Benjamin M Posted June 4, 2014 Author Share Posted June 4, 2014 http://img.tapatalk.com/d/14/06/05/y5aqatyp.jpg http://img.tapatalk.com/d/14/06/05/y5yhemuz.jpg http://img.tapatalk.com/d/14/06/05/ydagasyb.jpg Sold it on the spot......jk. Got it over to the transmission shop. Had a peek at the clutch slave cylinder, it seemed to check out. We roll started it and he attempted to disengage the clutch by driving up to 3k-4k rpm and depressing the clutch, but no luck with that. He showed me how to shift sans clutch, that was neat. Took it back to the shop and they are going look into it and hopefully have something by the end of Friday. The shop owner was nice enough to give me a lift to the rental company since they backed out on their pick up service. Fingers crossed! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ehsnils Posted June 5, 2014 Share Posted June 5, 2014 If they break it apart it may be worth it to install a new clutch. A jammed pilot bearing can be enough for this kind of trouble - as well as the clutch plate stuck to the flywheel, which can be a bitch to break off if it happens. Link to comment Share on other sites More sharing options...
Benjamin M Posted June 5, 2014 Author Share Posted June 5, 2014 If they break it apart it may be worth it to install a new clutch. A jammed pilot bearing can be enough for this kind of trouble - as well as the clutch plate stuck to the flywheel, which can be a bitch to break off if it happens. Don't bring that bad ju-ju in here!!! But really, hoping for the best, planning for the worst. The whole clutch, pressure plate, flywheel, TOB assembly was installed sept. Of '13. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Free Range Racing Posted June 5, 2014 Share Posted June 5, 2014 I'm putting money on broken clutch rivets on one shoe, or a broken off section of shoe, wedged between the clutch and either flywheel or pressure plate. But..you know... totally guessing. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 5, 2014 Share Posted June 5, 2014 Agree ^ What clutch is it ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 5, 2014 Moderators Share Posted June 5, 2014 Agree ^ What clutch is it ? Take a wild guess. It's a CM FX350 I believe. Not surprised it's giving issue "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Underdog Posted June 5, 2014 Share Posted June 5, 2014 FX350 as stated in OP. Car had no clutch issues prior to sitting for two weeks. Symptoms are not consistent with early-wear as reported by a rash of other FX350 owners recently. I would think if a pad was thrown from the clutch disc it would have occurred en route and would have been immediately noticed. Hard to imagine the pad "dropped" while sitting parked, with the friction disc sandwiched between the PP and FW. The Crimson Dynamo Link to comment Share on other sites More sharing options...
GTEASER Posted June 5, 2014 Share Posted June 5, 2014 I'm putting my money on the clutch fork. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Underdog Posted June 5, 2014 Share Posted June 5, 2014 Possible. It's something we discussed, and the fact that it has minimal play is not conclusive. Still though, you'd think there would have been some indicator when it failed. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 5, 2014 Moderators Share Posted June 5, 2014 Can't you get enough of a visual on the clutch fork form the inspection hole or whatever it is to confirm that / rule it out? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Underdog Posted June 5, 2014 Share Posted June 5, 2014 I'm about 1,500 miles from the OP. I had him grab the exposed end and see how much play was there and from what he said it sounded normal. We talked about pulling that little boot but he felt better just having it towed to a shop. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Max Capacity Posted June 5, 2014 Share Posted June 5, 2014 Sorry I missed that. Must be my age... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 9, 2014 Moderators Share Posted June 9, 2014 Bump. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Benjamin M Posted June 10, 2014 Author Share Posted June 10, 2014 Sorry guys for the delay, I've been in New Orleans for a bachelor party and some since Wednesday evening....wow. Picked the wagon up today, shifts like a champ. The mechanic said that he did or attempted to actuate the slave cylinder in the bay for the clutch, but that didn't prove effective after going for another drive and trying to break it loose. Let it sit overnight, next morning took the car out again and the clutch started working again. That's really all he could offer. When I was with him, we would drive in 1st and pump the clutch. I had passed on to him some advice that Rick had given me to brake hard while in 1st with the clutch pedal out. I'm not sure if he attempted this or not. But it seems that continual driving and and working the clutch was able to get it "unstuck". Didn't even charge me! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
