ipekur Posted January 22, 2014 Share Posted January 22, 2014 I know this topic was touched couple of times. But what is the best air filter for the turbo engine. Turbo needs substantially more air flow than the regular engine. All the regular Legacy filters will fit, but most of them do not have enough airflow to supply to the turbo. Any advice will be great! (Except K&A - it is oiled and from what I read doesn't provide enough air) Link to comment Share on other sites More sharing options...
Nubie Posted January 22, 2014 Share Posted January 22, 2014 The best air filter for a turbo is a clean filter. That is all. Link to comment Share on other sites More sharing options...
Nubie Posted January 22, 2014 Share Posted January 22, 2014 Unless your going for high horsepower than you are incorrect, the "regular" legacy filters do allow enough air through. A KnN doesn't provide enough air when cleaned improperly, many people add too much oil, this is what causes a restriction in air flow, not the design of the filter. Link to comment Share on other sites More sharing options...
KCwagon Posted January 22, 2014 Share Posted January 22, 2014 I know this topic was touched couple of times. But what is the best air filter for the turbo engine. Turbo needs substantially more air flow than the regular engine. All the regular Legacy filters will fit, but most of them do not have enough airflow to supply to the turbo. Any advice will be great! (Except K&A - it is oiled and from what I read doesn't provide enough air) My advice would be to read more and type less Link to comment Share on other sites More sharing options...
ipekur Posted January 22, 2014 Author Share Posted January 22, 2014 It goes without saying that clean air filter is the best. and for "My advice would be to read more and type less" - no comments, but I can assure you that if I type less - most people will answer wrong question, and If I read more - I would not have time to enjoy the car. I am not newbie to this at all. I know that because of the oil and silicone K&n filters do not let as much air as others comparable dry filters, also statement that all filters let the same amount of air could not be farther from the truth. Fram creates much more resistance than Beck and Arley, and wick and so on.... Link to comment Share on other sites More sharing options...
nouse4aname Posted January 22, 2014 Share Posted January 22, 2014 And that can be a concern on most other cars. Air intake just isn't a bottleneck on these cars until you are way above stock power. Link to comment Share on other sites More sharing options...
Danteneon Posted January 22, 2014 Share Posted January 22, 2014 Here is something you may want to consider...the factory # for the 06 air filter is 16546AA10A. The later turbo and 6 cyl models use part # 16546AA12A which has a higher flow. Switch to the 12A filter and you should be fine until you exceed 350whp. http://www.swagparts.com/media/00/a2079171355e62b1512aba_m.JPG http://www.swagparts.com/media/00/a2079171355e62b7c6dba4_m.JPG I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
Nubie Posted January 22, 2014 Share Posted January 22, 2014 They dont all flow the same but the differences are small and do not matter to a stock car. The BEST air filter for your STOCK car is the one that Subaru engineers spent countless hours deciding was needed. If you are worried that it is not enough and you are sure that Beck and Arley and Wick are better than what else do you need to know? Run one of those. Link to comment Share on other sites More sharing options...
Berzerklo Posted January 22, 2014 Share Posted January 22, 2014 I believe AVO makes a dry filter. I have heard that you may want to consider a tune for a high-flow filter - especially if you are in high altitudes like Denver. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 22, 2014 Moderators Share Posted January 22, 2014 I have an aFe Pro Dry S that I'm not using--didn't agree with my airbox for whatever reason so I went back to stock. I used a similar filter on my last car and it was great--for this car it doesn't seem that the airbox seals properly with it. Anyway, if you want it I'd sell it pretty cheap. Basically new "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
chato Posted January 22, 2014 Share Posted January 22, 2014 yeah, I had a avo dry filter and my AF learning was all over the place. it also didn't fit in the box correctly, there was a small leak at the bottom which caused some turbulence that I think messed with the MAF. a word of general advice about these cars: the usual things that make for better performance and power (intake, exhaust etc) don't really come into play till you start bolting on giant turbos. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 22, 2014 Moderators Share Posted January 22, 2014 yeah, I had a avo dry filter and my AF learning was all over the place. it also didn't fit in the box correctly, there was a small leak at the bottom which caused some turbulence that I think messed with the MAF. a word of general advice about these cars: the usual things that make for better performance and power (intake, exhaust etc) don't really come into play till you start bolting on giant turbos. Yeah, it's odd. I had one on the old LGT and was tuned for it w/ stage 2--no issues. This new one on the OBXT ended up with my a/f trims adding fuel, I'm guessing to compensate for un-metered air. Similar mods, different results "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Chris GTO TT Posted January 22, 2014 Share Posted January 22, 2014 I have an aFe Pro Dry S that I'm not using--didn't agree with my airbox for whatever reason so I went back to stock. I used a similar filter on my last car and it was great--for this car it doesn't seem that the airbox seals properly with it. Anyway, if you want it I'd sell it pretty cheap. Basically new I had that same problem with my aFe Pro Dry S filter, AF adjustments were all over the place so i threw in a WIX filter and poof all stable again. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
apexi Posted January 22, 2014 Share Posted January 22, 2014 I don't have a turbo, but I use an aem dryflow that seems to fit my airbox nicely. I actually had issues in the past with aftermarket paper filters not fitting properly, which is why I went with the AEM to begin with. I went into a little more detail in the post below. http://legacygt.com/forums/showpost.php?p=4074362&postcount=3 Link to comment Share on other sites More sharing options...
GTEASER Posted January 22, 2014 Share Posted January 22, 2014 I'm running AEM Dryflow as well with no issues. Flames shoot out of my exhaust now. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 22, 2014 Share Posted January 22, 2014 I'm running AEM Dryflow as well with no issues. Flames shoot out of my exhaust now. Damn ! ! You GROOVE ! ! Link to comment Share on other sites More sharing options...
GTEASER Posted January 22, 2014 Share Posted January 22, 2014 Damn Straight!! See....if they show that it does, then its true. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 23, 2014 Share Posted January 23, 2014 Damn Straight!! See....if they show that it does, then its true. Pics or it didn't happen....and you have pics....but NOT of your car...LOL Link to comment Share on other sites More sharing options...
cww Posted January 23, 2014 Share Posted January 23, 2014 I am also running an AEM Dryflow panel filter and can confirm that it transformed my car into a Porsche 911 Turbo, as advertised on the package. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted January 23, 2014 Share Posted January 23, 2014 They dont all flow the same but the differences are small and do not matter to a stock car. The BEST air filter for your STOCK car is the one that Subaru engineers spent countless hours deciding was needed. If you are worried that it is not enough and you are sure that Beck and Arley and Wick are better than what else do you need to know? Run one of those. I agree that the stock/recommended air filter for a NA is perfectly fine. However I disagree that there's no benefit to upgrading to the filter intended for the 6 cyl and turbo cars. Sure it flows more air and this may not be necessary in a NA car, however it'll have larger surface area of filter media and a longer service life because of this. Link to comment Share on other sites More sharing options...
Danteneon Posted January 23, 2014 Share Posted January 23, 2014 I agree that the stock/recommended air filter for a NA is perfectly fine. However I disagree that there's no benefit to upgrading to the filter intended for the 6 cyl and turbo cars. Sure it flows more air and this may not be necessary in a NA car, however it'll have larger surface area of filter media and a longer service life because of this. Keep in mind, according to the OP's profile info, he has a LGT. The 12A filter wasn't listed back then. Starting in 2007 the 12A was the proper filter to use in the LGT. So if he has been using the 10A up to this point, the 12A is an upgrade. But in the end, the filter really isn't going to make any real difference. Unless you use the flamethrower AEM that is. I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted January 24, 2014 Share Posted January 24, 2014 I don't think my humble car is worthy of AEM. Link to comment Share on other sites More sharing options...
Dispatch20 Posted March 10, 2015 Share Posted March 10, 2015 I have an aFe Pro Dry S that I'm not using--didn't agree with my airbox for whatever reason so I went back to stock. I used a similar filter on my last car and it was great--for this car it doesn't seem that the airbox seals properly with it. Anyway, if you want it I'd sell it pretty cheap. Basically new I was wondering how so dust and debris got into my inlet, TMIC, throttle body hose (and presumably into the engine). When I took apart off these parts to replace the turbo, I couldn't explain why dirt pieces could get past the filter. When I was cleaning the MAF tonight, I noticed the aFe pro dry air filter didn't fit the air box properly. Dirty air was getting past the filter. The "clean" part of the airbox shouldn't be dusty. I think hicksta had this on his car for 30k miles. I'm not super happy right now. :spin: Link to comment Share on other sites More sharing options...
Merc6 Posted March 10, 2015 Share Posted March 10, 2015 K&N also filters less and Chrysler were voiding warranties if you had one installed due to turbo dusting. Don't think anyone here is under factory warranty still if that is a deciding factor. I'm going back to my AEM filter when Humpty Dumpty is back together again. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted March 10, 2015 Share Posted March 10, 2015 I finally replaced my 10y/o Perrin panel filter in my 05 wagon with a K&N like I put in my 09 Spec B. The Perrin was installed Aug 2004. Never had any issue with lack of air flow. Even when the filter was dirty. I clean them once a year, then lightly oil them. I thinks you guy's are making way to much of this. BTW Yesterday I pulled the MAF sensor on the wagon to clean for the first time in 16 month's. Sprayed it with maf cleaner, tapped it on the clean white cloth, nothing came out, it was clean. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
