c123money Posted March 14, 2012 Author Share Posted March 14, 2012 Just give me a set up where hitting a bump or hole doesn't feel like I got hit by an RPG in one of my tires and I am happy. No clinks, clanks, extra knobs or tools. I just want the set up and bing bang boom, happy N/A driver cruising the streets and hitting corners with authority. So far Koni's sound good, springs are were we get into holly f#ck there's a lot of options here. Link to comment Share on other sites More sharing options...
c123money Posted March 14, 2012 Author Share Posted March 14, 2012 After reading and reading and reading, I think I'm going Koni with Eibach Pro-Kit. Just need to get it done now. Link to comment Share on other sites More sharing options...
PhillyWilly Posted March 14, 2012 Share Posted March 14, 2012 where did you find the pro kit? Link to comment Share on other sites More sharing options...
c123money Posted March 14, 2012 Author Share Posted March 14, 2012 where did you find the pro kit? Thought I did then realized it was for 2010-up models... Back to square one WTF:spin: Link to comment Share on other sites More sharing options...
c123money Posted March 14, 2012 Author Share Posted March 14, 2012 Check your PM.. Thought I did then realized it was for 2010-up models... Back to square one WTF:spin: Link to comment Share on other sites More sharing options...
BoostWagon Posted March 15, 2012 Share Posted March 15, 2012 Aren't the Epics the same spring as the Eibachs? Different mfgr designing to match the discontinued Eibach's was my understanding. So far so go with the Koni Epic combo, fronts and backs turned up 3/4 turn from full soft. Rears are a bitch to adjust though.. Link to comment Share on other sites More sharing options...
mdd Posted March 15, 2012 Share Posted March 15, 2012 When I got my Koni's last year I was annoyed with how not-user-friendly they were to adjust in the rear (I have a wagon, not sure how bad the sedans are). It is too time consuming. I changed mine a lot as I dialed them in initially. I still change mine here and there depending on how full the wagon is, so I wanted something to help with the adjustment. I found these: http://www.rogueengineering.com/mm5/merchant.mvc?Screen=PROD&Product_Code=KONI_ADJ&Category_Code=Coils They are a little pricey, but they work like a charm and have saved a fair amount time and anger. I also enjoy the precision they offer. I had a hard time ensuring the supplied Koni knobs were positioned as I intended with the lack of space. If anyone decides to get these, I would recommend that you make the hole in the trim about 3 times larger than the diameter of the rod. Otherwise they will pop off of the adjuster tab as the suspension goes through its' range of motion; I think the tab moves a little. For the wagon, they are the perfect length and require no trimming. One word of warning is if you are running spacers, you will have a hard time tightening the set screw that attaches them to the adjuster. I ended up taking a sharp hacksaw to shorten an Allen wrench. This allowed it to fit in the area when I was running spacers. No spacers, no problems. Just wanted to put this out there as I have liked them. Probably very easy for someone to duplicate who has the right tools or connections. Link to comment Share on other sites More sharing options...
BoostWagon Posted March 17, 2012 Share Posted March 17, 2012 MDD, were you able to lock these down, or is the weight enough to hold them in place? The shop that put my Konis in made a similar tool for me, but only one. A second would cost me $50 for them to fabricate, these might be worth the extra $ to have two in place at all times. Last time I adjusted the backs it took me close to 8 minutes to engage the second strut, kind of a disincentive to tweak them often. Link to comment Share on other sites More sharing options...
BoostWagon Posted March 17, 2012 Share Posted March 17, 2012 MDD, were you able to lock these down, or is the weight enough to hold them in place? The shop that put my Konis in made a similar tool for me, but only one. A second would cost me $50 for them to fabricate, these might be worth the extra $ to have two in place at all times. Last time I adjusted the backs it took me close to 8 minutes to engage the second strut, kind of a disincentive to tweak them often. Guess I should have read your post more thoroughly, looks like you answered it already. Link to comment Share on other sites More sharing options...
jcsny18 Posted March 17, 2012 Share Posted March 17, 2012 I've been trying to make a decision for 2 months. As far as my car being lowered epic springs give me exactly what I'm looking for. Install of the Koni's look like a pain in the arse and may cost more (in labor) and take longer for a shop to do. I've seen a lot of comments on the Koni/Epic combo but what about the Bilstein/Epic combo? Anyone have or been in a car with this set up? Keep in mind I have a 2.5i and do 90% city driving in the Boston area dodging bombed out roads all day. Only suspension mods I've had so far are a whiteline rear sway and end links. Appreciate any feedback Subscribed. I have a 2009 n/a and saw your post from a few months ago about improving ride quality and whatnot, and after doing some research myself I've narrowed it down to koni's/blisteins for struts and most likely epics for springs being that I've seen a few members have confined epics just being rebranded eibachs (after seeing that eibach only makes springs for 2010+ models I understand your "back to square one" frustration) still not 100% on any decision yet though as most of my money is going to tuition Link to comment Share on other sites More sharing options...
jcsny18 Posted March 17, 2012 Share Posted March 17, 2012 having so many options really does suck Link to comment Share on other sites More sharing options...
tito_b0y Posted March 17, 2012 Share Posted March 17, 2012 Subscribed. I have a 2009 n/a and saw your post from a few months ago about improving ride quality and whatnot, and after doing some research myself I've narrowed it down to koni's/blisteins for struts and most likely epics for springs being that I've seen a few members have confined epics just being rebranded eibachs (after seeing that eibach only makes springs for 2010+ models I understand your "back to square one" frustration) still not 100% on any decision yet though as most of my money is going to tuition Your car still running well? If so, I suggest saving your money for maintenance and then upgrade to the GT after you graduate and get your career started. My $.02 as a fellow student with a modded 2.5i 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
jcsny18 Posted March 17, 2012 Share Posted March 17, 2012 yeahhhhh.....i guess your right "stay stock stay happy" right?....realizing this to be truer everyday. Link to comment Share on other sites More sharing options...
BoostWagon Posted March 17, 2012 Share Posted March 17, 2012 Compared to stock how would you say it penalizes the ride? Just curious as I've heard that from a few others, if its bad would it be better just to keep the OEM springs with the Koni's? Just with the new rear sway 20mm, endlinks, and front strut bar (mostly aesthetic) the car handles like a new car in corners and switching lanes quickly curious to see how much more it will tighten up with the strut/spring mod. I'm not experienced enough to truly separate the effects of springs vs struts. I do think there's a minor penalty in ride quality, especially on big hits, but its a trade-off I was willing to try out. I think the ride flattens out a lot with the springs, if you really have a lot of windy roads in your daily driving, I don't think you'll regret the springs. Link to comment Share on other sites More sharing options...
jhawk222 Posted March 19, 2012 Share Posted March 19, 2012 I went with the Koni/Epic setup. I'll weight in when I finally get them installed this week. Link to comment Share on other sites More sharing options...
jhawk222 Posted March 19, 2012 Share Posted March 19, 2012 H&R are stiffer but not as much drop as the Epics. I would go for the H&R for performance and Epic for comfort. Let us know if we can provide either set for you and/or install. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Mike, what do you guys charge for the Koni/Epic install? Link to comment Share on other sites More sharing options...
AZP Installs Posted March 20, 2012 Share Posted March 20, 2012 Mike, what do you guys charge for the Koni/Epic install? We charge $295 and $100 for an alignment (if you want an alignment). http://azpinstalls.com/index.php?option=com_content&view=article&id=54&Itemid=74 -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
c123money Posted March 20, 2012 Author Share Posted March 20, 2012 Crazy question but has anyone ever run Bilstein HD's with stock springs? I'm looking for minimal maintenance once I put on new struts. Just curious if that would even be worth it for an option or if its just a waste of money. I'm really not worried about the ride height as much as the overall ride. Link to comment Share on other sites More sharing options...
AZP Installs Posted March 21, 2012 Share Posted March 21, 2012 Crazy question but has anyone ever run Bilstein HD's with stock springs? I'm looking for minimal maintenance once I put on new struts. Just curious if that would even be worth it for an option or if its just a waste of money. I'm really not worried about the ride height as much as the overall ride. I liked by stock w/konis. I ran stockers with bilsteins on my wagon, they were pretty good as well, just a bit harsher than the konis. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
recruitx Posted March 26, 2012 Share Posted March 26, 2012 How do the konis compare to JDM spec B struts w either pinks or Spec B Springs? Link to comment Share on other sites More sharing options...
RuskiTrombone Posted March 28, 2012 Share Posted March 28, 2012 When I got my Koni's last year I was annoyed with how not-user-friendly they were to adjust in the rear (I have a wagon, not sure how bad the sedans are). It is too time consuming. I changed mine a lot as I dialed them in initially. I still change mine here and there depending on how full the wagon is, so I wanted something to help with the adjustment. I found these: http://www.rogueengineering.com/mm5/merchant.mvc?Screen=PROD&Product_Code=KONI_ADJ&Category_Code=Coils They are a little pricey, but they work like a charm and have saved a fair amount time and anger. I also enjoy the precision they offer. I had a hard time ensuring the supplied Koni knobs were positioned as I intended with the lack of space. If anyone decides to get these, I would recommend that you make the hole in the trim about 3 times larger than the diameter of the rod. Otherwise they will pop off of the adjuster tab as the suspension goes through its' range of motion; I think the tab moves a little. For the wagon, they are the perfect length and require no trimming. One word of warning is if you are running spacers, you will have a hard time tightening the set screw that attaches them to the adjuster. I ended up taking a sharp hacksaw to shorten an Allen wrench. This allowed it to fit in the area when I was running spacers. No spacers, no problems. Just wanted to put this out there as I have liked them. Probably very easy for someone to duplicate who has the right tools or connections. Still not sure what you did with these. Any help in explaining further how you installed the rogue engineering adjusters? Link to comment Share on other sites More sharing options...
mdd Posted March 28, 2012 Share Posted March 28, 2012 Still not sure what you did with these. Any help in explaining further how you installed the rogue engineering adjusters? Within the next month or so I will be doing a stereo install in the wagon. At that time I'll do a proper write up (in a new thread) on the installation of these as pictures will be easier to take then. If anyone needs further info between now and then, PM me and I'll do my best to help. Regards, Matt Link to comment Share on other sites More sharing options...
RuskiTrombone Posted March 28, 2012 Share Posted March 28, 2012 Thanks Link to comment Share on other sites More sharing options...
c123money Posted March 29, 2012 Author Share Posted March 29, 2012 Anyone know the part number for pinks for my 09 to complete the Bilstein/Pink combo? If the epics weren't an issue and I could find eibachs I would do the koni/eibach but this is like trying to a diamond in the ocean. Appreciate any help on finding the right pinks. Link to comment Share on other sites More sharing options...
AZP Installs Posted March 29, 2012 Share Posted March 29, 2012 Anyone know the part number for pinks for my 09 to complete the Bilstein/Pink combo? If the epics weren't an issue and I could find eibachs I would do the koni/eibach but this is like trying to a diamond in the ocean. Appreciate any help on finding the right pinks. The pinks will be way too stiff for your needs imo. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
