GEE-OTTO Posted October 18, 2011 Share Posted October 18, 2011 Try AZP for the bearings and i didn't know you dropped in a used SB so you are right for $100 i guess you can't be too upset. Yes you can use a EJ251 bottom end and EJ25D heads could give you the CR bump you need but be mindful of the deck clearance Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted October 18, 2011 Share Posted October 18, 2011 Sorry to jump in the middle of this but can you tell me the short Version of you end result 2.5 rebuild? Was it hybrid or just built internals with a drilled crank? Also was there a HP goal you were shooting for? Is the BD a 5MT or a Auto? Link to comment Share on other sites More sharing options...
Highflyr Posted October 19, 2011 Author Share Posted October 19, 2011 Try AZP for the bearings and i didn't know you dropped in a used SB so you are right for $100 i guess you can't be too upset. Yes you can use a EJ251 bottom end and EJ25D heads could give you the CR bump you need but be mindful of the deck clearance So I got in touch with AZP. They're asking if I want the bearings with extra clearance for oil. Is worth it to go the extra .001? I figured I'd stick with std size since I'v had the crank polished. Wouldn't that remove .001 off the crank giving me the same result? Sorry to jump in the middle of this but can you tell me the short Version of you end result 2.5 rebuild? Was it hybrid or just built internals with a drilled crank? Also was there a HP goal you were shooting for? Is the BD a 5MT or a Auto? The short? well I bought a used 97 LGT w/ a seized engine. Got an EJ25D from a friend that had a spun rod bearing. Decided to rebuild found it had a cracked blocked so I decided to use the block from the seized engine. Then I found out it wouldn't work since I had phase 1 as well as a phase 2 blocks. SO I couldn't use the crank out the phase 1 in the phase 2 block. So I got an EJ253 SB from rs25.com and used thinner HGs giving me about a 10.4:1 compression with the 25D heads. Ran good and strong but had a knock. Split the 253 and found yet another spun rod bearing. Now I'm starting over again but this time building the bottom end. Going to use stock 251 pistons and crank with ACL bearings. Thinner HG for the same 10.4:1 compression. It's a 5MT. No HP goals just want a good strong running engine. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted October 19, 2011 Share Posted October 19, 2011 Depends if they balanced your crank within that range .001 shouldn't make a large difference unless your spinning at 8500RPM Link to comment Share on other sites More sharing options...
Highflyr Posted October 19, 2011 Author Share Posted October 19, 2011 Crank wasn't balanced they polished it and checked the balance said it was within spec. So I guess I'm good. I think I'm just going to stick with standard size. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted October 19, 2011 Share Posted October 19, 2011 Crank wasn't balanced they polished it and checked the balance said it was within spec. So I guess I'm good. I think I'm just going to stick with standard size. Yes .001 gram wont affect this build or maybe the EJ25D is that sensitive You find a deal on internal yet ? Link to comment Share on other sites More sharing options...
Highflyr Posted October 20, 2011 Author Share Posted October 20, 2011 Yes .001 gram wont affect this build or maybe the EJ25D is that sensitive You find a deal on internal yet ? Yeah I ordered the bearings this morning. I got the ones with extra oil clearance for $100 shipped from maperformance.com. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted October 20, 2011 Share Posted October 20, 2011 Yeah I ordered the bearings this morning. I got the ones with extra oil clearance for $100 shipped from maperformance.com. Good price ! how long are you expecting to be down this time ?? Link to comment Share on other sites More sharing options...
Highflyr Posted October 20, 2011 Author Share Posted October 20, 2011 I'd say no more than the next 2 weeks. Im probably going to re-use pistons and rings so i just have to put everything back together once i get the bearings. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted October 20, 2011 Share Posted October 20, 2011 what do you drive meanwhile? Link to comment Share on other sites More sharing options...
Highflyr Posted October 20, 2011 Author Share Posted October 20, 2011 what do you drive meanwhile? 2002 BMW 330xi, 2008 BMW 335i, and a 2009 Yamaha FZ1 Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted October 20, 2011 Share Posted October 20, 2011 Very sweet! Mines other ride Is a Lex SC coupe. Decided to stay all Japanese... Link to comment Share on other sites More sharing options...
Highflyr Posted October 20, 2011 Author Share Posted October 20, 2011 I've been driving BMWs for a long time this is my first subie. I work for BMW so its hard to pass up deals when they're available. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted October 21, 2011 Share Posted October 21, 2011 I had a silver 735i.... that car was a beast!! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted October 21, 2011 Share Posted October 21, 2011 2002 BMW 330xi, 2008 BMW 335i, and a 2009 Yamaha FZ1 Why are you fooling around with a EJ then nice line up of vehicles you got there Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted October 21, 2011 Share Posted October 21, 2011 Is the 330xi AWD? Link to comment Share on other sites More sharing options...
Highflyr Posted October 21, 2011 Author Share Posted October 21, 2011 Why are you fooling around with a EJ then nice line up of vehicles you got there I've always liked the subies and decided I'd start with old and cheap before I went new and expesive. Is the 330xi AWD? Yes all BMWs with "x" in the model are AWD. The "x" stands for x-drive. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted October 22, 2011 Share Posted October 22, 2011 I also decided to go with old and cheap. Also I honestly don't like the newest designs on the leggy. My old BD is very cool. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted October 22, 2011 Share Posted October 22, 2011 Yeah i stop at the BL/BP but i do like the older designs Link to comment Share on other sites More sharing options...
Highflyr Posted October 25, 2011 Author Share Posted October 25, 2011 Just ordered new piston rings and all the block seals from Subaru. Also got some new timing covers since all mine are cracked. Even spent a good couple hours cleaning the block in our parts washer. I've decided to paint the block a nice bright orange enamel. Also do you think it's worth it to have the crank polished? There doesn't appear to be any damage to the crank from the rod bearing. Some pics... Link to comment Share on other sites More sharing options...
Highflyr Posted October 26, 2011 Author Share Posted October 26, 2011 Got the cylinders hoaned last night and cleaned the block some more. I was talking with on of our older techs and he suggested using tide and hot water to clean the cylinder after hoaning. Apparently the foaming of tide lifts the shavings out of the crosshatches which does a better job than normal soap and water. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted October 26, 2011 Share Posted October 26, 2011 Nice cleanup! I would totally paint the block but Orange enamel ?? Why not Subaru Blue If you crank is not damaged don't machine it unless you have a set balancing weight in mind Link to comment Share on other sites More sharing options...
Highflyr Posted October 26, 2011 Author Share Posted October 26, 2011 I thought about blue but I figured I'd be different. I haven't made up my mind completly so I'm going to go look at some colors here before too long. One thing I was worried about it the nice score line in the one cylinder. I can't feel it with my nail and I tried a little extra hoaning to get rid of it but it won't seem to go away. Should I be worried? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted October 26, 2011 Share Posted October 26, 2011 I noticed that score on the wall if it is flush then no problem but if it is recessed that bore wont hold compression over the long haul. And boring it over can fix it BUT if you take off too much you compromise cylinder wall integrity and risk having one grossly larger cylinder than the other three Link to comment Share on other sites More sharing options...
Highflyr Posted October 26, 2011 Author Share Posted October 26, 2011 Yeah I'm not too worried about it. All 4 cylinders had 150-170psi in the compression test. Link to comment Share on other sites More sharing options...
