LGTwagon1993 Posted October 23, 2017 Share Posted October 23, 2017 Or get mucho JDM points and pick up one of these bad boys, Zero/Sports grounding kit & voltage stabilizer! Link to comment Share on other sites More sharing options...
JustCallMeNick Posted April 2, 2018 Share Posted April 2, 2018 I have a P0245 that I suspect to be related to a lack of effective grounding. That's what the problem was last time. The Perrin EBCS is only a year old so... That being said, I also haven't figured out how to test the solenoid with a multimeter. Good thread. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 3, 2018 Share Posted April 3, 2018 https://www.napaonline.com/en/p/TWEVEL058116 check those out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JustCallMeNick Posted April 3, 2018 Share Posted April 3, 2018 Thanks Max. I just replaced the drivers side one from frame to block but I haven't replaced the passenger side frame to exhaust ground yet. Link to comment Share on other sites More sharing options...
JustCallMeNick Posted April 4, 2018 Share Posted April 4, 2018 Or you could splurge and spend the $3 it costs at a parts store.. $6 at O'Reilly I believe (bought one the other day). One thing to remember is that you could put 1563535196591565365 grounds on your car and it would NEVER hurt anything. But if you have NO ground, EVERYTHING can mess up. Make your own out of wire like Max shows above. It looks like he used 2-14 ga. wires if I'm correct Max? That's easily more ground than the original flat straps. I generally use a piece of 12 ga. Monster cable with the clear sheath because you can see through it and see if it's corroding. I also put heat shrink tube over the end where the crimp terminal goes on just to seal it up even more. I have a P0245 and I think it might be ground related. I'm going to try putting 1563535196591565365 grounds on my car to see if that solves the issue. I bought some 12-gauge automotive wire and some sheathed terminal loops to make some of my own. I'm also considering replacing my battery cable terminals for good measure, and because one of them is covered in corrosion lol... Link to comment Share on other sites More sharing options...
apexi Posted April 4, 2018 Share Posted April 4, 2018 I remember watching this and thinking it'd be a cool way to check for a bad engine ground. Link to comment Share on other sites More sharing options...
