Max Capacity Posted December 28, 2023 Share Posted December 28, 2023 Here's the inside. Be careful with the push buttons, when you open the display, the rubbers tend to fall out. My old eye's are not good at seeing what's wrong here ? 2 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
kzr750r1 Posted February 24 Share Posted February 24 (edited) Yeah I had mine off as well. Hit the main connector terminal to just reflow the solder. Still no luck and lost one of the rubber mushrooms. In the meantime ordered another cubby from fleabay to see if it would make a difference. NOPE! I can slap it back into reading by hitting the dash just above cubby. Not hard... But hard enough at one point I guess cracked my old bezel. Water under the bridge at this point since the new fleabay unit is in really good shape. Time to inspect the wires. Need to tear into it any way at some point to replace all the air actuators. Edited February 24 by kzr750r1 Link to comment Share on other sites More sharing options...
