armax1980 Posted April 17, 2012 Share Posted April 17, 2012 gonna be changing out the front and rear diff fluid on my 2009 2.5i. just wondering for the rear diff do they use metal or liquid gasket for the drain plug and is it the same for the front? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 17, 2012 Share Posted April 17, 2012 gonna be changing out the front and rear diff fluid on my 2009 2.5i. just wondering for the rear diff do they use metal or liquid gasket for the drain plug and is it the same for the front? There is NO gasket maker for either plug Link to comment Share on other sites More sharing options...
bluesuby Posted April 17, 2012 Share Posted April 17, 2012 My 2005 LGT has a copper gasket (reusable) on the transmission (common with diff fluid) and I use Permatex thread sealer on the rear plug (sealer not loctite). Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 17, 2012 Share Posted April 17, 2012 my 2005 lgt has a copper gasket (reusable) on the transmission (common with diff fluid) and i use permatex thread sealer on the rear plug (sealer not loctite). +1 Link to comment Share on other sites More sharing options...
N.sane Posted April 19, 2012 Share Posted April 19, 2012 For the 4EAT, there's a copper gasket for the front. The manual calls for a liquid gasket for the rear, but I never used any and had no issues. I confirmed with shtbxr22, who works at a Subaru dealer, and he said the following: you don't have to use anything on the drain/fill plugs on the diff, at all. i have never heard of that. if you were to use something, I would recommend going to a hardware store and getting teflon paste. I have also done hundreds, maybe more than a thousand rear diff. svcs, and never had a leak afterwards using no sealant. Link to comment Share on other sites More sharing options...
apexjapan Posted April 19, 2012 Share Posted April 19, 2012 Rear diff isn't exactly under pressure, you just fill it up and it sits at the bottom of the diff and oils things as they run through that puddle o' fluid. I'm sure there's a rally team that at some point in history had to use duck tape at some point to seal it, and it did seal... Regards, Paul Hansen http://www.avoturboworld.com http://www.facebook.com/avoturboworld Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 20, 2012 Share Posted April 20, 2012 Does any one know where I can find Redline Lightweight Shock Proof AND MOTUL Gear 300 ???? Swapping fluid and NOT going with Extra-S Link to comment Share on other sites More sharing options...
