HellShadow70 Posted January 16, 2013 Share Posted January 16, 2013 I forget, are you running equal length headers? (btw, I have a feeling I'll be in the same boat---getting misfire on #4 only once so far but crappy idle when cold...fun) I'm running uel borla header, magnaflow cat, cobb catted dp,cobb uncatted up, K&N Typhoon,GFB BOV 50/50. stage 2 93 oct OTS cobb Map, stock turbo and injectors. But i believe this happend before i modded the car. i was driving to bj's and bumped into a infinity G35 we did a quarter mile WOT on the eastchester bridge half way in it a felt a jolt. like it lost power but for a millisecond but then it was fine. then the oil lose started and it got worse and worse now it's like a quart every 700 miles. Link to comment Share on other sites More sharing options...
UTwrestler22 Posted January 16, 2013 Share Posted January 16, 2013 then the oil lose started and it got worse and worse now it's like a quart every 700k. I wish i only lost a quart every 700,000 miles. Link to comment Share on other sites More sharing options...
HellShadow70 Posted January 16, 2013 Share Posted January 16, 2013 Weren't you getting any misfire cells? Rough idle when cold? How much was your oil consumption? Man 48k wouldn't know i didn't have an ap at the time and i was stock. it started with one quart every 1000 miles and no rough idle when cold and i warm up my car with the remote starter. Link to comment Share on other sites More sharing options...
HellShadow70 Posted January 16, 2013 Share Posted January 16, 2013 I wish i only lost a quart every 700,000 miles. LMFAO. Thanks MAN. I Wouldn't be in here if it was 700k now would I Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 16, 2013 Share Posted January 16, 2013 So HellShadow70, you also have a busted ringland on #4? Rebuilding your engine or just brand new shortblock? Link to comment Share on other sites More sharing options...
HellShadow70 Posted January 17, 2013 Share Posted January 17, 2013 So HellShadow70, you also have a busted ringland on #4? Rebuilding your engine or just brand new shortblock? Rebuild, a short block is over kill for a 5eat and money i don't have. Ive read some story's on this forum about short block rebuilds and there not that great especially the new blocks. Link to comment Share on other sites More sharing options...
OutbackXT05 Posted January 17, 2013 Author Share Posted January 17, 2013 07+ pistons equal poop in my opinion Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 17, 2013 Share Posted January 17, 2013 Rebuild, a short block is over kill for a 5eat and money i don't have. Ive read some story's on this forum about short block rebuilds and there not that great especially the new blocks. So which pistons are you going to use and how much will it cost you to rebuild your block? 07+ pistons equal poop in my opinion Link to comment Share on other sites More sharing options...
HellShadow70 Posted January 17, 2013 Share Posted January 17, 2013 Well haven't done the numbers yet, i have to decide if I'm doing it in my friends shop and sending the engine to machine shop or going with AZP installs or both remove engine in the bronx and rebuild in NJ. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 18, 2013 Share Posted January 18, 2013 Talk with the machine shop, my buddy told me he can't rebuild mine for equal $$$$ as a new OEM EJ257. If I wanted a built short block he could do that. But for stock, just go with a EJ257. Also make sure you have a great tune. I have over 12,000 miles on mine. I took him the new EJ257 and my old long block. He rebuilt the heads, cleaned everything, assembled the new long block with oil pan and timing belt. $1200. The EJ257 and gasket set was $2100. http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
OutbackXT05 Posted January 19, 2013 Author Share Posted January 19, 2013 New ej257 shortblock ~$1800-2000 Rebuild shortblock with just forged pistons and bearings ~$900-1100 if you do it yourself machine work included. Of course theres always the stay stock stay happy because it isnt just throw forged pistons in and boom its indestructable. The cylinder walls are gonna be torn up due to the larger clearances when cold. Link to comment Share on other sites More sharing options...
HellShadow70 Posted January 19, 2013 Share Posted January 19, 2013 :confused: Link to comment Share on other sites More sharing options...
HellShadow70 Posted January 19, 2013 Share Posted January 19, 2013 http://www.ebay.com/itm/Brand-New-04-07-Subaru-STi-EJ257-Short-Block-/150976128170#vi-content http://www.flatironstuning.com/p-970-sti-ej257-shortblock.aspx http://www.graveyardmotorsports.com/category_s/1042.htm Link to comment Share on other sites More sharing options...
Oregon OBXT Posted January 19, 2013 Share Posted January 19, 2013 $1,645 here for 10103AC030. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 5, 2013 Share Posted February 5, 2013 Two questions for you OutbackXT05: 1. How's the rebuild going? 2. How did your spark plug in #4 look like? any kind of fouling? if yes, dry carbon fouled or was it wet? Link to comment Share on other sites More sharing options...
OutbackXT05 Posted February 6, 2013 Author Share Posted February 6, 2013 The spark plugs all looked the exact same. One of my buddies looked at them and said theres no way you have a dead cylinder. And as far as the rebuild goes i have 250 miles on it so far and so far so good. Makes a bit of noise when cold due to the bigger clearances. But other than that it started on the first crank after i built some oil pressure. Heres what i put in: CP 8.2compression 99.5mm forged pistons Acl main bearings Acl rod bearings New gasket set Spark plugs KillerB oil pick up Perrin lwcp Perrin turbo inlet (been sitting for over a year so finally took advantage on the motor being out) Infamous full turbo oil feed kit Broken in with rotella T6 i believe is which one it was (the non synthetic of course) Link to comment Share on other sites More sharing options...
HellShadow70 Posted February 6, 2013 Share Posted February 6, 2013 The spark plugs all looked the exact same. One of my buddies looked at them and said theres no way you have a dead cylinder. how did the piston look like when you got them out? any pics? What was the Grand total of the rebuild? BTW my plugs look good too. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 6, 2013 Share Posted February 6, 2013 That's how mine looked like after 60k: http://legacygt.com/forums/showthread.php/check-out-my-spark-plugs-pleasei-200916.html I pulled them last Saturday. I have a brand new injector on #4, new spark plugs, swapped coil packs. Still getting misfire on #4. Sooooo yeah, it sucks. But I would doubt I have a busted ringland since the spark plug was dry...You never know though until I find a place that can do a proper compression and leak down tests. Link to comment Share on other sites More sharing options...
OutbackXT05 Posted February 7, 2013 Author Share Posted February 7, 2013 There was a small amount of carbon buildup on all 4 pistons with 6k miles on them. Nothing out of the ordinary tho. Cp pistons $600 Bearings $110 Gasket set$200 Forgot to add arp head studs $170 Plugs. $50 Fujibond. $30 Oil/coolant$50 Machine work (bore/hone, polish crank, and gap rings) $140 So that makes $1210 if i did that math correctly for the bare basics of the rebuild. Adding Oil pick up. $170 Perrin lwcp $100 Oil feed. $220 Inlet/hoses $150 Totals out to $1850 Link to comment Share on other sites More sharing options...
OutbackXT05 Posted February 7, 2013 Author Share Posted February 7, 2013 Ya a compression test is usually the easiest to see if there is actually an issue. Then the leak down pin points it. It sucks that its so hard for you to find a place to do it cuz the compression gauge i have was 30 bucks from the local parts store. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 7, 2013 Share Posted February 7, 2013 You're so lucky you have a garage. I envy you. I have basically all the necessary tools to do a teardown but no garage . A few more months and then I'll hopefully get one. Link to comment Share on other sites More sharing options...
ehsnils Posted February 7, 2013 Share Posted February 7, 2013 You're so lucky you have a garage. I envy you. I have basically all the necessary tools to do a teardown but no garage . A few more months and then I'll hopefully get one. And you are in France now or??? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 7, 2013 Share Posted February 7, 2013 And you are in France now or??? That's right my man. With the OBXT too . We'll be back towards the end of this year hopefully with the car as well. And of course I have to get this misfire business before returning . Hard to find help over here. Very small French Subaru community and they are mostly acquainted with the EJ20X turboed imprezas. As soon as I mention I have an outback turbo, they are like . So I am on my own.. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 7, 2013 Share Posted February 7, 2013 btw, I drove through your country last year and that's where my timing belt tensioner busted while pulling a trailer during winter in Härnösand. I fixed it myself with my wife in a small garage with no heater... Link to comment Share on other sites More sharing options...
HellShadow70 Posted May 2, 2013 Share Posted May 2, 2013 Engine block is at the machine shop getting bored and honed for CP pistons 99.5mm 8.5 compression. while trying to loosen the cam bolts we cracked a head so I got another passenger side head from a friend, machined and ready to go. The other head is at the same machine shop that did the head I bought. and we broke both inner timing covers, what a pain in the nut sack. parts list. NKG iridium lX plugs stock#6619 STI 11mm oil pump killer B Oil pickup ACL rod and main bearings standard gates racing timing belt kit no pump PCV Valve STI thermostat red line assembly lube subaru fujibond engine sealer From Infamous Performance & Tuning Thanks Msprank subaru overhaul gasket kit Oem radiator hoses new cam bolts Oem water pump new inner timing covers From Heuberger Subaru APR head studs From Lightning Motorsports.com i will get the Infamous full turbo oil feed kit when i get a BNR 18G Link to comment Share on other sites More sharing options...
