Moderators BarManBean Posted October 12, 2012 Moderators Share Posted October 12, 2012 05 Wagon, 68k miles. I plan to keep it for a good long while (safe to assume 100k miles), so I'd like to get the suspension dialed in all at once if I can and I'd like to button everything up either during the winter or beginning next spring. I have a set of epic sedan springs in the garage and I have a set of stock front struts for konis. Pretty well set on going that route. Aside from the konis/springs, what else would you recommend. Pieces that have been floating through my head include a roll-center/bump steer kit to go along with the lowering springs and replacement LCA bushings. I'm guessing it would make sense to install both of these along with the struts to save on labor, but I'm not entirely sure. All thoughts are welcome. I'm looking for a great DD setup and may get into some autocross just for fun down the road. If there's anything I'm missing, fill me in. Should also note that I have hotchkis sways already on with KB endlinks and AVO rear mounts. EDIT: my additional budget after I buy konis and strut mounts will top out at around $800, but I'd really like to keep that around $300 if possible so I can pick up an F1 VB as well. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
.Catalyst. Posted October 12, 2012 Share Posted October 12, 2012 Whiteline ALK Whiteline Front LCA inner bushings Whiteline RC/BS Kit Whiteline steering rack bushings I did this all at once along with the rear camber adjusters with my Swift springs and Bils. Even without sways this setup was the "best handling Legacy" my local Subaru performance and rally shop ever put together. He's used this setup as a recommendation now for 3 other LGTs. I highly recommend and if looking to save $, doing all these at once means only one alignment. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted October 12, 2012 Author Moderators Share Posted October 12, 2012 Cool. I'm looking through some installs today and I'm thinking that a strut/shock install is pretty much unrelated to installation of LCAs. Is that correct? If that's the case, I will probably try to focus on getting the konis done first to see how I like the setup. One step at a time, I guess... I definitely hear you on the alignment issue though, would certainly be nice to only have to do that once. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Shotokan1509 Posted October 12, 2012 Share Posted October 12, 2012 I'd say that depends.. I am doing Koni's and bushings right now, instead of trying to pop the balljoint I actually removed teh arm with the knuckly which means I un-did the strut. If did this once for struts, then again for arms, you'd be looking at two alignments. The other thing, are your LCA bushings torn? Mine are pretty bad at 79k Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted October 12, 2012 Author Moderators Share Posted October 12, 2012 I'm just assuming my bushings are either 1) torn already, or 2) will tear long before I get rid of the car. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
dingbang Posted October 12, 2012 Share Posted October 12, 2012 Yeah, the difference over stock going to koni/epic's and f/r sways was pretty drastic. Replacing my avo adj endlinks with kartboys soon which should remove a little more slop. I picked up a second set of LCA's with almost new balljoints and poly rear bushings. Going to be picking them up from the shop today from getting the front bushings pressed out, got a set of poly whitelines going in. My bushings weren't as torn as shotokan's, but you can definitely tell when driving that they need to be replaced. Glad I picked up a second set of LCA's so I didn't have to worry about rushing to get bushings pushed out/in. Link to comment Share on other sites More sharing options...
BlackHole Posted October 13, 2012 Share Posted October 13, 2012 I have a set of epic sedan springs in the garage Don't forget your 3/8" or 1/2" (need longer strut studs) saggy butt spacers for the wagon when using sedan springs. Get a good alignment - not to stock specs (search this forum). Best $100 spend on suspension, IMO. You may need rear camber arms / adjusters. Kyle "BlackHole" Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted October 15, 2012 Author Moderators Share Posted October 15, 2012 Yup, got the spacers covered I think. Will most likely get an alignment at MachV. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Impatient Posted October 16, 2012 Share Posted October 16, 2012 I'm not sure, did you mention beefing up your RSB? Or both F & R? A popular upgrade. I'll 2nd the notion that if you are pulling off the front struts, replacing the LCA rear bushings might be highly advisable. If you are having a shop do this, make sure they give you some credit for the redundant labor; I had to get nearly abusive to get my point across, and to top it off, the "fu-fu" Subaru tuning shop kinda botched the job (TMI for this thread, but who the h**l can you trust?). Also, there is a middle ground on this, between stock & poly. Maybe I'm wrong, and you already have them, but STI bushings are supposed to be harder, more durable than stock (at least some stock). They are still rubber, with no offset. And a little further toward "modded" are the group N bushings: even more firm, though same basic design. Might take longer to get, and are more expensive. If you don't have any tears in your current bushings at 65K, you are luckier than many. Or is that just an Outback thing? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted October 16, 2012 Author Moderators Share Posted October 16, 2012 I have upgraded F/R sways, endlinks, and mounts already. Also I'll most likely do the work myself, so the only worry about redundant labor is for myself, lol. Sounds like replacing the suspensions and LCA work is more or less a separate process unless I decide to undo the castle nut. Finding a couple days in a row to do car work these days is rare for me, so I'll probably go the route of pulling the ball joint or whatever it is so I can do both jobs separately. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
xero287 Posted October 16, 2012 Share Posted October 16, 2012 If you need halp, you know I have teh toolz. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted October 16, 2012 Author Moderators Share Posted October 16, 2012 If you need halp, you know I have teh toolz. Yah, I may actually take you up on that! Would be nice to have an extra set of hands / extra experience. I'll buy you a shitload of sprite too "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Dujo Posted October 16, 2012 Share Posted October 16, 2012 You can totally do the strut swap without undoing the LCA or any castle nut. Easy enough to do them separately, which I recommend. Especially b/c the hard part will be getting them apart the first time. Once you get them apart, use plenty of antiseize and next time they'll come apart like butter for the roll center or lcas (if you even need them to). RCK or LCAs are not strictly necessary to do a strut swap, but they should still improve handling. I am currently in between struts along with sways and rck and lca on the not yet done side. Will probably run that way this winter and do at least rck in the spring. Fyi ... GTspec makes a relatively new roll center kit that looks to be beefier than the whiteline one. However, I don't think there's a ton of data on how they perform yet. Search on lgt.com for more info, there's a thread out there somewhere. I think I might try that when I get around to it. I have konis/epics in paired with whiteline adjustables in the front and rear. I currently have the setup on hard in front and soft in the rear to get a little closer to oem as I get used to the upgrade over the winter. In the spring, I will probably reverse that to tighten up the understeer/oversteer even further and really try to level things out in the turns. If you plan to use spacers in the rear (which you probably should with a wagon in this setup), you absolutely will need longer top studs on the koni rear. The ones that come with it are too short to use even with a 1/4 inch spacer (ask me how I know ... I have a saggy butt wagon and two spacers sitting in the garage). Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted October 16, 2012 Author Moderators Share Posted October 16, 2012 What are these studs that people talk about? Is there a source / part number for them? I understand exactly the point of the longer studs, just don't know exactly what to get as a replacement. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
xero287 Posted October 16, 2012 Share Posted October 16, 2012 Infamous should be able to get you them. He usually sells them with the spacers. Link to comment Share on other sites More sharing options...
Dujo Posted October 16, 2012 Share Posted October 16, 2012 Actually, I don't know where to get them. I didn't know I needed them until I tried to use my spacers. So ended up just doing it without. It certainly works, but doesn't look quite right. But there are two studs at the very top of the rear strut that attach them to the rear strut tower behind your rear wagon side panels behind the rear seat. If you put a spacer in, you won't be able to thread a nut on from inside the car so you need longer ones. If anybody knows where to source the right part though, I'm in for that actually. Link to comment Share on other sites More sharing options...
Jim_KT Posted October 18, 2012 Share Posted October 18, 2012 What are these studs that people talk about? Is there a source / part number for them? I understand exactly the point of the longer studs, just don't know exactly what to get as a replacement. I remember seeing them available from Paranoid Fabrication's site a while back. Link to comment Share on other sites More sharing options...
dingbang Posted October 18, 2012 Share Posted October 18, 2012 I remember seeing them available from Paranoid Fabrication's site a while back. http://www.subtle-solutions.com/product_info.php?cPath=21_25_64_92&products_id=234 Link to comment Share on other sites More sharing options...
Dujo Posted October 18, 2012 Share Posted October 18, 2012 By the way, when I stripped one of these on my ISCs, I did not have any luck banging out the seated one with a hammer. Instead, I used a vise and block of wood (with a hole) behind the stud and then cranked down pressure on the tip of the stud. After a few cranks, it gave a big pop and came free. Poor man's hydraulic press. Link to comment Share on other sites More sharing options...
LegacyDan Posted October 18, 2012 Share Posted October 18, 2012 im looking for some similar upgrades as i think my bilsteins and pinks are past there best date. i came across these: http://www.europerformance.co.uk/pages/products/product_info.mhtml?product=2577296 i thought Koni only did inserts whereas these look like a full replacement set? is there any point in upgrading to poly bushes on stock jdm sway bars? or upgrading to solid end links on standard sway bars? Link to comment Share on other sites More sharing options...
Dujo Posted October 18, 2012 Share Posted October 18, 2012 ^ Hmm, that's very interesting. The Koni North America website has instructions for the kit as per usual (shock only, no strut option in the front). However, the global website does have a sport strut (front) listed separately from a sport kit, which I assume is the shock-only version. Sounds like there may actually, possibly be a full strut option though. The two Koni websites are a little lacking in information actually. Perhaps it is very recent or it is EDM and/or JDM only? Link to comment Share on other sites More sharing options...
LegacyDan Posted October 18, 2012 Share Posted October 18, 2012 I don't know of any difference between the edm/usdm/JDM struts apart from different valving between some and spring rates. I think strut body is the same across all 05-09 legacy. Link to comment Share on other sites More sharing options...
boxkita Posted October 19, 2012 Share Posted October 19, 2012 Depending on your budget and how much you have spent already, a set of BC Racing Coilovers is a good compromise @ $1000. Plus you get height adjustablity which removes the need for the saggy-butt spacers. You can even set your car to have a forward rake. They also come with front camber plates (up to -2.1 degrees), and adjustable shocks. The Whiteline LCA & ALK kits are good, however, they will change the turn-in feel for cornering, as well affect the self-centering aspect of your steering (it will be less). Replacing the steering rack bushings will firm up your steering quite a bit, cheaper than replacing the steering column with its builtin damper. Replacing the shifter bushings with Group-N bushing will give the shifting a more solid feel. Replacing the rear arms (Whiteline KTA124) will help the back end feel tighter. For me, it meant the rear of the car felt more connected...and reduced the tendency to oversteer. Using solid RSB/FSB endlinks will tighten up the feel of the swaybars. Ideally, you would replace both. If you have adjustable bars, use the softer setting until you get the hang of it. UTube is full of video of Impreza improperly setting this and wrapping the car around some inaminate objects when the car oversteers instead of understeers. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
xero287 Posted October 19, 2012 Share Posted October 19, 2012 Using solid RSB/FSB endlinks will tighten up the feel of the swaybars. Ideally, you would replace both. If you have adjustable bars, use the softer setting until you get the hang of it. UTube is full of video of Impreza improperly setting this and wrapping the car around some inaminate objects when the car oversteers instead of understeers. Most people set it on full stiff and don't really realize what they're doing. I'm glad someone finally posted that people should use the softest setting first. Link to comment Share on other sites More sharing options...
mr.hicksta Posted October 19, 2012 Share Posted October 19, 2012 Extended strut studs: http://www.fastwrx.com/sabusp1.html You will need these if you run any spacers. Cheap, highly recommended and easy to install. Link to comment Share on other sites More sharing options...
