Blackbeard Posted June 22, 2021 Share Posted June 22, 2021 Attempted meating... 2005 LGT 245/35/18 Pirelli PZero - published specs are 9.8 section width, 24.8 diameter 18x8 +48 (or 45?) TSW Nurburgring 3 degrees front camber (Mooresport top hats, Tokico struts) 2 degrees rear camber (Whiteline rear links) Moderate fender roll/pull all around. The pull up front was completely unnecessary (due to camber) and I'm not sure any was needed in the rear either. It drives great, but it came out less meaty than I had hoped. When these tires wear out I'm either going to try 255/35/18 (I think there's room, but might need a couple mm of spacer) or coilovers and 255/40/18. Or maybe just a wider 245/35. Well see. Can we see a side profile shot please. I'm currently running 235/40/18 with a 44 offset they're just meaty enought for my liking. I'll grab some images to post up in a bit. And just like yours, I didn't need to roll the front, so I didn't. But rears scrubbed like crazy, had to roll those. I was I would paid attention and rolled them first, I've never done it before and had to wait for the roller to arrive. Unfortunately my rear tires paid the price. Link to comment Share on other sites More sharing options...
Blackbeard Posted July 15, 2021 Share Posted July 15, 2021 (edited) After getting use to them, they aren't as chunky imo anymore. Especially after a little rolling an a good alignment. Edited July 15, 2021 by Blackbeard links Link to comment Share on other sites More sharing options...
Febreze Mee Posted July 15, 2021 Share Posted July 15, 2021 Attempted meating... 2005 LGT 245/35/18 Pirelli PZero - published specs are 9.8 section width, 24.8 diameter 18x8 +48 (or 45?) TSW Nurburgring 3 degrees front camber (Mooresport top hats, Tokico struts) 2 degrees rear camber (Whiteline rear links) Moderate fender roll/pull all around. The pull up front was completely unnecessary (due to camber) and I'm not sure any was needed in the rear either. It drives great, but it came out less meaty than I had hoped. When these tires wear out I'm either going to try 255/35/18 (I think there's room, but might need a couple mm of spacer) or coilovers and 255/40/18. Or maybe just a wider 245/35. Well see. I would also like a ton more pictures of this setup! I keep bouncing back and forth between re-wrapping my RPF1s (18x8") in 235/40's or bumping it up to 245/35's. Help! MILKRUN - Click Here Link to comment Share on other sites More sharing options...
Blink Posted July 25, 2021 Share Posted July 25, 2021 255/35/18 Hankook V12s on 18x8 +48 with a 12mm spacer for rears. Very slight fender roll required. Fronts fit just fine with no rubbing. The 255's on 18x8 are slightly pinched and therefore aren't noticeably wider than 245's. You really need 8.5" or wider rims to get the full effect of the larger tire. Link to comment Share on other sites More sharing options...
boxkita Posted July 25, 2021 Share Posted July 25, 2021 275's fit on front. not so much on rear Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Code Posted July 25, 2021 Share Posted July 25, 2021 99% I’m replacing my 245/40/18 z2 with 245/35/18 mp4s. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
seanyb505 Posted July 25, 2021 Share Posted July 25, 2021 Great tire. Link to comment Share on other sites More sharing options...
NORULZleggy Posted August 12, 2021 Share Posted August 12, 2021 Question, i just got a set of Enkie TS-5 wheels they are 17x8 +45. I want to know if I can run a 235/45/17 or should I do a 225/45/17? I a lowered just a tab bit you can still see some gap. I am running Enkie TS-10s they are 18x8 with a 225/40/18 and have not problems. I know my stock wheels are 225/45/17. can I go 235s? Link to comment Share on other sites More sharing options...
rhino6303 Posted August 12, 2021 Share Posted August 12, 2021 Question, i just got a set of Enkie TS-5 wheels they are 17x8 +45. I want to know if I can run a 235/45/17 or should I do a 225/45/17? I a lowered just a tab bit you can still see some gap. I am running Enkie TS-10s they are 18x8 with a 225/40/18 and have not problems. I know my stock wheels are 225/45/17. can I go 235s?I run 245/40/17 on my LGT sedan on enkei pf01 17x8 +45. I find they fit nicer than 235/45/17 tires. I felt the 235/45 was just a little too tall. Link to comment Share on other sites More sharing options...
shralp Posted August 12, 2021 Share Posted August 12, 2021 I'd also suggest a 235/40 as well. Fitment is great in a 17x8 for our platform Link to comment Share on other sites More sharing options...
boxkita Posted August 12, 2021 Share Posted August 12, 2021 if you can find a 235/40 tire, they are very firm so you get good handling Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
NORULZleggy Posted August 12, 2021 Share Posted August 12, 2021 if you can find a 235/40 tire, they are very firm so you get good handling Dang I guess a 235/40 it will be I am looking at DWS06 tires also. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted August 12, 2021 Share Posted August 12, 2021 Get some real tires! EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
seanyb505 Posted August 12, 2021 Share Posted August 12, 2021 I thought 215/45/17 was the stock size. I've got about the same wheel dimensions, and I run 245/40 Michelin ps4as. Same height, just wider. I think it's probably a bit too fluffy for my driving purposes, but I wanted to see how it looked. It's still a really good tire for spirited daily driving, I'll probably go back to stock or 225/45 for the next set depending on price. I thought 235/40 were fewer in choice and more track based compounds. Link to comment Share on other sites More sharing options...
Infosecdad Posted August 13, 2021 Share Posted August 13, 2021 I thought 215/45/17 was the stock size. I've got about the same wheel dimensions, and I run 245/40 Michelin ps4as. Same height, just wider. I think it's probably a bit too fluffy for my driving purposes, but I wanted to see how it looked. It's still a really good tire for spirited daily driving, I'll probably go back to stock or 225/45 for the next set depending on price. I thought 235/40 were fewer in choice and more track based compounds. 215/45/17 is stock for us. I'm running 225/45/17 PS4AS and love them. Link to comment Share on other sites More sharing options...
boxkita Posted August 13, 2021 Share Posted August 13, 2021 (edited) 225 on an 8" rim is "most correct". more section width (the 225 number) doesn't mean more tread. tread width (typically found on tire rack site only idky) is what you should actually care about. Although the smaller the difference between the tread width and the section width, the better the handling should be, all other variables being equal. The closer you get to a race tire, the stiffer the sidewall. Sidewall stiffness overcomes alot of issues. And makes for a harsher ride. These are touring sedans not sportscars. blah, blah Edited August 13, 2021 by boxkita Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
seanyb505 Posted August 13, 2021 Share Posted August 13, 2021 Maybe the sedans... Wagons are a different story as I'm sure you're well aware lol Link to comment Share on other sites More sharing options...
Cincy05LGT Posted August 13, 2021 Share Posted August 13, 2021 Here's my meat. 245/40R17 RE71R on 17x9 et45 RPF1's. They needed every mm of inboard room the coilovers provided, and a good fender roll. Recently lifted about 0.5" for autox and track. Required for kerbs and elevation change at Mid Ohio on 7k springs... Link to comment Share on other sites More sharing options...
YourConfused Posted August 16, 2021 Share Posted August 16, 2021 Looks great! I have 255's on 18x8.5 et45 that I'm trying to make fit. I think i may need some top hat spacers and quite a bit of a fender roll though. How close are you to stock ride height after you raised it half an inch? Thanks Here's my meat. 245/40R17 RE71R on 17x9 et45 RPF1's. They needed every mm of inboard room the coilovers provided, and a good fender roll. Recently lifted about 0.5" for autox and track. Required for kerbs and elevation change at Mid Ohio on 7k springs... Link to comment Share on other sites More sharing options...
NORULZleggy Posted August 17, 2021 Share Posted August 17, 2021 225 on an 8" rim is "most correct". more section width (the 225 number) doesn't mean more tread. tread width (typically found on tire rack site only idky) is what you should actually care about. Although the smaller the difference between the tread width and the section width, the better the handling should be, all other variables being equal. The closer you get to a race tire, the stiffer the sidewall. Sidewall stiffness overcomes alot of issues. And makes for a harsher ride. These are touring sedans not sportscars. blah, blah So just to make things clear I am not looking for a crazy race tire. I need a nice all season, and DWS06 is great. Also there are not many choices to choose from when you get to 235/40/17. 225 might be the way. Link to comment Share on other sites More sharing options...
NORULZleggy Posted August 25, 2021 Share Posted August 25, 2021 So just to make things clear I am not looking for a crazy race tire. I need a nice all season, and DWS06 is great. Also there are not many choices to choose from when you get to 235/40/17. 225 might be the way. So I cannot find a 235/40 all season tire. so I am looking at a 225/45 tire for winter. I know it might be tall a bit, but My car is not lowered like other, I am not into the low life. Link to comment Share on other sites More sharing options...
NORULZleggy Posted August 25, 2021 Share Posted August 25, 2021 215/45/17 is stock for us. I'm running 225/45/17 PS4AS and love them. I am going to run these, I decided on. Thanks Link to comment Share on other sites More sharing options...
seanyb505 Posted August 25, 2021 Share Posted August 25, 2021 Very good tire. They probably won't throw you out of the seat, but they're definitely surprising. Link to comment Share on other sites More sharing options...
NORULZleggy Posted August 25, 2021 Share Posted August 25, 2021 Very good tire. They probably won't throw you out of the seat, but they're definitely surprising. Yeah, My car sits is a nice garage 4-5 days a week, so I just want to take it out in the cold winter ish days. It will not see snow. My 13 legacy has blizzaks on it so It get beat on. If I don't drive that, it the daily. Link to comment Share on other sites More sharing options...
KevinEdgar Posted October 21, 2021 Share Posted October 21, 2021 265/35/18 Bridgestone pole position S04 on Volk TE37SL 18x9.5 +45 with 20mm spacer for inner clearance. 4 fenders rolled/pulled, these photos are before fortune auto 500 10k/8k install and corner balance/alignment. alignment specs: LF: Camber -2.1 Toe 0 RF: Camber -2.2 Toe 0 LR: Camber -2.3 Toe - 1/32 LR: Camber -2-6 Toe -1/32 I don't have the corner balance sheet on me right now. Link to comment Share on other sites More sharing options...
