0-60 mph
Posted
Correct me if I'm wrong, but I thought 2nd Gear pulled you to 60mph? My car just doesn't feel fast. I have to go to 3rd to hit 60mph. Is that normal?:confused:
Posted
Guess this must really be a dumb question.. My car was driven on wastegate pressure for a long time. ..and after finally getting it tuned I've forgotten what it feels like to conduct spirited driving. As such....I couldn't remember if I was able to reach 60 in second gear. But it's ok...I've searched. Will go to other forums and search some more.
Sent from my SCH-I535 using Tapatalk
Posted
whats a speed shift
Keeping the revs higher then the next gear would normally require. And shifting hard into the next gear.
IE failing to let the revs drop going from 3rd to 4th. The 'extra' power is slammed through the clutch and into the wheels.
Posted
Read about "full throttle shift" on Cobb AP.
The AP can set the rev limit and keep the engine safe while you shift.
Either way, with trannys made of glass, its not a good idea, IMO.
There are other options you can program in to other systems like Motec and AEM that will keep the turbo spooled and give a soft engagement into the next gear while you "flat foot shift" too. For inquiring minds you can research it.
But yes, my wagon will hit 60 in 2nd gear very easily. Makes passing people on the backroads real easy. Did it yesterday, its amazing how quick the car in that gear.
Engine Build - Click Here
Posted
Oh yea, ^ that too. I did notice the tech at about 7300rpm in 1st yeaterday.
Posted
Thanks guys...I had a wrx before and that seemed to have gotten up there in second gear. Now... I'm tuned. . But by second..rpms are up there,engine is screaming but speedo is barely climbing above 45. I'm not saying this is necessary though. At regular speeds...the car performs well. 65-100 is a breeze and torque throughtout the powerband is phenomenal. So I was just trying to figure if it was a tune thing or if clutch was unable to keep up...thanks for the responses chaps.
Posted
slipping clutch?
Posted
From the factory, it needs to be in 3rd to hit 60. With a tune and raised rev limit, 60 is attainable in 2nd, which is why 0-60 times drop so much between stock and stg 1.
Negative. A2WC522N stock ROM shows rev limiter at 6700 which brings you to just about 63.42 on stock 215/45 17 wheels.
Posted
wasn't paying attention but I was wanting to pass a bunch of slow assholes on the highway on ramp that dont know how to drive and got to 80 without shifting to 3rd but I may be wrong
Posted
auto to 5mt comparison? 80mph in 2nd gear isn't going to happen in a 5mt, no matter what tune you run.
At redline, I get 63 in 2nd. 3rd is about 95. It pulls hard all the way, however, the tune is very specific to allow for that.
Posted
The rom can say whatever it wants. My car hit the rev limit at 6500, as does everyone else's stock GT 5MT. :lol:
Posted
6500 is still enough, JUST. Brings you to abou t61MPH. I suppose with worn tires and tire variations and whatnot, it'd be pretty close. :)
Posted
^Invar, I believe you have a video on YouTube showing your acceleration to 60. Sounds like it was achieved in second gear, am I right?
Posted
Dude...I'm protuned with a vf52, running 17psi; catless up and down etc. So guess that'll be stage 2.5, something is defintely wrong...clutch must me on the way out.
Posted
You're a stage 3... aftermarket turbo. Hmm. Well, you can tell your clutch is on the way out if you're in 4th gear and say, 2500 and floor it and watch what happens as your boost builds. If the RPMs suddenly shoot up, it's slipping.
Posted
Strangely. .when I try that no issues. No sign of slippage. Hmmmm...the plot thickens
Posted
Well, here's a breakdown:
At 6000 RPM, your speed in 1st should be 33.7MPH. 2nd is 56.8MPH. 3rd is 82.5MPH.
So you don't have to be accelerating, but if you bring your engine up to 6K in those gears and just let off the throttle, you should be at those speeds while the car rapidly decelerates from engine braking.
Since you're not accelerating, you can pretty much eliminate the clutch slipping as a possibility.
