RuskiTrombone Posted July 27, 2013 Share Posted July 27, 2013 TATS deli in Seattle. Made with real Russian dressing! http://www.seriouseats.com/images/2012/08/080712-217761-TatsDeli-Tatstrami-Small.JPG Wow, I had no idea my dressing made its way to the west coast. Link to comment Share on other sites More sharing options...
RuskiTrombone Posted July 27, 2013 Share Posted July 27, 2013 Anyone want to race eating a sandwich? I'd beat anyone in CO or in the entire Amurrica. In a sandwich eating race. Link to comment Share on other sites More sharing options...
Nubie Posted July 27, 2013 Share Posted July 27, 2013 Where are the restrictors located? It's right in the oil inlet if a ball bearing center section. Link to comment Share on other sites More sharing options...
Nubie Posted July 27, 2013 Share Posted July 27, 2013 I looked around online couldn't find a good picture but ill take a center section apart on Monday an show you exactly where it is. Link to comment Share on other sites More sharing options...
TheBlackPearl Posted July 27, 2013 Share Posted July 27, 2013 Anyone want to race eating a sandwich? I'm effin hungry now! Heading to Jimmy Johns for lunch FTMFW! I'm looking at about 4mins47secs and 51/100ths for a #17 Ultimate Porker sub. I took it easy since it was my first timed run, but I'm excited to get back there and try some new techniques before the summer is over. Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
RuskiTrombone Posted July 27, 2013 Share Posted July 27, 2013 I live my life a quarter sub at a time. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted July 27, 2013 I Donated Share Posted July 27, 2013 It's right in the oil inlet if a ball bearing center section. So in other words, not located in the lines? Link to comment Share on other sites More sharing options...
mwiener2 Posted July 28, 2013 Share Posted July 28, 2013 You know, there are bearings in the turbo, too... There is no hacking involved. The ball bearings of said turbo had exploded and fell through the drain tube, into the oil pan. I know for a fact oil starvation was NOT the cause of the failure. You're right, it's not hacking. It's precision machining removal of material to make it fit into a smaller housing. So in other words, not located in the lines? So replacing the lines does what? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted July 28, 2013 I Donated Share Posted July 28, 2013 So replacing the lines does what? Just because there is no restrctor that can be removed doesn't mean the lines aren't restrictive... Link to comment Share on other sites More sharing options...
mwiener2 Posted July 28, 2013 Share Posted July 28, 2013 If the restrictor isn't located in the lines, and you replace the lines, you are still restricted. You will not find a Subaru with a failed turbo that had too small of factory lines. Restricted lines from clogged filters and such, yes. But not because the lines themselves were too small. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted July 28, 2013 I Donated Share Posted July 28, 2013 If the restrictor isn't located in the lines, and you replace the lines, you are still restricted. Yes, but what if the lines themselves are the restriction? In that case, replacing the lines would get rid of the restriction. You will not find a Subaru with a failed turbo that had too small of factory lines. Restricted lines from clogged filters and such, yes. But not because the lines themselves were too small. For factory turbos, I'm sure you are right. I'm not so sure for aftermarket turbos. Link to comment Share on other sites More sharing options...
Nubie Posted July 28, 2013 Share Posted July 28, 2013 The oiling system is the same amongst all turbos, so it doesn't make a difference if its aftermarket, if it is twice as big, if its black or its blue, unless off course it's a ball bearing which requires even less oil. Link to comment Share on other sites More sharing options...
boxkita Posted July 28, 2013 Share Posted July 28, 2013 enough with the lines, already. I see people put race parts on their cars all the time and discuss how they can feel the difference on the drive home from the bar. If braided oil lines help you feel better about your turbo's continued life while engine rpm holds steady at 3000, good for you. I run stick hard lines on upgraded turbo, so far its been fine. Then again I run stock brake calipers on the track, so I don't hold much stock in race parts being the bomb. I do have an uprated oil pump with windage tray to encourage more oil to available to prevent the engine from exploding from not enough oil. OP was running the original pump with no oil delivery upgrades, something you would/should consider if you were going to drive your car in the upper 1000 of the rpm range. more sammich, less oil Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted July 28, 2013 Share Posted July 28, 2013 ^^^ gawddamed auto correct Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
WaspGT Posted July 28, 2013 Share Posted July 28, 2013 idk, he posted in open forum about racing. Didnt specify course. as he challenged, I'm open for an open road race point to point. Thinking pike's peak would work. At a drag strip? meh All you'll see is my tail lights, BoxKitty! Link to comment Share on other sites More sharing options...
Nubie Posted July 28, 2013 Share Posted July 28, 2013 more sammich, less oil Lets get this back on track http://www.totstoteensmagazine.com/wp-content/uploads/2011/08/peanut-butter-jelly-sandwich-lrg.png Link to comment Share on other sites More sharing options...
WaspGT Posted July 29, 2013 Share Posted July 29, 2013 MMH-MMMMM!!! good ol' PB&J:wub: Link to comment Share on other sites More sharing options...
laz Posted July 29, 2013 Share Posted July 29, 2013 How about a nice rib sandwich? http://i1243.photobucket.com/albums/gg548/deexboy/null_zps72a9cfa2.jpg X --- Link to comment Share on other sites More sharing options...
WaspGT Posted July 29, 2013 Share Posted July 29, 2013 Oh snap! Link to comment Share on other sites More sharing options...
JesseH Posted July 29, 2013 Share Posted July 29, 2013 Just had an amazing roast beef sandwich today..has RB, thousand island dressing, coleslaw, and swiss cheese, all on a nice long roll. Link to comment Share on other sites More sharing options...
LegGTLT Posted July 29, 2013 Share Posted July 29, 2013 I like Russian dressing more now... Please PM joeleodee For All Site Questions. He is the acting Admin and can resolve anything related to LegacyGT.com Link to comment Share on other sites More sharing options...
chimera Posted July 30, 2013 Share Posted July 30, 2013 From fast LGT's to sandwiches in less than 8 pages. http://www.seriouseats.com/images/20091214-grilledcheesetruck2.jpg Link to comment Share on other sites More sharing options...
RuskiTrombone Posted July 30, 2013 Share Posted July 30, 2013 I like Russian dressing more now... Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted July 30, 2013 Share Posted July 30, 2013 If these are sandwiches from the food trucks at the street race... count me in. Sent from a handheld device that can access the aggregate of human knowledge, but that I generally use to buy car parts and watch videos of people hurting themselves Tits mcgee Link to comment Share on other sites More sharing options...
laz Posted July 30, 2013 Share Posted July 30, 2013 http://xaxor.com/wp-content/uploads/2013/05/Crazy-sandwich-art4.jpg X --- Link to comment Share on other sites More sharing options...
