Drew888 Posted September 1, 2011 Share Posted September 1, 2011 ^^^ yep... [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
rob-2 Posted April 22, 2013 Share Posted April 22, 2013 Want to confirm this installs just fine with the 5EAT on an 05! Everyone makes this sound like a difficult install. It's 30 minutes of work, and you could probably do it faster if you had to. The trick is really in the prep. Watch the video on their website first. Link to comment Share on other sites More sharing options...
GrimmSpeed Posted April 22, 2013 Share Posted April 22, 2013 Thank you for sharing! Mike Link to comment Share on other sites More sharing options...
darkside Posted April 24, 2013 Share Posted April 24, 2013 How do you know if your car is vdc or non vdc Link to comment Share on other sites More sharing options...
SBT Posted April 24, 2013 Share Posted April 24, 2013 From your VIN. More info here - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SubyDude555 Posted April 29, 2013 Share Posted April 29, 2013 Have it love it! Link to comment Share on other sites More sharing options...
SBT Posted April 30, 2013 Share Posted April 30, 2013 Was driving through a lot of water today (torrential downpour here in the low country) and was just reflecting on how much "flex" this had eliminated from the firewall, and how much better the pedal feel is post-GS BMCB install. It's eliminated a lot of the "take-up" that I previously had to use before the firewall finally stopped moving and the brake piston could finally "work" on the brake lines. Adding water on the brakes to the mix just increased the duration between compression and engagement. Now the brakes are just "there" when you compress and you don't have to wait until the firewall fully flexes (extending the compression stroke). - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
tema Posted May 6, 2013 Share Posted May 6, 2013 Will this fit Outback 2005? Link to comment Share on other sites More sharing options...
oldskoolbiker Posted May 6, 2013 Share Posted May 6, 2013 Will this fit Outback 2005? I'd expect this is the one you want. http://www.grimmspeed.com/catalog/product_info.php?cPath=60_54_164&products_id=236 Link to comment Share on other sites More sharing options...
darkside Posted May 15, 2013 Share Posted May 15, 2013 I got a 07 lgt limited manual, , is it vdc or non vdc version that I need Link to comment Share on other sites More sharing options...
SBT Posted May 15, 2013 Share Posted May 15, 2013 Check your VIN. From your VIN. More info here - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Chameleon Posted May 15, 2013 Share Posted May 15, 2013 Have it love it! Ditto! Link to comment Share on other sites More sharing options...
wpmarky Posted May 14, 2014 Share Posted May 14, 2014 bump from the dead, how are people liking their braces? I just watched this gif on GS's site and said "ohhhh" that's why it's so squishy lol http://grimmspeed.com/product_images/uploaded_images/GSBrace400x300.gif Link to comment Share on other sites More sharing options...
SBT Posted May 14, 2014 Share Posted May 14, 2014 Best thing I've done to upgrade pedal feel during braking. It's definitely a noticeable and immediate return on investment. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
dahoseman Posted May 15, 2014 Share Posted May 15, 2014 Interesting. I hadn't even thought of installing this. I might consider it. When it comes to aftermarket 'performance' parts, I assume a fair amount of placebo effect because I typically find that most enthusiasts can't discern whether a part is or isn't installed. If this has an obvious and real improvement in pedal feel, I would definitely like to install it. Link to comment Share on other sites More sharing options...
Code Posted May 15, 2014 Share Posted May 15, 2014 Interesting. I hadn't even thought of installing this. I might consider it. When it comes to aftermarket 'performance' parts, I assume a fair amount of placebo effect because I typically find that most enthusiasts can't discern whether a part is or isn't installed. If this has an obvious and real improvement in pedal feel, I would definitely like to install it. The benefits of this MCB are for real and can be felt immediately. Bang for buck is off the charts. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
GrimmSpeed Posted May 16, 2014 Share Posted May 16, 2014 Interesting. I hadn't even thought of installing this. I might consider it. When it comes to aftermarket 'performance' parts, I assume a fair amount of placebo effect because I typically find that most enthusiasts can't discern whether a part is or isn't installed. If this has an obvious and real improvement in pedal feel, I would definitely like to install it. The benefits of this MCB are for real and can be felt immediately. Bang for buck is off the charts. Yep, just like Code said, you will notice an improvement immediately. The change in pedal feel is relatively dramatic, not just in high-speed braking, but everywhere. You'll feel the difference before you've even pulled out of your driveway. Call us if you have any questions or need install tips! Matt Beenen Engineering Link to comment Share on other sites More sharing options...
dahoseman Posted May 16, 2014 Share Posted May 16, 2014 Ordered. Looking forward to some improved pedal feel. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 16, 2014 Share Posted May 16, 2014 You'll feel the difference before you've even pulled out of your driveway. Completely true. I noticed the difference as soon as I started the car and depressed the brake pedal before I even got in gear. Keep in mind, however, this is a "braking feel" upgrade, and does nothing for total stopping distance/power. That being said, it will do more for precise braking feel than SS lines ever will. Not even comparable IMO. Link to comment Share on other sites More sharing options...
Nuclear Posted June 3, 2014 Share Posted June 3, 2014 perfect improvement, i have it Link to comment Share on other sites More sharing options...
