qiman Posted February 9, 2013 Share Posted February 9, 2013 Does anyone know of any non-resistor plugs that fit a normally aspirated EJ25? This is in a 1998 Legacy GT 2.5 liter - 5 speed. Link to comment Share on other sites More sharing options...
spooln30 Posted February 9, 2013 Share Posted February 9, 2013 Just get some NGK Platinum plugs and NGK or OEM wires if you need them, use some diaelectric grease and call it a day. Link to comment Share on other sites More sharing options...
qiman Posted February 9, 2013 Author Share Posted February 9, 2013 What is the resistance of your plugs from hv input connector to the center electrode? Â And what is the item number for your plugs? Link to comment Share on other sites More sharing options...
spooln30 Posted February 10, 2013 Share Posted February 10, 2013 Dude what are you trying to accomplish? Â These are the plugs I'm running NGK # BKR5EGP Link to comment Share on other sites More sharing options...
qiman Posted February 10, 2013 Author Share Posted February 10, 2013 Thanks but an NGK plug with the letter R in the part number means it is a resistive plug. I have a plasma ignition system that requires extremely low resistance through the whole ignition system. Any significant impedance and the impulse does not work. Link to comment Share on other sites More sharing options...
spooln30 Posted February 11, 2013 Share Posted February 11, 2013 Cool, got you now. Email ngk and see if they my a plug for your needs. Link to comment Share on other sites More sharing options...
qiman Posted February 12, 2013 Author Share Posted February 12, 2013 If anyone is interested in non-resistor plugs for the EJ25... I wound up ordering the NGK R5671A-11, #6596 - it is the V-Groove racing plugs and they should fit perfectly. The total for 4 is about $15 delivered. The response I got from NGK is that the only plug avail in the states for the EJ25 they make that are intended for a Subaru is the NGK BCP5ES, #7496 - that is a standard geometry non-resistor plug. These are only a couple $ a piece too. Both of the above can be ordered through any local car parts store. Link to comment Share on other sites More sharing options...
spooln30 Posted February 14, 2013 Share Posted February 14, 2013 So what's the deal with this Plasma ignition system? What engine and mod are you running? Link to comment Share on other sites More sharing options...
qiman Posted February 14, 2013 Author Share Posted February 14, 2013 I have it on my jet engine and leave it running even after it is up to temp - its more efficient. I also have it on my gas generator and it can be run in ultra lean conditions without any heating - it actually drops the temp. With this form of plasma, the more compression/air you cram onto the gap, the bigger the plasma grows - completely opposite from conventional sparks that will get snuffed out. Â I'm putting in the non-resistors in the EJ25 and some 0 resistance plug wires and will move towards putting the plasma on the Subaru, leaning it out and doing those tests. Â Plasma jet ignition circuits have been around for 40+ years but the plugs don't hold up. They need to be pure tungsten on the center electrode AND the ground. But it still works. NASA, Princeton, and all auto manufacturers have patents on it but they all use secondary power supplies to get the effect. My patent pending method is the most efficient and I made the need for secondary completely obsolete. Â Anyway, I'm just surprised that it is so hard to find non resistor plugs for these Subarus. Link to comment Share on other sites More sharing options...
Osei Posted February 14, 2013 Share Posted February 14, 2013 [ ...... My patent pending method is the most efficient and I made the need for secondary completely obsolete. ..../]  More power to you. O. Link to comment Share on other sites More sharing options...
qiman Posted February 16, 2013 Author Share Posted February 16, 2013 (edited) Thanks Osei. @anyone interested - I just received these plugs: NGK R5671A-11, #6596 and they're the lowest ohm non-resistor plugs I've seen. Measured from 0.00 ohms to 0.3 ohms each so these are absolutely perfect for the plasma. Even if you don't use the plasma ignition, there will be an automatic increase in combustion efficiency. Normal Kettering spark ignition can be 0.01 (yes - 1/100th of 1% efficient) and the reason is because most of the energy that leaves the coil is lost in the line resistances in the ignition cables and spark plugs. This has been known and documented for ages. With only non-resistor plugs as an upgrade, you drastically increase the spark efficiency even if you keep the same cables. Plugs are commonly 5000 ohms or more! That's ridiculous.  I'm now waiting for my custom made ignition cables. I've seen the popular "performance" cables that claim to be low resistance at 300 ohms per foot. To me, that is crazy high resistance. The ones I'm having made will be close to 0 (ZERO) ohms per foot. So basically, with those and non-resistor plugs, I will have spark efficiency of around 99.xx% or so. That is 9900 TIMES increase above a typical Kettering Spark ignition that is commonly around 0.01% efficient.   If you use a scope to measure the voltage difference across a resistance of 6000 ohms, which would be minimum for a normal plug and cable series, that will tell you how much current you're getting. If the coil is 20,000 volts, you will have x voltage difference between the input end of the able and the tip of the spark plug electrode.    That current available is the electron current that moves from the ground electrode towards the center hv electrode in the opposite direction - that is the case if the HV polarity is + and opposite if it is negative. You can see that the left side of the Subaru ignition coil terminals get corroded but the right side to not, they're opposite polarity. Anyway, with 6000 ohms of resistance, the current available is pathetically puny.    Imagine taking the same voltage difference across a plug and cable set that is almost zero and you divide that voltage by even say 1 ohm compared to 6000 ohms, you have WAAAAAAAAAAAAY more current there for a spark and it will be tremendously more bigger than normal all from the same silly old stock ignition coil.    No magic, just plain and simple ohms law.    Of course you won't think you have nitro or anything, but you will be getting almost every bit of spark energy to the air/fuel mixture that you're paying for. It makes me cringe to see people spending $1000 on a fancy coil and CDI/MSD type system only to put it on a car with high resistance cables and high resistance spark plugs. They spend that money just to throw a serious portion of all that energy down the drain and they don't even know it. Anyway, I'm just glad to have found some non-resistor plugs for the EJ25 that should work perfectly. I'll post results later when I get time to change my plugs. Edited February 16, 2013 by qiman Link to comment Share on other sites More sharing options...
spooln30 Posted February 16, 2013 Share Posted February 16, 2013 So your saying I could run a non-resistor plug on my stock ignition system Subaru engine to improve its ignition efficiency? I get why they would be better and I understand that a resistor plug is to help with interference with onboard electronics. But to make that system be 100% effective I would also need a ultra low resistance wire as well. This is from NGK's website. " In fact, using a non-resistor plug in certain applications can actually cause the engine to suffer undesirable side effects such as an erratic idle, high-rpm misfire, engine run-on, power drop off at certain rpm levels and abnormal combustion" Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted February 16, 2013 Share Posted February 16, 2013 This thread now has my attention. $15 & a more complete burn can be had? I have one of those "fancy MSD coils" so I'm wondering how that would affect these non resistance plugs that you speak of (coil puts out 40k volts but amps I am not sure). So what is the type of metal that these plugs have so that the electrode at the ends do not get eaten away? I have copper plugs & my MSD is chewing on them like you wouldn't believe.  Also, if there is too much of a spark, I would think that would mean an increase in octane so that the combustion chamber would stay cooler to avoid detonation but if anything I am saying is not making any sense, please let me know. I'm just working off my basic understanding of how spark, air, & fuel come together for combustion. Link to comment Share on other sites More sharing options...
qiman Posted February 16, 2013 Author Share Posted February 16, 2013 So your saying I could run a non-resistor plug on my stock ignition system Subaru engine to improve its ignition efficiency? I get why they would be better and I understand that a resistor plug is to help with interference with onboard electronics. But to make that system be 100% effective I would also need a ultra low resistance wire as well. This is from NGK's website. " In fact, using a non-resistor plug in certain applications can actually cause the engine to suffer undesirable side effects such as an erratic idle, high-rpm misfire, engine run-on, power drop off at certain rpm levels and abnormal combustion" Yes on the improved ignition efficiency and the non-resistor plugs are about the same cost. The NGK v grooved racing plugs I got were about $15 for 4 of them and that included shipping.  The resistance/suppression is supposed to reduce RF intereference. In the last 15 years, this Subaru is the only car where I left in resistor plugs for this long - all the other cars - Civic DX, 200SX with the v6 3 liter, 240z (no computers of course, but still), Kia Sportage (2001) and I have never heard a buzz on the radio or had any problems with the electronics. If anyone finds they have issues, they can always change back to resistor plugs. They're cheap enough to find out. Here is my perspective on RF. Almost every big of RF is generated at a spark gap. If you use an oscilliscope and look at the gap, you will see that although you start with HV DC, at the gap, you actually get a high frequency AC waveform. That is where interference comes from. If you have that plug sitting on the bench, you will see your normal volt meters, etc... glitch because of a mix of the EMP and the RF at the gap.  A lot of materials absorb RF like metals, various plastics, etc... for example, if you have an antenna in both the UHF and VHF ranges for the purpose of mixing frequencies (heterodyning), you don't want to house those antennas in metal, various plastics, etc... because those absorb the RF. If you have a piece of ABS plastic and put it next to a glass of water in a microwave over and turn it on for a minute, the ABS will NOT heat up because that particular plastic does not absorb RF. So, ABS is a very good material to house the antennas in.  Since metal does absorb a good amount of RF, when that RF is created in the gap, the fuel/air mixture absorbs some of that RF but so does all that metal that is surround it - the head and engine block - one giant sink for the RF. I have never seen that the RF is an issue with electronics in that situation.  Will you have RF interference? You could, I can only speak for my own experience, but the fact is that a non-resistor plug will allow a bit higher voltage (because of less voltage drop from the resistance) and that lets higher current move over the gap so permits a bigger spark.  When doing bench tests with my plasma method, the impulse is so strong, the EMP (electromagnetic pulse) was interfering with electronics 20 feet away, but that is out in the open. I was creating plasma balls on a spark plug and some were larger than a golf ball, literally. You can see the third one below - but blasts that big will destroy your plugs, valves, etc... those blasts were nothing but tap water. The impulse is so strong that you don't have to electrolyze water - with simple water vapor, the impulse rips the molecules apart to their atomic state and then instantly burns the hydrogen. The Lorentz force is an electromagnetic field that is produced upon these impulses and launches the plasma off of the plug into the combustion chamber to burn everything.  http://ignitionsecrets.com/images/boost2.jpg Ground strap in normal position http://ignitionsecrets.com/images/boost1.jpg Ground strap in vertical position to open up the gap really big. http://ignitionsecrets.com/images/boost3.jpg Anyway, yes, non-resistors will increase efficiency and yes there is possible interference so I can't guarantee it won't give you interference, I've just never seen it with the plugs in an engine because I believe all the block and head metal are instantly grounding it out so it is a non-issue. For stereo's, there have been RF filters on those for ages and almost nobody ever gets buzzing on their speakers when revving up the engine anymore. Link to comment Share on other sites More sharing options...
qiman Posted February 16, 2013 Author Share Posted February 16, 2013 This thread now has my attention. $15 & a more complete burn can be had? I have one of those "fancy MSD coils" so I'm wondering how that would affect these non resistance plugs that you speak of (coil puts out 40k volts but amps I am not sure). So what is the type of metal that these plugs have so that the electrode at the ends do not get eaten away? I have copper plugs & my MSD is chewing on them like you wouldn't believe.  Also, if there is too much of a spark, I would think that would mean an increase in octane so that the combustion chamber would stay cooler to avoid detonation but if anything I am saying is not making any sense, please let me know. I'm just working off my basic understanding of how spark, air, & fuel come together for combustion. Yes, more complete burn.  40kv is more than that MSD 33000v one some people are putting on their Subaru's that are meant for the Neon and Eclipses. What is the coil you're using? Is your engine similar to a EJ25 wasted spark ignition? The outcome of coupling that non-resistor plugs and your higher voltage ignition is that the spark will be stronger at the plug. With the plasma, the plug material is much more important. Ideally, it would have tunsten at BOTH the center electrode and the ground. Tungsten was common back in the early 1900's - search ebay and you'll see that. Plug manufacturers won't make them anymore because the plugs will outlast your engine and they won't sell very many. Most of the exotic metal plugs are just distracting people from going back to the basics of what always works best. Tungsten is inert and is a great catalyst for chemical reactions - doesn't add to or take away from the chemistry and it won't corrode.  But for performance ignition coils, cdi's or msd's, most normal racing plugs metals work fine. They won't have as long of a life compared to stock ignition coils and resistive wires/plugs. Beryllium/copper is a good alloy that we've tested and some places make them avail. They brisk yttrium a-line non-resistors with the 4 ground electrodes last pretty good. The "torquemaster" plugs now know as Extreme Spark last a long time. I don't have specific experience with those and Subaru's so I'm on a learning curve here and am just starting with the v groove racing plugs from NGK. This isn't the exact numbers, but or example, if you put in 12v and 1 amp into your ignition coil, it will fire at HV when the switch is turned off (inductive collapse or radiant spike). 12v at 1 amp is 12 watts input - I don't know how much a stock subaru coil draws per spark. But this is the idea. If there is 10% loss in the autotransfomer windings (the coil is a small Tesla coil) - you have 12 watts minus 10% loss = 10.8 watts available.  10.8 watts divided by your 40,000 volts output = 0.00027 watts. You traded low voltage and high current for high voltage and low current. If you find how much current your coil draws per pulse, you can then use the above math to figure out the current. Imagine that small of current most of it destroyed in cable and plug resistance. It is no wonder a stock spark is like a fine spider web at the gap of a plug.  Here are some comparisons. http://ignitionsecrets.com/images/1sparkignition200x.jpg As you can see, the standard Kettering Spark Ignition can be as low as 0.01% efficient in converting power to a spark at the gap, which runs almost every gasoline powered engine in the world. http://ignitionsecrets.com/images/1peakingcapacitorignition200x.jpg Peaking Capacitors are MASSIVELY more efficient at converting the standard spark ignition power to a spark - upwards to 50% efficient! Notice that is 50% and NOT one-hundredths of one percent. That is quite a difference, but is all the hype justified? http://ignitionsecrets.com/images/1capacitivedischargeignition200x.jpg Capacitive Discharge Ignition systems have a separate power supply and are the prime choice for serious results. The dense blue ball at the gap is substantially more powerful than the peaking cap but it is hard to tell from the picture. http://ignitionsecrets.com/images/1murakamiignition200x.jpg __________ IGNITION method uses the SAME amount of power as the CDI system but is so much brighter and more powerful that it is beyond words. It isn't even a spark or an enhanced spark - it is in a category all by itself - it is a bright white ball of wonder! I deleted my name because I'm not here to plug my stuff - pun intended. lol Kettering is normal spark ignition. Peaking caps are a capacitor in parallel across the gap of a plug. For example, Pulstar plugs are nothing more than peaking caps built into the plug and the Nology wires are just capacitance built into the wire to do the same thing - they're just discharges slower so the spark lasts longer. CDI is normal capacitance discharge like any CDI or MSD - MSD of course just being more CDI discharges per cycle.  Now, for the EXACT same energy that the CDI takes and you can see the CDI is really not that much different than peaking caps, I get that supernova at the spark plug gap - SAME ENERGY! I just know how to manipulate electricity to do what I want. But that effect won't happen if there is any significant resistance in the plugs and cables.  Anyway, you say your MSD is chewing up your plugs, but it is an actual MSD or is just an MSD manufactured coil? If it is just the coil and it is 40kv output and your plugs are getting chewed up, I'd say the plugs are junk. With plugs I've used throughout thousands and thousands of hours of bench testing ignitions, I've never seen an ignition coil chew up plugs and I'm used to using a Mallory Promaster that is about 70-80kv!  With octane, actually if you have a more efficient ignition, you can use a lower octane. A better ignition doesn't necessarily mean hotter temperature either. For example, with the plasma ignition, (real plasma like I show above and not just bigger normal sparks), the engine temperatures have shown to drop up to 100F or more! AND, that is even with leaning out the mixture. There is a huge misconception about lean burn and engine temps. If you lean it out a little and haven't compensated for a way to burn that lean mixture more efficiently, then yes, you can get hotter temps. However, you can take it so lean and with plasma for example, the engine runs cooler and cooler.  Just look at the famous story about Charles Lindbergh -  http://www.charleslindbergh.com/wwii/ You can read the whole story if you want, it is a fascinating bit of history about a famous lean burn method. ------------------- Nervously the pilot told Lindbergh that he had only 175 gallons of fuel left. The civilian told him to reduce engine rpms, lean out his fuel mixture, and throttle back. When they landed, the 431st driver had seventy gallons left, Lindbergh had 260. They had started the mission with equal amounts of gas. Lindbergh talked with MacDonald. The colonel then asked the group's pilots to assemble at the recreation hall that evening. The hall was that in name only, packed dirt floors staring up at a palm thatched roof, one ping pong table and some decks of cards completing the decor. Under the glare of unshaded bulbs, MacDonald got down to business. "Mr. Lindbergh" wanted to explain how to gain more range from the P-38s. In a pleasant manner Lindbergh explained cruise control techniques he had worked out for the Lightnings: reduce the standard 2,200 rpm to 1,600, set fuel mixtures to "auto-lean," and slightly increase manifold pressures. This, Lindbergh predicted, would stretch the Lightning's radius by 400 hundred miles, a nine-hour flight. When he concluded his talk half an hour later, the room was silent. The men mulled over several thoughts in the wake of their guest's presentation. The notion of a nine-hour flight literally did not sit well with them, "bum-busters" thought some. Seven hours in a cramped Lightning cockpit, sitting on a parachute, an emergency raft, and an oar was bad, nine hours was inconceivable. They were right. Later, on 14 October 1944, a 432nd pilot celebrated his twenty-fourth birthday with an eight-hour escort to Balikpapan, Borneo. On touching down, he was so cramped his crew chief had to climb up and help him get out of the cockpit.  The group’s chief concern surfaced quickly, that such procedures would foul sparkplugs and scorch cylinders. Lindbergh methodically gave the answer. The Lightning's technical manual provided all the figures necessary to prove his point; they had been there all along. Nonetheless the 475th remained skeptical. A single factor scotched their reticence.  -------------------------------------- Anyway, despite their skepticism, the engines actually ran cooler, they used less fuel and there was no fouling of the plugs. A historical fact.  I know someone that ran an engine with an air fuel ratio of 100:1 on a bench test (not pulling a load) using a form of plasma ignition and the engine ran just fine to prove the point. For practical use, an AF ratio of 25:1 on a V8 with plasma worked just fine. That completely rips to shreds everything anyone thinks they know about the possibilities of a lean burn engine.  For example, most cars are about 20% efficient. That means 80% is wasted in transmission losses, etc... and bad combustion. Because of that, that means there is HUGE room for improvement in the combustion chamber. If we were all getting the energy in the fuel that we pay for, then cars wouldn't need a catalytic converter. With lean burn past 14.7:1, conventional wisdom is 100% wrong that you can't burn it. You can. It is a matter of using the right kind of ignition to release the energy from the fuel. That plasma instantly disassociates the hydrocarbon molecules on contact so it is almost like cracking heptane into propane, methane, etc... and suddenly you get more BTU out of the fuel. It isn't magic.  Anyway, I'm waiting for my custom cables and will look at upgrading my coil and adding a CDI that I can then modify to give me plasma. The NGK's won't last incredibly long but it is a test until I have some custom tungsten's modified.  Then, the path is to lean out the EJ25.  40MPG in the EJ25 on the highway with my 5speed should be a no brainer all the while, the engine runs cooler, no plug fouling, etc... I get 29MPG on the hwy with this 160,000 mile engine right now with a few simple things so 33% increase above that should be easy.  Mine is a 98 so is the last year with a MAF before they went to MAP. Does anyone know of a MAF modification to lean it out that doesn't including putting tape over the wire sensor or using a potmeter? Or, does anyone have the actual schematic so I can just build a new circuit? Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted February 17, 2013 Share Posted February 17, 2013 I was always told that it was 40k but if its 33k, that's still good since that's 10k more than the stock ignition coil. Â My EJ22 is actually a hybrid that has EJ25 heads on it but yes, the ignition coil that runs the engine is a wasted spark setup. 1 coil that produces energy for ignition for all cylinders. Â 40mpg from a 25D sounds awesome & may actually be possible as I was able to draw out 36mpg hwy from my 25D/22E hybrid. Our ECUs have an extremely WIDE area of adjustment when it comes to fuel & are self adjusting. I have more than one proof of my car getting these nice mpgs. Â Learning the engine may be a problem though since, as I have mentioned before, our ECUs are self adjusting. The leaner you run, the more fuel the ECU will inject. The richer you run, the more fuel it pulls back. Â My transmission is mint & my fluid & filter was replaced last week (auto). What also helps is that I don't drive aggressively & my ignition system (except for plugs) is practically brand new. I thought I had platinum plugs but I found that I had copper plugs. I also keep the differential fluids fresh. Â With a more thorough burn at lower rpms, the engine will produce more low-end torque due to more energy being released from the fuel in the combustion process. I can see this straightening out the powerband a little but the ECU's correction processing may get in the way if it senses that the fuel is being burned lean through the o2 sensors. Â So even if I don't have the plasma type setup that you do, those low resistance plugs will allow more spark production? I read that correct, right? Link to comment Share on other sites More sharing options...
Osei Posted February 17, 2013 Share Posted February 17, 2013 Well. I am going to buy some of those plugs and wait for your plasma stuff to be available. O. Link to comment Share on other sites More sharing options...
spooln30 Posted February 17, 2013 Share Posted February 17, 2013 Qiman, I'm gonna give those plugs a try. Would it be beneficial to just run those plugs on OEM ignition or should I get wires too? I could use some better mpgs untill I do my STI swap. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted February 17, 2013 Share Posted February 17, 2013 From the way he explained it, it would be very beneficial to run just the plugs with an OEM ignition coil. That being said, I'm also going to buy these plugs. I like where this is going! Link to comment Share on other sites More sharing options...
pleaidestar Posted February 17, 2013 Share Posted February 17, 2013 (edited) The ngk r5671a 11 is a cold plug I'm going your way with that qiman I'm using a 8 heat number with my msd coil, I was using the iridiums but they did not perform nearly as good as I thought they were, so I went to the v powers and the electrode is still sharp shapely and snow white..the ground strap has a little bit of pitting but that blaster coil is strong I think I may need some thicker wires for it...I'm running a 2.2 with that coil and plug setup with stock diameter wires, maybe looking into accel V-8 or wires or going to msd since the engineering and manufacturing is located in el paso to see what application they recommend. Edited February 17, 2013 by pleaidestar Link to comment Share on other sites More sharing options...
pleaidestar Posted February 17, 2013 Share Posted February 17, 2013 (edited) I wouldn't go back to stock after installing that msd coil, that was one of the best things I could have done for efficiency on my car I'm getting 4 mpg better than I was before I installed it, the the idle is so quiet and even there is no pinging whatsoever ,even with the egr delete. Edited February 17, 2013 by pleaidestar Link to comment Share on other sites More sharing options...
qiman Posted February 18, 2013 Author Share Posted February 18, 2013 Quick update - you can use the same plugs - but get warmer ones in the same heat range as stock. The stock "11" at the end is the gap and I thought that was the heat range. On the racing plug, that number actually is the heat range. Just ran them and they work great. I'll post another message but just wanted to say if you order some get them in the same heat range - they're available. Link to comment Share on other sites More sharing options...
qiman Posted February 18, 2013 Author Share Posted February 18, 2013 Learning the engine may be a problem though since, as I have mentioned before, our ECUs are self adjusting. The leaner you run, the more fuel the ECU will inject. The richer you run, the more fuel it pulls back.  My transmission is mint & my fluid With a more thorough burn at lower rpms, the engine will produce more low-end torque due to more energy being released from the fuel in the combustion process. I can see this straightening out the powerband a little but the ECU's correction processing may get in the way if it senses that the fuel is being burned lean through the o2 sensors.  So even if I don't have the plasma type setup that you do, those low resistance plugs will allow more spark production? I read that correct, right? Yeah, the fuel computer sabotage is fairly standard on almost all cars. The EFIE's do work a bit but the benefits are small - they just take the voltage from the o2 sensor and drop it a bit so the fuel computer doesn't richen up as much. I built one from scratch for my Civic and it was one of the things that helped me get 43mpg in the city.  I did hook up a VOLO Performance HHO chip (without having HHO hooked up) and that leans out the fuel just a bit. Got mixed results. Had it disconnected for a while and just wired it back up a couple days ago.  For the fluids, I have only put in AMSoil over the last 3 years that I've had this car. It makes a difference and I also added Champion QX to the oil - it is a vacclaisocryptene - the only under surface lubricant known to science. Has countless microscopic "ball bearings" that go into the metal and under heat and pressure, it sweats it out so any metal to metal contact is as friction free as you can get. Was classified during WWII. Under transverse cylinder tests with Caterpillar engines, many tests showed 0% (ZERO) gap growth under extended running times.  Yes, non-resistors will allow more spark energy for the fuel mixture. Link to comment Share on other sites More sharing options...
qiman Posted February 18, 2013 Author Share Posted February 18, 2013 Qiman, I'm gonna give those plugs a try. Would it be beneficial to just run those plugs on OEM ignition or should I get wires too? I could use some better mpgs untill I do my STI swap. I'd do low resistance cables too.  Yesterday, one of my contacts just send me this: http://granatellimotorsports.com/index.php?p=catalog&mode=search&search_in=all&search_str=subaru&button=submit They make "0" ohm resistor cables and they have a ferrite ring for suppression. I just read the patent - they use steel wires in the core so they have virtually no resistance and they have a ferrite ring - if you have a plasma tv for example and a HDMI cable, there are little ferrite beads that open up and you wind the cable in that one loop and close it up - that is the same idea.  The company I'm getting my cables made at are different - basically the core is a flexible copper tube - same kind of stuff you get at a hardware store stuffed into an insulated tube with the plug and ignition boots at both ends. I'll post this company's name after I get the cables in my hands.  You'll definitely get better efficiency, but as DOHCEJ22E1 mentioned, the computer can sabotage the gains. Link to comment Share on other sites More sharing options...
qiman Posted February 18, 2013 Author Share Posted February 18, 2013 From the way he explained it, it would be very beneficial to run just the plugs with an OEM ignition coil. That being said, I'm also going to buy these plugs. I like where this is going! Yeah, just the plugs make a difference, but I would try to get low to no resistance cables if possible. Link to comment Share on other sites More sharing options...
