turbodog Posted June 4, 2012 Share Posted June 4, 2012 Sorry, but this should be a sticky. Link to comment Share on other sites More sharing options...
PeterJMC Posted June 4, 2012 Share Posted June 4, 2012 How would you wreck your tires and wheels running less than 40psi? Link to comment Share on other sites More sharing options...
whitetiger Posted June 4, 2012 Share Posted June 4, 2012 dafuq? Link to comment Share on other sites More sharing options...
joelwatts Posted June 4, 2012 Share Posted June 4, 2012 ^yeah, what he said. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
sanchitosonria Posted June 4, 2012 Share Posted June 4, 2012 So what it says from Subaru is incorrect? What's the theory behind this? Link to comment Share on other sites More sharing options...
Drift Motion Posted June 4, 2012 Share Posted June 4, 2012 http://cdn.memegenerator.net/instances/400x/21481206.jpg Link to comment Share on other sites More sharing options...
Gire Posted June 4, 2012 Share Posted June 4, 2012 Sorry, but this should be a sticky. Please go on...... Link to comment Share on other sites More sharing options...
Chris GTO TT Posted June 4, 2012 Share Posted June 4, 2012 I just go all the way and run 60PSI in my tires... 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
iNVAR Posted June 4, 2012 Share Posted June 4, 2012 He's trolling. I searched his other posts. He makes some fairly informed comments in a few other threads. Link to comment Share on other sites More sharing options...
lucas569 Posted June 4, 2012 Share Posted June 4, 2012 sounds like id wreck my suspension Link to comment Share on other sites More sharing options...
turbodog Posted June 5, 2012 Author Share Posted June 5, 2012 No troll. Subaru has always under spec'd tire pressure. Link to comment Share on other sites More sharing options...
iNVAR Posted June 5, 2012 Share Posted June 5, 2012 Riiiiight. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 5, 2012 I Donated Share Posted June 5, 2012 No troll. Subaru has always under spec'd tire pressure. As has every other manufacturer who specs 32-36psi for their car's tires? Please, go on. If Subaru was specing 26psi like Ford did on the Explorer, you might have a point, but as it is, you don't. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 5, 2012 Share Posted June 5, 2012 How in the world would <40 cause damage to tires/wheels? That's just ridiculous. Tires can be damaged by excessive heat buildup, but you need to be below 30 for that to really be an issue. Over 40psi is pretty much overinflated for everything but autoX IMO. Link to comment Share on other sites More sharing options...
No DRFT Posted June 5, 2012 Share Posted June 5, 2012 http://www.gifsforum.com/images/image/stfu/grand/stfu_and_gtfo.jpg I have no control over drippie. Link to comment Share on other sites More sharing options...
turbodog Posted June 5, 2012 Author Share Posted June 5, 2012 As has every other manufacturer who specs 32-36psi for their car's tires? Please, go on. If Subaru was specing 26psi like Ford did on the Explorer, you might have a point, but as it is, you don't. Friend of mine has an A3, similar weight and tire, spec'd at 39 psi, runs 42. I run 42 in the spec.b. I've owned numerous cars around 3500 lbs with similar tire profiles to the legacy. Running pressures in the low 30's will consistantly result in bent wheels and sidewall damage when driven on normal roads with pot holes etc. Low 40's is NOT over inflated and will provide much better tire and wheel durablity. There are at least two threads on the first page of this forum discussing wheel or tire damage..... Link to comment Share on other sites More sharing options...
No DRFT Posted June 5, 2012 Share Posted June 5, 2012 bullshit I have no control over drippie. Link to comment Share on other sites More sharing options...
PeterJMC Posted June 5, 2012 Share Posted June 5, 2012 lol yeap. I drive on un-maintained Baltimore roads all day long and I've never had to repeatedly replace my wheels or have new tires installed. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 5, 2012 I Donated Share Posted June 5, 2012 I had to replace a wheel once on my G20, when I hit a HUGE pothole next to a storm drain going about 60. No amount of overinflation would have kept that from happening. Link to comment Share on other sites More sharing options...
iNVAR Posted June 5, 2012 Share Posted June 5, 2012 Uh, I drive on NYC roads, through ghetto Brooklyn. This is what I posted in another thread: Sooooo your question is... what sort of wheels can you get that are 18 inches and/or a set of tires to go with them that will protect the rim? Get stronger rims. Get ready to pay out of the butt for them. Get tires that have a rim protector too if possible. The tiny extra bit of rubber would help. Most importantly, watch where you're driving. I've driven/drive on these in shitty ghetto Brooklyn roads and I have yet to pop a tire, cause a bubble or dent/crack a rim. 17x7 stock with stock Bridgestone RE92 215/45 17x7 stock with Yokohama W4S 225/45 17x7 stock with Dunlop Wintersport M3 215/45 18x7.5 Volk CE28N with General Exclaim UHP 225/40 I forgot to mention in that thread that I inflate to 36/34 front/rear which is 1 PSI over what the door jamb sticker recommends. In fact, sometimes I neglect to check my tire pressures so realistically I probably dip below that frequently until I remember to check again. I have yet to dent a rim or damage a tire and I can be pretty aggressive in my driving sometimes. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 5, 2012 I Donated Share Posted June 5, 2012 Oh, also, IIRC, the sticker on the door jamb of my mom's A4 says 35psi. It sounds like the A3 is the exception to the rule. Link to comment Share on other sites More sharing options...
KartRacerBoy Posted June 5, 2012 Share Posted June 5, 2012 I've run 35 psi on 18" wheels and 40 profile tires for 7 yrs. Yet I've never bent a rim. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted June 5, 2012 Share Posted June 5, 2012 Ive ran 40psi and bent a wheel. Tar and feather OP and /thread. Link to comment Share on other sites More sharing options...
turbodog Posted June 5, 2012 Author Share Posted June 5, 2012 Those of you running low 30s have smooth roads, drive slow, or are on borrowed time. I've bent a lip at 40 psi, but it was a particularly hard impact that would not be considered normal driving....rounded curb @ 50 mph. Link to comment Share on other sites More sharing options...
iNVAR Posted June 5, 2012 Share Posted June 5, 2012 Those of you running low 30s have smooth roads, drive slow, or are on borrowed time. BTW, 34-36 isn't low 30s. It's mid-30s. Link to comment Share on other sites More sharing options...
