iNVAR Posted September 6, 2011 Share Posted September 6, 2011 I'm sure you're right about the bolt. I should be able to go to Home Depot. Thanks much for the response and the awesome product! Link to comment Share on other sites More sharing options...
Leonardo Posted September 21, 2011 Share Posted September 21, 2011 Been waiting forever for one and I didn't even know they were out! Link to comment Share on other sites More sharing options...
bmx045 Posted September 23, 2011 Share Posted September 23, 2011 this *may* interfere with my FMIC pipe, since it passes right infront of the mc Link to comment Share on other sites More sharing options...
SBT Posted September 26, 2011 Author Share Posted September 26, 2011 I don't think there's a lot of movement where parts and pieces in that general area are concerned, vertically or horizontally, as the fuel lines are on the same plane as they were previously with no bend (up or down, in or out) to indicate that anything has changed post-install. WRT passing right in front of the MC, perhaps the proper BFH application at the right spot might get you the clearance you need...or possibly repositioning (tilting) the FMIC cold-side pipe up a bit to clear... - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
bmx045 Posted September 26, 2011 Share Posted September 26, 2011 Just installed one on an '11 wrx last weekend, it fit well- just one issue- the decending brake line is right ontop of the 3 strut tower holes I needed to put the short screws in. Took some tugging and pulling to fit them in. Other than that, when pushing the pedal hard, no movement in the master cyl or brace is seen. I didnt drive it though, owner is picking it up tomorrow. Link to comment Share on other sites More sharing options...
SBT Posted September 26, 2011 Author Share Posted September 26, 2011 Just installed one on an '11 wrx last weekend, it fit well- just one issue- the decending brake line is right ontop of the 3 strut tower holes I needed to put the short screws in. For some reason I can't visualize the descending brake line... - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
bmx045 Posted September 26, 2011 Share Posted September 26, 2011 atleast on the '11 wrx a brake line goes directly over the holes, pita Link to comment Share on other sites More sharing options...
SBT Posted September 26, 2011 Author Share Posted September 26, 2011 Got it - vertically in front of the "short-bolt" holes - yeah, that would be a pain to work around. Don't know why I was visualizing the three strut tower top bolts themselves...doh! - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
PirateDuck Posted October 4, 2011 Share Posted October 4, 2011 The brace took about 30 minutes to install. Instructions here were spot on. I ended up not re-using the bracket for the wiring harness and used a zip tie instead. Pedal feel is much improved. Link to comment Share on other sites More sharing options...
GrimmSpeed Posted October 4, 2011 Share Posted October 4, 2011 Glad this is working for you guys, any videos yet?? Will Link to comment Share on other sites More sharing options...
iNVAR Posted October 5, 2011 Share Posted October 5, 2011 Doh, I've been busy lately, no time to make a before/after video, will try to get one up in the next few weeks with the cup loosened/slackened to show the movement without the brace, and then the cup tightened down to show movement, or rather lack of it. Link to comment Share on other sites More sharing options...
xero287 Posted October 5, 2011 Share Posted October 5, 2011 +1 good idea Link to comment Share on other sites More sharing options...
Claw Posted October 10, 2011 Share Posted October 10, 2011 Here's a before video: [ame=http://www.youtube.com/watch?v=1qpMujB1JHc]05 LGT MBC Movement.avi - YouTube[/ame] Afterwards: [ame=http://www.youtube.com/watch?v=lN7Ddo0xIuI]05 LGT Grimmspeed MBC Brace.AVI - YouTube[/ame] Link to comment Share on other sites More sharing options...
GrimmSpeed Posted October 10, 2011 Share Posted October 10, 2011 Great video! Really can see how much the master cylinder moves. Taras Link to comment Share on other sites More sharing options...
Hollow Idol Eyes Posted October 11, 2011 Share Posted October 11, 2011 I had a chance to install the brace this weekend, and I just want to point out a couple of observations from my experience... The OEM cable brace flattens out pretty easily behind the MCB by simply tightening the bolts. The little added pressure conforms the cable brace to the contours of the MCB. HOWEVER-- re-mounting the OEM cable brace behind the MCB does move the red cup off center, no matter how flat the cable brace. Without the OEM cable brace, the red cup is centered. I initially mounted the MCB without the OEM cable brace but decided to reinstall it-- on a whim of foolish curiosity-- just to see how much of a difference it would make. It's definitely noticeable, and I prefer the red cup centered, so it'll be coming back off soon. On a possibly related note, I'm noticing some occasional brake pedal vibration while at stops after installing the MCB. Otherwise, the product seems great! It provides a very welcome, yet subtle, difference in brake feel. I definitely recommend it. Link to comment Share on other sites More sharing options...
tito_b0y Posted October 16, 2011 Share Posted October 16, 2011 Bump for the '08-09 crowd! 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
mr.hicksta Posted October 16, 2011 Share Posted October 16, 2011 My friend installed the brace on my NON-VDC 08 LGT LIMITED on Saturday, and it fits!!! I'll toss up some pictures when he sends them to me, but he did confirm that the '05-07' version fits my non-VDC 08 . Link to comment Share on other sites More sharing options...
tito_b0y Posted October 16, 2011 Share Posted October 16, 2011 My friend installed the brace on my NON-VDC 08 LGT LIMITED on Saturday, and it fits!!! I'll toss up some pictures when he sends them to me, but he did confirm that the '05-07' version fits my non-VDC 08 . Awesome! But wait, does that mean no group buy for us? 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 16, 2011 Share Posted October 16, 2011 How do you have a non-VDC 08 LGT? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
mr.hicksta Posted October 16, 2011 Share Posted October 16, 2011 How do you have a non-VDC 08 LGT? I have a smaller MBC, and no VDC button on the dimmer cluster. On top of all that I test fitted a 08+ WRX GS MBC brace because GS realized it fits LGTs with VDC, and it did NOT fit mine. My friend is going to email me some pictures of the install later on so I'll post them when I get them. Link to comment Share on other sites More sharing options...
mr.hicksta Posted October 16, 2011 Share Posted October 16, 2011 Awesome! But wait, does that mean no group buy for us? Not sure, and I emailed GS to let them know about the fitment. Hopefully they don't get mad that I let the cat out of the bag, but I know how much excitement there is about this product so I wanted to let everyone know Link to comment Share on other sites More sharing options...
mr.hicksta Posted October 17, 2011 Share Posted October 17, 2011 Okay...here's my non-VCD dimmer cluster: Here's the 05-07 non-VCD MBC Brace installed on my 08 LGT Limited: Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 17, 2011 Share Posted October 17, 2011 Strange. I thought VDC was standard on all 08+ cars. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
mr.hicksta Posted October 17, 2011 Share Posted October 17, 2011 Strange. I thought VDC was standard on all 08+ cars. Same here. Mine comes equipped with BBK Link to comment Share on other sites More sharing options...
tito_b0y Posted October 20, 2011 Share Posted October 20, 2011 Bueller? 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
