The Official Legacy Wheel Fitment Thread
Ohitsspencer
So I mounted a set I just picked up and wow....no rubbing non stock setup. Have hit a few bumps but nothing scraping. Can't believe my good fortune. Thought at least I'd have to go a size down, maybe two. I plan to change springs but not lower. Hoping to pick up some Swifts and then add some spacers to the struts to even me back up ot get me close.
Edited by MDSubie4
  • 1 month later...
Wheel brand/model: Enkei PF01
Wheel height/width: 17x8
Wheel offset: +45mm
Tire size: 235/55-17
Camber F/R: -1.5-ish / minimal
Lowered?: No, spec.B springs on Bilstein HD struts.
Modified Fenders?: Stock
Miscellaneous Suspension: Seems to ride lower than other stock Legacys, suffers from saggy butt, camber bolts up front.
With more rear camber, I think this setup would work. As it is, rears will rub with anything more than 10% throttle. Fronts do not rub at all.
Other notes: I think 225/55-17s would work with minimal rubbing, as well as 235/45-17s.
Edited by JF1GG29
Hi guys and gals. For some reason I am unable to send pics? I'm working on it. Promise. Color- like a tomato soup red? Idk the color code or name. That's my next project. I wanted to make sure I can run 225-45-17's on my stock 7" rim? The reason i ask is i see pictures on here with 225s but with a 7.5 inch rim. Is the stock rim size 7.5 or 7? Also you are positive there will be no tire rubbing or hitting the fender on a bump?
These 215s are too skinny. Great for snow but that's about it.
I have to say the ride is crazy stiff? I had my suspension looked at to make sure nothing was wrong and it was fine. Is the reason BMW can make a suspension stiff and connected to the road and Subi can't strictly a cost issue? I'm running Hankook ventus v2 all seasons on my car which I just purchased. I would say 70% tread left. Man the ride is so choppy I'm going to have to wear a kidney belt. It sounds as if my ball joint is going to bust through the hood. Lol. Well I'm coming from a 2005 Audi A6 3.2 with Continental Extreme Contact 06. Great tire btw. But I know Audi is more comfort oriented. It wasn't the greatest handling car I ever drove but it wasn't a Chrysler K car either. Anyway I digress. So back to my fitment question. No problems? Thnx!!! Love the forum and my turbo!!!
  • 3 weeks later...
Hi there!
One more post about wheels.
2015-2017
Wheels: Rays Gram Lights 57Xtreme
Offset: +15 front/+10 rear
Tires: Hankook Ventus V12 Evo K110, 215/40
Lowering: Blitz Damper ZZ-R
Camber: About -6
Modified Guards: Rolled
After 2017
Wheels: BBS RG-R
Offset: +35
Tires: Bridgestone Potenza RE-11, 215/45
Lowering: Stock+RSR Ti2000
Camber: About -1.5
Modified Guards: Rolled Guards
Edited by Udong
Wheel brand/model: Enkei RPF1s (2x Gunmetal/2x Silver)
Wheel height/width: 18x8.0
Wheel offset: +35
Clear Brembos: Yes
Tire size: 235/40/18 Michelin Pilot Sport 4S
Camber F/R: -2F - 2R
Modified Guards: N/A
Miscellaneous Suspension: BC coilovers, Whiteline rear camber kit
MILKRUN  - Click Here
  • 1 year later...
  • 6 months later...
Wheel brand/model: BBS Forged 02 WRX option
Wheel height/width: 17x7
Wheel offset: 55
Clear Brembos: No
Tire size: 225/45/17 Michelin Pilot Sport A/S 3+
Miscellaneous Suspension: Koni
  • Like 1
