incufan1 Posted June 7, 2013 Share Posted June 7, 2013 I've only dealt with a dealer once. I had a coupon for a cheap oil change and they wanted to charge me almost $3000 for some basic repairs (I had another shop I trust do everything under a grand). I'm a little apprehensive about taking it in for this inspection/repair. Any tips for someone that doesn't deal with the dealer that often? My car has been registered in Utah,Missouri and Kansas so it qualifies. Link to comment Share on other sites More sharing options...
apexi Posted June 7, 2013 Share Posted June 7, 2013 I snapped a quick picture after having subaru put their anti-corrosion wax on my brake lines and joint connector. It's not the best picture since I didn't feel like going underneath my wet car, but better than nothin. Link to comment Share on other sites More sharing options...
BX77 Posted June 7, 2013 Share Posted June 7, 2013 Looks like the money shot! that's it, how long did it take? Link to comment Share on other sites More sharing options...
apexi Posted June 7, 2013 Share Posted June 7, 2013 I got to the appointment 20 minutes early, and I was there for about an hour, or just under an hour. It looked like my car was only on the lift for 20 minutes or so though, so I think they might've just been busy with other customers and such. Link to comment Share on other sites More sharing options...
ragman Posted June 7, 2013 Share Posted June 7, 2013 I snapped a quick picture after having subaru put their anti-corrosion wax on my brake lines and joint connector. It's not the best picture since I didn't feel like going underneath my wet car, but better than nothin. wow, what a technical fix! they just spluged it. Link to comment Share on other sites More sharing options...
apexi Posted June 7, 2013 Share Posted June 7, 2013 Heres a few more pictures from some Outback forums. http://www.subaruoutback.org/forums/109-gen-3-2005-2009/54561-new-recall-brake-lines-4.html#post698841 One guy there suspects it's just white lithium grease. I'm not too worried regardless of what was used since that area just gets splashed with water, and doesn't really get hit with hard streams of water. As long as it has decent waterproof properties and can't get eaten away with salt, I'm ok with it. And I guess car wash underbody washes could spray water up through the hole I outlined previously, but it'd have to be directly under the hole. Edit: My receipt says the following under parts SOA635115 WQG43 NOX RU So it looks like it might be a tectyl or nox-rust product from the daubert chemical company, and not just plain ole white lithium grease. Link to comment Share on other sites More sharing options...
08subieLGT Posted June 8, 2013 Share Posted June 8, 2013 I received the recall notice from Subaru a few days ago. I'm the second owner, so looks like there sending notice by your registration from DMV. Link to comment Share on other sites More sharing options...
BX77 Posted June 9, 2013 Share Posted June 9, 2013 took a look at mine today Link to comment Share on other sites More sharing options...
PortCityLGT Posted June 9, 2013 Share Posted June 9, 2013 I had a chance to look at mine today. Access was pretty straightforward, pop the little door open and look up. I was very surprised at how well mine had held up, considering the state of the rest of my underbody components. It looked nowhere near as bad as the pictures that FrozenNorthLGT posted a little higher up. With that said, the fix seems a little suspect, and I have my doubts that it will hold up in the long run. I'd much rather... "encourage" them to replace the lines with a little brake fluid. For anyone wondering, as far as I understand, they will only replace the lines if they observe "seepage" of brake fluid through the lines/connector. If none is observed, no matter how bad the rust, you get the band-aid fix. Link to comment Share on other sites More sharing options...
VtspecB Posted June 10, 2013 Share Posted June 10, 2013 Keep the before pictures coming so that we'll have a benchmark from the first person to have the 4-way replaced, thereby hopefully knowing what level of rust/leakage constitutes replacement for reference to our local stealerships. my vBGarage Link to comment Share on other sites More sharing options...
omenjh Posted June 10, 2013 Share Posted June 10, 2013 So Salt Lake City Utah is NOT part of the recall area?? Not sure why because winters here can be rather harsh. I think I wash my car more in the winter than in the summer due to the amount of salt they throw on the roads. Link to comment Share on other sites More sharing options...
subawang Posted June 10, 2013 Share Posted June 10, 2013 So here's what mine looks like after 7 chicago winters (though I try not to drive it much when there's salt on the ground. Although the lighting is a little off, I thought it looked ok and I would be happy applying an anti-rust coating myself. I've serviced my car myself for the 7 years I've owned it - don't trust anyone handling her. It's definitely tight in there without removing the underguard. But I figure it would be easy enough to remove the underguard, hit it with a wire brush, anti-rust coating. Then good as new. Link to comment Share on other sites More sharing options...
car_cursed Posted June 10, 2013 Share Posted June 10, 2013 So Salt Lake City Utah is NOT part of the recall area?? Not sure why because winters here can be rather harsh. I think I wash my car more in the winter than in the summer due to the amount of salt they throw on the roads. Yep, I made this same arguement earlier, I just called Mark Miller to inquire, and they said you can bring your car in and they will inspect it for you for free. Link to comment Share on other sites More sharing options...
incufan1 Posted June 10, 2013 Share Posted June 10, 2013 So Salt Lake City Utah is NOT part of the recall area?? Not sure why because winters here can be rather harsh. I think I wash my car more in the winter than in the summer due to the amount of salt they throw on the roads. Yep, I made this same arguement earlier, I just called Mark Miller to inquire, and they said you can bring your car in and they will inspect it for you for free. Mine was registered in MO at one point so it should qualify on that. I gotta call today. I can't believe SLC, Utah isn't on that list tho. Link to comment Share on other sites More sharing options...
incufan1 Posted June 10, 2013 Share Posted June 10, 2013 Just got off the phone with the service dept at Mark Miller. He said that he doubts it would qualify since it spent such a short time in MO. When I asked why SLC isn't covered, he said the desert climate offsets the salt. Riiiiiiiight... I'm gonna get under the car soon to see how mine looks. If it's bad I'm gonna try to press the dealer more. If it's not that bad, does anyone have a suggestion of what rust inhibitor I can use myself? Thanks.... Sent from my T-Mobile G2 using Tapatalk 2 Link to comment Share on other sites More sharing options...
subawang Posted June 10, 2013 Share Posted June 10, 2013 Eastwood products seem to have good reviews: http://www.eastwood.com/review/product/list/id/1120/category/26/ I'd be interested to get some of the stuff that SOA is actually using though. Maybe the dealership will sell me some... Link to comment Share on other sites More sharing options...
omenjh Posted June 11, 2013 Share Posted June 11, 2013 I was emailing back and forth with the service manager at Nate Wade Subaru. He spent the better half of two emails trying to convince me there is no real problem and not to be worried. I asked him why there was a recall then? I didn't get a response back Link to comment Share on other sites More sharing options...
ehsnils Posted June 11, 2013 Share Posted June 11, 2013 I forgot to mention in my previous post from yesterday, that the service manager said these would only be replaced if fluid was leaking. I asked why this was because its possible that there's enough rust/corrosion to warrant a complete replacement. And he basically said the anti-rust material would stop any further corrosion.....still doesn't help what's already done though. At some level the rust has weakened them enough to warrant a replacement. A panic braking would risk cracking them if they are damaged. I was emailing back and forth with the service manager at Nate Wade Subaru. He spent the better half of two emails trying to convince me there is no real problem and not to be worried. I asked him why there was a recall then? I didn't get a response back Watch out - it can be that they report to SOA that they have made a replacement but are cutting the corners and earn money on it. So you should check with SOA when your car has been in to see which action that was reported and compare with your car. Link to comment Share on other sites More sharing options...
Danteneon Posted June 11, 2013 Share Posted June 11, 2013 For those of you not in the area of the recall, but concerned about rust, this is taken from the recall bulletin... Vehicles in "non-salt belt" states that have experienced the defect In the unlikely event that an owner in a "non-salt belt" state experiences the defect or otherwise requests the procedure be performed on their vehicle, the dealer should perform the recall procedure. This applies to both "salt-belt" and "non-salt belt" state dealers. As far as the chemical used, it is a can that does 33 cars. Not cheap either...MSRP $84.00 I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
ehsnils Posted June 11, 2013 Share Posted June 11, 2013 Just got off the phone with the service dept at Mark Miller. He said that he doubts it would qualify since it spent such a short time in MO. When I asked why SLC isn't covered, he said the desert climate offsets the salt. Riiiiiiiight... I'm gonna get under the car soon to see how mine looks. If it's bad I'm gonna try to press the dealer more. If it's not that bad, does anyone have a suggestion of what rust inhibitor I can use myself? Thanks.... Sent from my T-Mobile G2 using Tapatalk 2 [ame=http://www.amazon.co.uk/DINITROL-PENETRATOR-AEROSOL-Extension-nozzle/dp/B0076L4BII]DINITROL ML PENETRATOR WAX 4 x 500ml AEROSOL SPRAY CANS with 600mm Extension spray nozzle: Amazon.co.uk: Car & Motorbike[/ame] http://www.qpaints.co.uk/tetroseal-wax-oil-rustproofing-black-5l.html http://www.tradekey.com/product_view/id/3985777.htm http://raybuck.com/i-68312-rusfre-clear-amber-innerpanel-rustproofing.html http://www.tptools.com/TP-Tools-Wax-Based-Permanent-Rustproofing-Coating-Gallon,7387.html Rust proofing the car is quite a business over here - and it's necessary since we have one of the most rust-prone climates in the world here around the west coast of Sweden - long winters with a lot of salt on the roads and temperatures around the freezing point combined with salt from the sea. The UK suffers similar conditions. As far as the chemical used, it is a can that does 33 cars. Not cheap either...MSRP $84.00 I would say that it's heavily overpriced. You can get a 1 liter can for something like $12 here - someone makes a buck. Link to comment Share on other sites More sharing options...
lee07 Posted June 11, 2013 Share Posted June 11, 2013 Anyone got it done already? Not liking their cheap temporary fix(spray). They should really replace with new and then spray it, as there's already rust on our lines Link to comment Share on other sites More sharing options...
Max Capacity Posted June 11, 2013 Share Posted June 11, 2013 My wagon goes to the dealer at 4:15 today, it's 9 years old, I'm guessing they'll just clean it and coat it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Eijjix23 Posted June 11, 2013 Share Posted June 11, 2013 set up the appiontment with my dealer. wonder how long this will keep me in the waiting room. Link to comment Share on other sites More sharing options...
mrjk77 Posted June 11, 2013 Share Posted June 11, 2013 got my appointment for 7 am tomorrow. mine is 9 years old as well, and has spent it's entire life in MA. if i'm out in one hour i'll be happy. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 11, 2013 Share Posted June 11, 2013 Took about 20 minutes if that. They coated it and I was on my way. The Spec B goes in next Wed. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
