WaspGT Posted February 14, 2013 Share Posted February 14, 2013 Okay... so my 05 LGT needs some maintenance. Had the techs in my shop put her up on the lift and heres what they gave me. I'd like to replace these bushings with urethane because i plan on coilovers for the spring. I also need sway bar end links. Unfortunately im not rolling in the dough yet so i cant spend the kind of money that i'd like too:rolleyes: With this in mind... does anyone know where i can get a complete kit at fairly inexpensive? I used to be able to rely on Energy Suspension... but i cant seem to find anything with them for my LGT. Whiteline makes some, but sells them individually. School me... ideas, opinions? Any help would be much appreciated:) Link to comment Share on other sites More sharing options...
Underdog Posted February 14, 2013 Share Posted February 14, 2013 I would recommend Whiteline poly control arm bushings. They are nice because you can adjust the caster without pressing out/pressing in the bushings multiple times. You can view the entire Whiteline Lineup here: http://www.whiteline.com.au/do_segue4.php?make=SUBARU&model=LEGACY&model_final=LEGACY+BL+SEDAN%2C+BP+WAGON+MY04-09+INCL+TURBO&vehicle=9%2F03-8%2F09 The two that are being called out specifically are KCA334 (front control arm - rear bushing) and W63398 (rear trailing arm - front bushing). I carry Whiteline, Perrin or Kartboy for poly-bushing endlinks, and OEM wheel bearings... One stop shopping! PM me with your list if you'd like a quote, and I'll put together "kit" pricing for you. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Max Capacity Posted February 14, 2013 Share Posted February 14, 2013 There you go, someone willing to help and he's close to you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
WaspGT Posted March 13, 2013 Author Share Posted March 13, 2013 So i ended up Purchasing a complete WhiteLine CAB kit, F&R through Auto Warehouse for $134 (they even through in F&R sway bar bushings), and bought a Moog F&R sway bar end link kit for $110. I should have replaced my ball joints while i was at it. I wonder if i should grab Moog ball joints too? I've heard mixed reviews. Link to comment Share on other sites More sharing options...
WaspGT Posted March 13, 2013 Author Share Posted March 13, 2013 Also... what is the relevance of installing urethane shifter bushings in my LGT? My shifter feels nice and tight as it is. **I have a set that came with my Whiteline kit. Link to comment Share on other sites More sharing options...
.Catalyst. Posted March 13, 2013 Share Posted March 13, 2013 IF you are going to drop your car get the WL Roll Center/Bump Steer kit. Ball joints and tie rod ends that correct geometry after lowering your car. Essentially a must if you want any sort of decent handling after going for the stance you desire. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
WaspGT Posted March 13, 2013 Author Share Posted March 13, 2013 IF you are going to drop your car get the WL Roll Center/Bump Steer kit. Ball joints and tie rod ends that correct geometry after lowering your car. Essentially a must if you want any sort of decent handling after going for the stance you desire. I'll be looking into that for sure:) Link to comment Share on other sites More sharing options...
