More sharing options...
Max Capacity Posted November 6, 2014 Share Posted November 6, 2014 Can you look in the inside of the drivers door and give us the build date ? I'm still on the OEM pick up with 197,000 miles. Mine was built May 2004. My thought is the late 2005 to mid 2006 build dates had the issue. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boostedsubbygt Posted November 6, 2014 Author Share Posted November 6, 2014 05/06 Link to comment Share on other sites More sharing options...
syngen smythe Posted November 9, 2014 Share Posted November 9, 2014 My oil pick up tube is cracked. Wow explain s the oil issue Why would a cracked tube increase consumption? I understand how it could kill your engine, but how does it make the oil go away? Link to comment Share on other sites More sharing options...
boostedsubbygt Posted November 9, 2014 Author Share Posted November 9, 2014 I'm going to continue to monitor my oil level but this issue did make my oil light come on due to pressure loss. Link to comment Share on other sites More sharing options...
snow05gtRI Posted November 10, 2014 Share Posted November 10, 2014 Why would a cracked tube increase consumption? I understand how it could kill your engine, but how does it make the oil go away? leaks out crack? Link to comment Share on other sites More sharing options...
MrTris Posted November 10, 2014 Share Posted November 10, 2014 leaks out crack? Right, but, he's saying it leaks out the crack in the pickup and right back into the pan. So, technically, it's a zero-loss and the oil light is coming on because it's not reading any pressure, though, unlike in most cases, it's not due to lack of available oil. Link to comment Share on other sites More sharing options...
doobaruGT Posted November 10, 2014 Share Posted November 10, 2014 Wondering if I have this issue. I'm losing a quart/1k also, which isn't bad, but still more than I would like to see. Didn't some folks have some luck with conventional? I have a newer PCV and AOS. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
MrTris Posted November 10, 2014 Share Posted November 10, 2014 Wondering if I have this issue. I'm losing a quart/1k also, which isn't bad, but still more than I would like to see. Didn't some folks have some luck with conventional? I have a newer PCV and AOS. Anything in your catchcan? How often are you emptying it? Link to comment Share on other sites More sharing options...
doobaruGT Posted November 10, 2014 Share Posted November 10, 2014 Anything in your catchcan? How often are you emptying it? Should have mentioned it's the GS one so no catch can. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
MrTris Posted November 10, 2014 Share Posted November 10, 2014 Should have mentioned it's the GS one so no catch can. I would just take it out. They're garbage, unfortunately. Link to comment Share on other sites More sharing options...
