LosAngelesLGT Posted June 5, 2012 Share Posted June 5, 2012 I've bent a lip at 40 psi, but it was a particularly hard impact that would not be considered normal driving....rounded curb @ 50 mph. So to make it clear at 30 or 40psi under normal driving conditions my wheels will be fine but at 30 or 40psi+ my wheels will get bent when experiencing an impact outside of "normal driving"? WTF is the point of this thread exactly? Link to comment Share on other sites More sharing options...
Chris GTO TT Posted June 5, 2012 Share Posted June 5, 2012 Friend of mine has an A3, similar weight and tire, spec'd at 39 psi, runs 42. I run 42 in the spec.b.A3 carries significantly more weight over its front axle too. I've owned numerous cars around 3500 lbs with similar tire profiles to the legacy. Running pressures in the low 30's will consistantly result in bent wheels and sidewall damage when driven on normal roads with pot holes etc. 1996 Nissan Maxima, 2001 Nissan Maxima, 1987 Mitsubishi Starion, 1991 Mitsubishi 3000GT VR-4. Highest recommended tire pressure for any of them is the 3000GT which calls for 36PSI for "sustained high speed driving." Ive never run more than 38 PSI on any of my cars and the only reason my Maxima was run at 38 was because i put Conti DWS's on it and they are extremely soft sidewalled tires. I have yet to bend a wheel or damage a tire from 'low pressure' Low 40's is NOT over inflated and will provide much better tire and wheel durablity. 40 psi is not 'over inflated' per sidewall specs, however it is over inflated on most street cars for normal driving. Yes it will give your tire less flex and roll over in cornering but it will not better protect your wheels. There are at least two threads on the first page of this forum discussing wheel or tire damage..... Many of the tire/wheel damage discussion revolves around the Conti DWS which is notorious for having far too soft of sidewalls. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
scoobyroo Posted June 5, 2012 Share Posted June 5, 2012 We're reading into this all wrong. He's talking boost. Anything under 40psi will destroy your tires and wheels. Time for us all to hit up infamous for a new tune.. Right? Link to comment Share on other sites More sharing options...
1055 Posted June 5, 2012 Share Posted June 5, 2012 I have been filling mine to 34 forever... and ive never bent a wheel or destroyed a tire. I Must be an anomaly. Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted June 5, 2012 I Donated Too Share Posted June 5, 2012 Those of you running low 30s have smooth roads, drive slow, or are on borrowed time. I've bent a lip at 40 psi, but it was a particularly hard impact that would not be considered normal driving....rounded curb @ 50 mph. http://i28.tinypic.com/2ljp5ok.gif Link to comment Share on other sites More sharing options...
trackhore Posted June 5, 2012 Share Posted June 5, 2012 Rao runs 73psi when he drives to the store to contemplate which oil to buy. Link to comment Share on other sites More sharing options...
urfsin Posted June 5, 2012 Share Posted June 5, 2012 Lol. Gotta love a Rao reference! Slide It Sideways Link to comment Share on other sites More sharing options...
Gire Posted June 5, 2012 Share Posted June 5, 2012 Thread closed. Full of mis info that is opinion not fact. And is basically a useless thread. Unless the OP is an engineer from Goodyear or Pirelli or Subaru, then please PM me with your credentials and I will open it up again. Link to comment Share on other sites More sharing options...
