Theride Posted May 26, 2011 Share Posted May 26, 2011 I remember years ago I could go to pepboys and get them resurface, but apparently they dont do it anymore. Can someone recommend a shop that does it? I am in the queens/ Long Island area. Thanks Link to comment Share on other sites More sharing options...
Gire Posted May 26, 2011 Share Posted May 26, 2011 Your dealership will definitely do it. But that would be a more expensive route to take... but you know it would be done right. Link to comment Share on other sites More sharing options...
Theride Posted May 26, 2011 Author Share Posted May 26, 2011 how much do you think they will charge per rotor? Link to comment Share on other sites More sharing options...
Gire Posted May 26, 2011 Share Posted May 26, 2011 I'm Canadian so we pay more for everything up here. My thoughts on pricing aren't accurate for you US guys. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 27, 2011 Share Posted May 27, 2011 NAPA may do it, or ask the guy's at theauto parts stores. I just drop them off at my buddies shop, http://www.eastwoodsautomachine.com/ They did my slotted rotors a couple weeks back, $30.00 for both fronts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ruggerheist Posted May 28, 2011 Share Posted May 28, 2011 i didnt think slotted rotors could be resurfaced... sweet! Link to comment Share on other sites More sharing options...
Scooby Fan Posted May 28, 2011 Share Posted May 28, 2011 I called my local dealer about this a few weeks ago......just a little more than double what a local (Reputable) brake shop charges.....any decent brake and alignment shop can do it for you......Stay away from your dealer on this kinda stuff Link to comment Share on other sites More sharing options...
frank_ster Posted May 29, 2011 Share Posted May 29, 2011 just put new ones .. you can surface drilled and slotted rotors but depending on how much they need to take off. the lgt rotors do have a lot of meat i surfaced mine my self but they weren't near as good as a new set Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ruggerheist Posted May 30, 2011 Share Posted May 30, 2011 i cant just put new ones on, rotora discontinued my model BBK so if i want to replace the rotors i need to send the whole front system in +$1300 to get a new front set. i can still replace the rears Link to comment Share on other sites More sharing options...
BIGAL8899 Posted September 20, 2011 Share Posted September 20, 2011 i cant just put new ones on, rotora discontinued my model BBK so if i want to replace the rotors i need to send the whole front system in +$1300 to get a new front set. i can still replace the rears the same thing is happening to me, i have 4 piston in the front and 2 piston in the back. Is there any other option? Link to comment Share on other sites More sharing options...
ruggerheist Posted September 20, 2011 Share Posted September 20, 2011 horsepower freaks think the new 2 piece rotors will fit old calipers. if it doesnt work they should return. I havent done it yet so i dont know for sure. Link to comment Share on other sites More sharing options...
