Jab83 Posted June 18, 2011 Author Share Posted June 18, 2011 what swap you gonna do? rims??? Link to comment Share on other sites More sharing options...
triplet911 Posted June 18, 2011 Share Posted June 18, 2011 lol engine sorry Link to comment Share on other sites More sharing options...
soloz2 Posted June 19, 2011 Share Posted June 19, 2011 The wheels on my wife's 98 looked similar ever since she got the car. I painted them for her earlier this spring. Here's a couple pics. Mine were worse to begin with and I got tired of cleaning them. Looking back they should have been bead blasted but oh well. Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
Jab83 Posted June 19, 2011 Author Share Posted June 19, 2011 the pic i put up was of my best looking wheel. lol. I had one that looked like that but through out the whole stupid thing. Link to comment Share on other sites More sharing options...
soloz2 Posted June 19, 2011 Share Posted June 19, 2011 Looking forward to how yours turn out. Mine were all bad like the one I showed. I actually dropped the wheels off at my local mechanic and had them remove the tires. To make it easier on me. Steps I used: -cleaned the wheels with a wire brush and sand paper -washed the wheels -about 4 light coats of self-etching primer -about 4 coats of filler primer -5 coats of duplicolor wheel paint -2 coats of clear coat -let them sit for a week before mounting tires... Should have waited at least two weeks IMO. Good luck! Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
Zues Marine Posted June 19, 2011 Share Posted June 19, 2011 so when are you going to paint these rims? this thread's been hanging around pointlessly for a while meow Link to comment Share on other sites More sharing options...
Jab83 Posted June 19, 2011 Author Share Posted June 19, 2011 Crazy with work. I also don't have extra rims right now... so can't really paint Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 19, 2011 I Donated Share Posted June 19, 2011 Here is my process - dismount tires - light sand with 500+ grit sandpaper - one light coat of primer - 30 minutes after primer first light coat of paint - 15 minutes between coats, usually about 4 coats total - after last coat - wait 10 minutes then do a light coat of clearcoat...followed by 3 more 10 minutes apart - mount tires a day later its worked excellent for me so far. My end result is a smooth and VERY glossy wheel that looks like it had been painted by a body shop -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Jab83 Posted June 20, 2011 Author Share Posted June 20, 2011 You think I could through the spare in there fir the day have to wait Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
triplet911 Posted June 20, 2011 Share Posted June 20, 2011 thats a good plan brokindark Link to comment Share on other sites More sharing options...
Jab83 Posted June 20, 2011 Author Share Posted June 20, 2011 Yeah its good I gonna do it that way but don't know if I can with out some other rimes. Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
triplet911 Posted June 20, 2011 Share Posted June 20, 2011 im gonna sand down my headlight today Link to comment Share on other sites More sharing options...
Jab83 Posted June 20, 2011 Author Share Posted June 20, 2011 I did that Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
Jab83 Posted June 21, 2011 Author Share Posted June 21, 2011 Rain ruined. My plans of polishing my tires. Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
Frogg Posted June 22, 2011 Share Posted June 22, 2011 Here is my process - dismount tires - light sand with 500+ grit sandpaper - one light coat of primer - 30 minutes after primer first light coat of paint - 15 minutes between coats, usually about 4 coats total - after last coat - wait 10 minutes then do a light coat of clearcoat...followed by 3 more 10 minutes apart - mount tires a day later its worked excellent for me so far. My end result is a smooth and VERY glossy wheel that looks like it had been painted by a body shop this is basically my process too, except i use a thicker coat of primer once, or two real light coats Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 23, 2011 I Donated Share Posted June 23, 2011 this is basically my process too, except i use a thicker coat of primer once, or two real light coats I've had back luck with thick coats of primer. The end result doesn't seem to be as smooth if I use a thick coat of primer -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Jab83 Posted June 23, 2011 Author Share Posted June 23, 2011 I would like to do about three coats if primer. And do the first to right after each other but on the third sand it down before I start again. Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
Jab83 Posted June 26, 2011 Author Share Posted June 26, 2011 Polished the wheels to fill in some of the bad parts I couldn't get rid of it worked out well. Might try to paint tomorrow after work. Should I get the primer that is made for aluminum? Or should I save my money and get normal stuff Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
Zues Marine Posted June 26, 2011 Share Posted June 26, 2011 self etching primer Link to comment Share on other sites More sharing options...
Jab83 Posted June 26, 2011 Author Share Posted June 26, 2011 Oh and can I take the weight thing off?? With out taking the tire off and keep it off?? No idea Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
Frogg Posted June 27, 2011 Share Posted June 27, 2011 sure, but u'll need to get re-balanced... Link to comment Share on other sites More sharing options...
Jab83 Posted June 27, 2011 Author Share Posted June 27, 2011 Oh ok. Needed that anyway Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
Lookatmyrust Posted June 28, 2011 Share Posted June 28, 2011 i wouldn;t drive like that. wears out parts fast Link to comment Share on other sites More sharing options...
Jab83 Posted June 28, 2011 Author Share Posted June 28, 2011 I don't have the money get em balanced right now. But I don't have time to wait to start working on em Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
Jab83 Posted July 3, 2011 Author Share Posted July 3, 2011 What they look like right now gonna paint as soon as I can. Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
