Low compression in Cyl. 2 -- where to go from here?
  • I Donated
Bearings
new rod bolts (?)
If it's the piston, and the cylinder walls are okay, I'm planning on replacing all four but not splitting the block. I have heard that there are access doors to get to the pins holding them in. Although, I would have to buy the pins, too. I assume that's a minimal expense.
  • Replies 151
  • Created
  • Last Reply
Oh yea that's right. Yes there are plugs on the front of the block and panels behind the flywheel to access the rear piston pins.
I think Subaru piston set should come with snap rings and pins. Do a web search and find out.
You going with OEM pistons or Wisceo's or CP's ?
What about a clutch ?
Do you need a Torx Plus tp50 ?
I have a extra set of WRX flywheel bolts that I bought just in case but I need the tp50's for my Al FW.
Thinking about it, I guess you can hone the cylinders with the rods in ?
Engine Build - Click Here
  • I Donated
Probably Wisecos.
Got a CM FX300 sitting in my garage now. If the compression test was okay, I was going to install it; as it is, install will be a bit easier.
I have a SMFW with regular bolts. I dealt with the TP50 last time around, and am glad I don't have to this time around.
I found that the 1/2 impact and the bit from Fred Beans made fast work of the torx plus tp50. To be honest with you, I don't understand why people complain about them, it was that easy.
I bet I can have my machine shop open up the bolt holes so they will fit real bolts.
  • I Donated
If you don't hit the bolts just right, you strip the bit, the bolt, or both. I nearly stripped two of the bolts, but managed to carefully position the bit to get them out.
I think you can reuse the OEM head bolts. I would check with a Subaru tech first. My research tells me they are not stretch bolts, and as such are reuseable.
You shoulnd't need a new timing belt. If you need an old one, I can get you my "tool" timing belt for removing the cam pulleys.
  • I Donated
I might go to the dealer and ask, then.
I mean, I don't NEED a new timing belt, but wouldn't it make sense, since I'm in there anyway?
So you don't use the cam tool, you just tension a belt and take the bolt off that way? The cam tool is EXPENSIVE, so it would be nice not to have to get it.
Update: engine is out. Bringing it into work tomorrow and getting it set up on the stand.
http://i14.photobucket.com/albums/a325/thefultonhow/Subaru/IMG_20120506_143553.jpg
Wow that was quick!
And you're right, while you got the engine out replace all the wear and tear parts. ie spark plugs, belts, gaskets/O rings etc. It'll be a lot easier to refresh the engine while it's out rather than fighting with it in the car.
I have no control over drippie.
Yep, you need to make sure you have the right angle and push the gun into the bolt.
  • Mega Users
I used a chain wrench as well. I wouldn't do it again though. It scored the crank pulley pretty good. Not really any damage and the belts are fine on it, but it will leave some marks.
A fuel pump is not something that you need to replace "just in case", ESPECIALLY considering the price. Had to order mine directly from Bosch and it was still almost $300.
Rather, a fuel pump assembly. My mistake.
  • I Donated
Wow that was quick!
Not wasting anytime are you...
It only took me about 5 hours, taking my time. This is the third time I've pulled a Subaru engine, and so I've figured out a lot of the tricks. Subaru engines are certainly easier than FWD stuff like my old G20.
I'm a little lazy and don't feel like searching... it's the intake cam on the driver's side that wants to rotate, right? Any tricks to not have it do that?
