LegacyDan Posted December 9, 2012 Share Posted December 9, 2012 its hard to make out what that bracket connects to on the radiator, that would be a better location if mine has similar, i just want to keep it as a position as close to stock as i can, just to keep things simple! Link to comment Share on other sites More sharing options...
cheerio Posted December 11, 2012 Share Posted December 11, 2012 Hey guys I been trying to install the FMS FMIC and I ran into some trouble. The problem is I been having trouble trying to put my bumper back on because it seems to be rubbing around the foglight area. I seen several of you guys install the kit and was able to retain your foglights. Any positive input will be gladly appreciated. Link to comment Share on other sites More sharing options...
G5892 Posted December 11, 2012 Author Share Posted December 11, 2012 Did you mount your driverside pipe like this? I know you have to do some trimming, but if you dont mount it like this, then you'll have to lose the fogs. http://i51.tinypic.com/15pfwvq.jpg Link to comment Share on other sites More sharing options...
cheerio Posted December 11, 2012 Share Posted December 11, 2012 yes i did! do i have to trim more? When you mount it like that you have to move your coolant but im still having trouble getting my bumper back on... sigh Link to comment Share on other sites More sharing options...
IM SLO Posted December 11, 2012 Share Posted December 11, 2012 Yes, keep trimming. It eventually fits and fits well. I ran into the same issue, however once you trim enough it fits perfectly fine. if i remember right you have to trim more behind the fog light that anywhere else. Link to comment Share on other sites More sharing options...
cheerio Posted December 11, 2012 Share Posted December 11, 2012 Yes, keep trimming. It eventually fits and fits well. I ran into the same issue, however once you trim enough it fits perfectly fine. if i remember right you have to trim more behind the fog light that anywhere else. Can u be a pal and provide pics? Link to comment Share on other sites More sharing options...
06specb366 Posted December 11, 2012 Share Posted December 11, 2012 U can also trim back the silicone 90 a bit on the intercooler side to move the pipe over a little towards the center of the car. Then it fits right in that pocket between the middle and where the fog light cover snaps in. Only a little though, like 1/4". Also, if u use 3/4" flat stock and bend a 90 in it, it will slip right into the slot on the radiator where the second bolt (drivers side) for the fan is. You will need a slightly longer bolt to do this. I can post pics of mine later if u want. Good luck . Link to comment Share on other sites More sharing options...
06specb366 Posted December 11, 2012 Share Posted December 11, 2012 here are the pics of my setup if you are interested. I used 3/4" flat stock as it fits in the groove on the radiator and a slightly longer bolt to accomidate the extra space. Also, the pic of the bumper is where the pipe should end up. Link to comment Share on other sites More sharing options...
LegacyDan Posted December 11, 2012 Share Posted December 11, 2012 looks like a good way to mount the overflow tank, ill see can i get a bracket to fit there Link to comment Share on other sites More sharing options...
cheerio Posted December 12, 2012 Share Posted December 12, 2012 here are the pics of my setup if you are interested. I used 3/4" flat stock as it fits in the groove on the radiator and a slightly longer bolt to accomidate the extra space. Also, the pic of the bumper is where the pipe should end up. thanks buddy! I manage to get my bumper back on but its not perfectly flushed like stocked. I will try to trim the silicone and try to get my piping to end up where u pointed out! Link to comment Share on other sites More sharing options...
cheerio Posted December 12, 2012 Share Posted December 12, 2012 looks like a good way to mount the overflow tank, ill see can i get a bracket to fit there Its not every day you get a guy response and post good pictures!!! we luck out. Link to comment Share on other sites More sharing options...
06specb366 Posted December 12, 2012 Share Posted December 12, 2012 oh, and one other thing, there is a "bent" silicone coupling. This goes at the joint between the pipe to the throttle body(one with BOV) and next pipe. If you face the bend down, it kicks the pipe in towards the timing belt cover. This gives you a little more room for the bumpeer. Link to comment Share on other sites More sharing options...
LegacyDan Posted December 12, 2012 Share Posted December 12, 2012 Shit I used that on the left side outlet of the core maybe that would explain my misaligned hot side piping. So just a straight coupler coming of left side of core as your looking at it? Maybe its different with the turboxs piping. I'll have to check the instructions for it Link to comment Share on other sites More sharing options...
06specb366 Posted December 12, 2012 Share Posted December 12, 2012 I believe I did just use a straight connector out of the left side. Good luck man. Link to comment Share on other sites More sharing options...
IM SLO Posted December 12, 2012 Share Posted December 12, 2012 All of the above ^^ haha this is exactly how i did it, and it fits perfect. 06Specb366 you beat me to it. lol Link to comment Share on other sites More sharing options...
firerescue9 Posted May 9, 2016 Share Posted May 9, 2016 bummmpp bring this post back! Newb question, ive never had a FMIC just some massive ETS TMIC, but do you have to retune for a FMIC and a restrictor pill? I have a protune by a shop in Charlotte NC with basic mods, vf46, straightpipe etc etc, but do I need to spend another 450$ for a tune just to put a FMIC on? Link to comment Share on other sites More sharing options...
Mike07LGT Posted May 10, 2016 Share Posted May 10, 2016 Yea to get the most out of it tuning is necessary... most will tell you that a front mount is overkill on a stock turbo though.. the gains wont be much for the $1000 you spend on it 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Tuning Alliance Posted May 12, 2016 Share Posted May 12, 2016 bummmpp bring this post back! Newb question, ive never had a FMIC just some massive ETS TMIC, but do you have to retune for a FMIC and a restrictor pill? I have a protune by a shop in Charlotte NC with basic mods, vf46, straightpipe etc etc, but do I need to spend another 450$ for a tune just to put a FMIC on? We can set you up with a good etune, would be 250 let me know. But yes you should. -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
firerescue9 Posted May 16, 2016 Share Posted May 16, 2016 ^pmed tuning alliance Link to comment Share on other sites More sharing options...
drunkinmonk Posted June 11, 2016 Share Posted June 11, 2016 bummmpp bring this post back! Newb question, ive never had a FMIC just some massive ETS TMIC, but do you have to retune for a FMIC and a restrictor pill? I have a protune by a shop in Charlotte NC with basic mods, vf46, straightpipe etc etc, but do I need to spend another 450$ for a tune just to put a FMIC on? In in charlotte. I'm looking into getting a racer x fmic. I'd love to check your out for fitment and quality. You go to any local meets? Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
G5892 Posted August 3, 2016 Author Share Posted August 3, 2016 Lol woah this thread kept going. Haven't been on here in the longest. FMIC still holding up great after all these years. Link to comment Share on other sites More sharing options...
