garygbnj Posted February 2, 2014 Share Posted February 2, 2014 Purchased new in late 05. Always in a semi heated garage. Following rust issues. Trunk lid at bottom edge (adjacent to bumper). Drivers side frt and rear doors at bottom edge. Body shop cleaned what they could and sprayed in a rust inhibiting material. They stated "it may or may not stop the rust". I am in northwest NJ. Is this a common issue or is it atypical? I love the car and plan to keep it forever (if that is feasible). The color is satin white pearl. Should I be looking to buy used doors and a trunk lid now while there is a plentiful number of parts available? If so should I be looking for parts only from a dry climate? Would it be ridiculous for me to look for the parts only in sating pearl white? thanks gary Link to comment Share on other sites More sharing options...
boostgt2 Posted February 2, 2014 Share Posted February 2, 2014 Most likely moisture is getting it somewhere behind the surface. Only way to completely get rid of it is to grind or cut it out prime and paint. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 3, 2014 Share Posted February 3, 2014 My 05 has no visible rust in those area's, never been in a garage. The only rust I had was around the windshield from having it replaced a number of times. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LongHiway Posted February 3, 2014 Share Posted February 3, 2014 I'm starting to see rust along the bottom edge on the inside of the driver's side door. Think the window molding is leaking. That's bad. Link to comment Share on other sites More sharing options...
snow05gtRI Posted February 3, 2014 Share Posted February 3, 2014 My 05 has no visible rust in those area's, never been in a garage. The only rust I had was around the windshield from having it replaced a number of times. I've got rust on the roof along the top edge of the windshield. Did you do anything to fix it, or just leave it? Link to comment Share on other sites More sharing options...
Holla Posted February 4, 2014 Share Posted February 4, 2014 I always thought that having a heated garage sped up the rusting process. When you drive your car through the snow and salt and then park it in a heated garage you're essentially giving it a salt water bath everyday. Warmer temperatures will also accelerate the rusting process. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2014 Share Posted February 4, 2014 I've got rust on the roof along the top edge of the windshield. Did you do anything to fix it, or just leave it? Yes I did. I had my buddies restoration shop strip the front bumper, hood and roof, pull the windshield fix the rust and paint those area's. I posted pictures after it was done last Oct. Here's a after shoot, I don't have a shoot of the rust but I do have one of the stone chips, this is a edit, so the pictures may be out of order. http://i185.photobucket.com/albums/x40/92Si/DSCN4801.jpg http://i185.photobucket.com/albums/x40/92Si/DSCN5333_zpsa10312c3.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
instantfury Posted February 4, 2014 Share Posted February 4, 2014 I have the same issue, except mine was never garaged. It's a pretty decent amount, too. Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted February 4, 2014 Share Posted February 4, 2014 I've got rust on the roof along the top edge of the windshield. Did you do anything to fix it, or just leave it? fix it asap! mine got so bad it was leaking water through the edge of the windshield. Had a shop do ALOT of work to fix it. Involves pulling windshield(which will most likely shatter on removal so you will need another one for about $600.) Then depending how bad it is they either cut out metal and weld new metal in, or grind all the rust off, apply rust inhibitor, and repaint the area. Costs anywhere from 2000-5000 dollars to get fixed right. Link to comment Share on other sites More sharing options...
silen7guardian Posted February 4, 2014 Share Posted February 4, 2014 Sorry for being off-topic, but at first I read the title as "06 LGT Lust Issues" which would have been understandable. Uh, I mean, I wouldn't know anything about LGT lust issues... Link to comment Share on other sites More sharing options...
snow05gtRI Posted February 4, 2014 Share Posted February 4, 2014 fix it asap! mine got so bad it was leaking water through the edge of the windshield. Had a shop do ALOT of work to fix it. Involves pulling windshield(which will most likely shatter on removal so you will need another one for about $600.) Then depending how bad it is they either cut out metal and weld new metal in, or grind all the rust off, apply rust inhibitor, and repaint the area. Costs anywhere from 2000-5000 dollars to get fixed right. $2k to $5k? Good god... I can see how it could add up... but.. damn. If I can get to it I'll post a pic of the rust spot for you to compare. Yes I did. I had my buddies restoration shop strip the front bumper, hood and roof, pull the windshield fix the rust and paint those area's. I posted pictures after it was done last Oct. was your fix any where close to that? Link to comment Share on other sites More sharing options...
Bbc84 Posted February 5, 2014 Share Posted February 5, 2014 I'm starting to see rust along the bottom edge on the inside of the driver's side door. Think the window molding is leaking. That's bad. I have that on my 05' wagon, how do I fix or stop that from getting worse? Link to comment Share on other sites More sharing options...
rob-2 Posted February 5, 2014 Share Posted February 5, 2014 I have that on my 05' wagon, how do I fix or stop that from getting worse? You have to cut rust out to stop it. Link to comment Share on other sites More sharing options...
LongHiway Posted February 5, 2014 Share Posted February 5, 2014 You have to cut rust out to stop it. Replace the molding & hope for the best? Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted February 6, 2014 Share Posted February 6, 2014 $2k to $5k? Good god... I can see how it could add up... but.. damn. If I can get to it I'll post a pic of the rust spot for you to compare. was your fix any where close to that? Mine was bubbling on driver corner near roof, and in the middle of the windshield on the roof. It didnt look bad, but I already started leaking water around the a-pillar. Its always worse under the molding vs what you can actually see. Also take into account, alot of shops DO NOT want to do the job. Luckily I had the dealership split on the price with me and we used their shop for about a 2000 dollar fix. I have that on my 05' wagon, how do I fix or stop that from getting worse? only way is to grind it off and cover it. But if you can already see it, then you rusted ALOT more under the actual windshield. Replace the molding & hope for the best? molding is installed on glass, then glass is installed into car. Link to comment Share on other sites More sharing options...
