stuck686 Posted May 4, 2012 Share Posted May 4, 2012 been lookin at 07-09 legacy gt, really like the harmon kardon audio but havent compared them much. does it sound alot better? found an 08 spec b that is certified might pull the trigger on it Link to comment Share on other sites More sharing options...
cseagle08 Posted May 4, 2012 Share Posted May 4, 2012 I changed out all the harmon kardon stuff in mine except the front door tweeters. It sounded fine when I still had it all in there. It's probably worth it just for the speaker locations to already be cut, wires run, etc. I haven't heard a non-HK one tho so... Link to comment Share on other sites More sharing options...
Max Capacity Posted May 4, 2012 Share Posted May 4, 2012 IMO my 05 stock radio sounds better then the HK system. The OEM with Sub has a lot less hiss. My GF even said that. I have replaced the front speakers in the Spec, but didn't help much. The plus side is Satilite radio. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted May 4, 2012 Moderators Share Posted May 4, 2012 IMO my 05 stock radio sounds better then the HK system. The OEM with Sub has a lot less hiss. My GF even said that. I have replaced the front speakers in the Spec, but didn't help much. The plus side is Satilite radio. I disagree. The HK in my 09 Sedan sounded WAY better than what is in my 05 wagon. Just my opinion though, and the wagon is also a lot more space to fill. YMMV. I wouldn't buy a turbo subie based on the sound system. You'll save money in the long run by focusing on finding a car that has been well maintained over what the speakers sound like. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Heedz Posted May 6, 2012 Share Posted May 6, 2012 The harmon kardon system makes an aftermarket speaker set up unless outboard amping a PITA Link to comment Share on other sites More sharing options...
