MDSubie4 Posted March 27, 2020 Share Posted March 27, 2020 (edited) So I mounted a set I just picked up and wow....no rubbing non stock setup. Have hit a few bumps but nothing scraping. Can't believe my good fortune. Thought at least I'd have to go a size down, maybe two. I plan to change springs but not lower. Hoping to pick up some Swifts and then add some spacers to the struts to even me back up ot get me close. Edited March 27, 2020 by MDSubie4 Link to comment Share on other sites More sharing options...
JF1GG29 Posted May 18, 2020 Share Posted May 18, 2020 (edited) Wheel brand/model: Enkei PF01 Wheel height/width: 17x8 Wheel offset: +45mm Tire size: 235/55-17 Camber F/R: -1.5-ish / minimal Lowered?: No, spec.B springs on Bilstein HD struts. Modified Fenders?: Stock Miscellaneous Suspension: Seems to ride lower than other stock Legacys, suffers from saggy butt, camber bolts up front. With more rear camber, I think this setup would work. As it is, rears will rub with anything more than 10% throttle. Fronts do not rub at all. Other notes: I think 225/55-17s would work with minimal rubbing, as well as 235/45-17s. Edited May 18, 2020 by JF1GG29 Link to comment Share on other sites More sharing options...
maxxbenzz90 Posted May 19, 2020 Share Posted May 19, 2020 Hi guys and gals. For some reason I am unable to send pics? I'm working on it. Promise. Color- like a tomato soup red? Idk the color code or name. That's my next project. I wanted to make sure I can run 225-45-17's on my stock 7" rim? The reason i ask is i see pictures on here with 225s but with a 7.5 inch rim. Is the stock rim size 7.5 or 7? Also you are positive there will be no tire rubbing or hitting the fender on a bump? These 215s are too skinny. Great for snow but that's about it. I have to say the ride is crazy stiff? I had my suspension looked at to make sure nothing was wrong and it was fine. Is the reason BMW can make a suspension stiff and connected to the road and Subi can't strictly a cost issue? I'm running Hankook ventus v2 all seasons on my car which I just purchased. I would say 70% tread left. Man the ride is so choppy I'm going to have to wear a kidney belt. It sounds as if my ball joint is going to bust through the hood. Lol. Well I'm coming from a 2005 Audi A6 3.2 with Continental Extreme Contact 06. Great tire btw. But I know Audi is more comfort oriented. It wasn't the greatest handling car I ever drove but it wasn't a Chrysler K car either. Anyway I digress. So back to my fitment question. No problems? Thnx!!! Love the forum and my turbo!!! Link to comment Share on other sites More sharing options...
JF1GG29 Posted May 20, 2020 Share Posted May 20, 2020 I wanted to make sure I can run 225-45-17's on my stock 7" rim? Yes, you can run 225/45R17 on your stock 17x7 ET+55 with zero issues. Link to comment Share on other sites More sharing options...
maxxbenzz90 Posted May 20, 2020 Share Posted May 20, 2020 Ok thank you! 225's it is. Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
Udong Posted June 8, 2020 Share Posted June 8, 2020 (edited) Hi there! One more post about wheels. 2015-2017 Wheels: Rays Gram Lights 57Xtreme Size: 18x9.5 Offset: +15 front/+10 rear Tires: Hankook Ventus V12 Evo K110, 215/40 Lowering: Blitz Damper ZZ-R Camber: About -6 Modified Guards: Rolled After 2017 Wheels: BBS RG-R Size: 17x7.5 Offset: +35 Tires: Bridgestone Potenza RE-11, 215/45 Lowering: Stock+RSR Ti2000 Camber: About -1.5 Modified Guards: Rolled Guards Edited June 9, 2020 by Udong Link to comment Share on other sites More sharing options...
Febreze Mee Posted June 9, 2020 Share Posted June 9, 2020 Wheel brand/model: Enkei RPF1s (2x Gunmetal/2x Silver) Wheel height/width: 18x8.0 Wheel offset: +35 Clear Brembos: Yes Tire size: 235/40/18 Michelin Pilot Sport 4S Camber F/R: -2F - 2R Modified Guards: N/A Miscellaneous Suspension: BC coilovers, Whiteline rear camber kit MILKRUN - Click Here Link to comment Share on other sites More sharing options...
Nyo Posted August 25, 2021 Share Posted August 25, 2021 i is there anyone who has tried 19s on the wagons? I am considering as I have a set of 19x8.5 ET30 Axis Hiro but I am not sure what tire spec to be used Any advise?? Link to comment Share on other sites More sharing options...
KekkeiLogankai Posted March 4, 2022 Share Posted March 4, 2022 Does the outback xt have more wheel well clearance than the legacy gt of the same year? Link to comment Share on other sites More sharing options...
Febreze Mee Posted March 4, 2022 Share Posted March 4, 2022 Does the outback xt have more wheel well clearance than the legacy gt of the same year? No, but the factory flares allow for you to make a little more clearance if you don't mind cutting. Read through this: https://legacygt.com/forums/showthread.php/rhitters-build-thread-248151p19.html MILKRUN - Click Here Link to comment Share on other sites More sharing options...
JJr Posted March 9, 2022 Share Posted March 9, 2022 Wheel brand/model: BBS Forged 02 WRX option Wheel height/width: 17x7 Wheel offset: 55 Clear Brembos: No Tire size: 225/45/17 Michelin Pilot Sport A/S 3+ Miscellaneous Suspension: Koni 1 Link to comment Share on other sites More sharing options...
