05wagongt Posted June 25, 2013 Share Posted June 25, 2013 i have no boost until i hit around 40 mph, and car bogs very heavily until 40 mph or so. im on my 3rd turbo and engine since dec. 2012. i only use premium gas i use rotella synthetic oil/oem filter i have cat-less up pipe, and did the egt sensor mod. i also removed banjo bolts on both sides. i checked to see if all vacuum hoses are connected, and they are. the intercooler and radiator are full of coolant i also checked oil when it was drained last time, and no debris in oil or shavings. what am i missing to check before i send my car back to the shop again for the 4th time in 6 months? i know turbo cars can be finicky, but this is past the point of annoying. Link to comment Share on other sites More sharing options...
johnAWD Posted June 25, 2013 Share Posted June 25, 2013 Check engine light? Have you pulled any codes from the ECU? The intercooler is full of coolant?!?! Link to comment Share on other sites More sharing options...
05wagongt Posted June 25, 2013 Author Share Posted June 25, 2013 no codes, no cel, yes the intercooler has coolant. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 25, 2013 Moderators Share Posted June 25, 2013 no codes, no cel, yes the intercooler has coolant. The intercooler should not have coolant in it. What are you referring to? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
bigBADbenny Posted June 25, 2013 Share Posted June 25, 2013 Dirty MAF? Logging it? Link to comment Share on other sites More sharing options...
05wagongt Posted June 25, 2013 Author Share Posted June 25, 2013 the tank next to the intercooler, it is full. Link to comment Share on other sites More sharing options...
05wagongt Posted June 25, 2013 Author Share Posted June 25, 2013 Dirty MAF? Logging it? have no way to log, maf is clean Link to comment Share on other sites More sharing options...
Tehnation Posted June 25, 2013 Share Posted June 25, 2013 Have you tuned the car? Is an uppipe required to have a tune? Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted June 25, 2013 Share Posted June 25, 2013 Not to sound rude but you just said the intercooler has coolant in it. Referring to the over flow tank on the pass side of the intake manifold. I would probably take this to a trained mechanic. And I recommend taking it to a different shop. If your not having luck at one place. Go some where else. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 25, 2013 Moderators Share Posted June 25, 2013 Not to sound rude but you just said the intercooler has coolant in it. Referring to the over flow tank on the pass side of the intake manifold. I would probably take this to a trained mechanic. Probably sound advice. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
johnAWD Posted June 25, 2013 Share Posted June 25, 2013 Not to sound rude but you just said the intercooler has coolant in it. Referring to the over flow tank on the pass side of the intake manifold. I would probably take this to a trained mechanic. And I recommend taking it to a different shop. If your not having luck at one place. Go some where else. Quoted for truth. Link to comment Share on other sites More sharing options...
subiestang Posted June 26, 2013 Share Posted June 26, 2013 When you say 3rd turbo and engine do you mean 3 turbos and 3 engines? Are replacing just the shortblock? Link to comment Share on other sites More sharing options...
subiestang Posted June 26, 2013 Share Posted June 26, 2013 5sp or auto? Link to comment Share on other sites More sharing options...
05wagongt Posted June 26, 2013 Author Share Posted June 26, 2013 3 long blocks and 3 new turbos.... Link to comment Share on other sites More sharing options...
subiestang Posted June 26, 2013 Share Posted June 26, 2013 Perhaps your problem lies in one of the parts you keep reusing. Boost control solenoid? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 26, 2013 Moderators Share Posted June 26, 2013 3 long blocks and 3 new turbos.... Was all of this under warranty or have you spent $20k on a car that's worth roughly $10k? With negative results...:eek: "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
05wagongt Posted June 26, 2013 Author Share Posted June 26, 2013 Was all of this under warranty or have you spent $20k on a car that's worth roughly $10k? With negative results...:eek: bought the car used with 47k in dec 2012, engine/turbo blew on way home from dealer. they replaced with a new motor, that had a 3 year warranty. that motor went again, and the turbo was a brand new one from subaru, and that was replaced again as well. i havent had to pay for the work, but its annoying Link to comment Share on other sites More sharing options...
