StringFellow Posted September 20, 2005 Share Posted September 20, 2005 AVO, cleanable, no oil to fowl your MAF. Just washed mine today Where did you get your AVO filter? Compared to the OEM paper, how does it look in terms of number and thickness of pleats? Is the AVO panel a Subaru part? -S Link to comment Share on other sites More sharing options...
sleepercell Posted October 30, 2015 Share Posted October 30, 2015 Can the afe pro air filter (paper reusable). Which doesn't need to be oiled like k n. Be used on a 07 lgt w. Turbo Link to comment Share on other sites More sharing options...
gmartinez1900 Posted October 30, 2015 Share Posted October 30, 2015 K&N dry flow filter... increase in MGP around 1mpg and can notice more throttle response slightly...Have about 1000 miles on it. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted November 2, 2015 Share Posted November 2, 2015 I'm gonna design a gadget to measure how low of pressure between the filter and intake manifold to determine how badly fowled the air cleaner is. Then I'll be rich. Paper filter here. There's an article online demonstrating just how poor of value reusable filters are in terms of airflow and performance. Link to comment Share on other sites More sharing options...
paul7ro Posted November 9, 2015 Share Posted November 9, 2015 To me, aftermarket air filters are pretty much the same in terms of functionality so just get the cheapest one. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted November 10, 2015 Share Posted November 10, 2015 Maybe its where I live, but air filters last an awfully long time around Toronto. In my experience K&N, and I suppose any "wet" style filter, is much more prone to clog throttle bodies and MAF sensors. Hence, I've been using paper ones for the last 15 years with no issues. Link to comment Share on other sites More sharing options...
Soarin Posted November 10, 2015 Share Posted November 10, 2015 I have an AEM DryFlow and zero problems with oil gumming up the MAF. You will have to take half of the airbox out to install or clean it. And clean the MAF while you're there. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 16, 2015 Share Posted November 16, 2015 Been using a Perrin in my wagon until about 2 years ago when it was 10 years old and looked a little aged. If you lightly oil the filter you ill not have any problem with fouling the MAF sensor. Both my cars have a K&N now. I clean the MAF's once a year when I clean the filters. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
sleepercell Posted November 16, 2015 Share Posted November 16, 2015 Thanx u for all the replys . I ended up purchasing afe pro power reusable paper filter.. I noticed a big improvement rite away.. Could jus be New filter but I would recommend it if u have the money Link to comment Share on other sites More sharing options...
