PhilT Posted June 29, 2005 Share Posted June 29, 2005 Hi guys, I searched the archives and found nothing about this so here's my question: Has anyone else had problems with their wheels becoming discoloured around the wheel nuts. It appears that the clearcoat is coming away from the alloy, although its not actually peeling. I have heard of this on other cars, especially up here where there is a ton of salt on the roads in the winter. Would this be covered under warranty ? Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
rallispec Posted June 29, 2005 Share Posted June 29, 2005 subaru puts some kind of wax or grease on the lugs apperently -- and as the wheel heats up it melts and drips out. Thats most likely what you're seeing. Some goo gone or other grease remover and a little bit scrubbing should clean them up fine. you'l probably have to repeat this every once in a while as more of the stuff drips out. Link to comment Share on other sites More sharing options...
rallispec Posted June 29, 2005 Share Posted June 29, 2005 http://legacygt.com/forums/showthread.php?t=2215 Link to comment Share on other sites More sharing options...
rallispec Posted June 29, 2005 Share Posted June 29, 2005 http://legacygt.com/forums/showthread.php?t=2302 http://slingblade.fccj.edu/~bfair/out/wheelgunk.jpg Link to comment Share on other sites More sharing options...
rony Posted June 29, 2005 Share Posted June 29, 2005 Yep, you can clean it off, it's just not fun.. My Car vBGarage Link to comment Share on other sites More sharing options...
PhilT Posted June 29, 2005 Author Share Posted June 29, 2005 Thanks guys, Goo Gone it is then. It's times like this I wish I had A/C in my garage ! Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
rony Posted June 29, 2005 Share Posted June 29, 2005 Use a fan... My Car vBGarage Link to comment Share on other sites More sharing options...
Legasee Posted June 29, 2005 Share Posted June 29, 2005 subaru puts some kind of wax or grease on the lugs apperently -- and as the wheel heats up it melts and drips out. Thats most likely what you're seeing. Some goo gone or other grease remover and a little bit scrubbing should clean them up fine. you'l probably have to repeat this every once in a while as more of the stuff drips out. If it's this, then I got it too...I just use scratch remover polish...it's also clear-coat safe...very easy to take that stuff off with! In Taiwan now... Link to comment Share on other sites More sharing options...
VXCL Posted June 29, 2005 Share Posted June 29, 2005 that stuff came right off using a small amount of goof off. also are rims are painted silver or is it just mine. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Gire Posted June 29, 2005 Share Posted June 29, 2005 Same situation over here... I figured it was some road gunk picked up somewhere. Had to use some Grade 'A' elbow grease! Link to comment Share on other sites More sharing options...
