MasAyinde Posted May 26, 2011 Share Posted May 26, 2011 I was looking at iPod integration and was comparing the Leptronix, jazzy and this thingy here. Has anyone used this? is anyone able to comment on how well it would work? ideally I would like something that uses the same cable to charge and play my iPod at the same time. Link to comment Share on other sites More sharing options...
Hanger Posted May 26, 2011 Share Posted May 26, 2011 if you want to play your ipod and able to charge on the same wire, then the Subaru Ipod integration kit is your only choice You'll also need a 07+ HU to go along with the kit ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
RJS5689 Posted May 26, 2011 Share Posted May 26, 2011 I have the OEM Subaru iPod integration kit in my car. It charges the iPod and allows you to control it from the headunit/steering wheel controls. I'm doing the JDM dash kit in my car this weekend, so I'll have my integration kit for sale. As Hanger said, you will need a 2007+ headunit for it to work. The reason for this is the kit uses the satellite input on the headunit, which is only present on 2007+ vehicles. Link to comment Share on other sites More sharing options...
Catalyst Posted May 26, 2011 Share Posted May 26, 2011 I thought the Jazzy played and charged from the same ipod wire? "This is an adventure." Link to comment Share on other sites More sharing options...
Gire Posted May 26, 2011 Share Posted May 26, 2011 If you want a simple solution that can be installed in under an hour to any factory car deck, look no further than Peripheral Electronics. Search this forum for the word Peripheral and you will see other posts come up showing links to the packages sold. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 26, 2011 I Donated Share Posted May 26, 2011 What is "this thingy here"? There is no link. I personally like the iSimple Gateway. But once again, you will need an 07+ headunit (P-204UH or P-206UH). The P-201UH that comes stock in 05/06 sucks in terms of expandability. The P-204UH will probably run you around $200-250, and the iSimple is $130 (an extra $60 if you want Bluetooth), but sound quality is better than Leptronix, you can control the iPod and view songs through the stereo, and it's still cheaper than the JDM double-DIN. Link to comment Share on other sites More sharing options...
ericutexas Posted June 1, 2011 Share Posted June 1, 2011 I have the Jazzy kit and this: http://www.dealextreme.com/p/3-in-1-usb-3-5mm-aux-audio-data-charger-cable-for-ipod-iphone-2g-3g-3gs-black-1-2m-34654 It's worked great for the past year that I've had it - I just have a 3.5mm extension cable that runs from the HU to the armrest cubby. You'd also need a USB charger for the 12V port inside the cubby, connect everything in there, and then run the single power/audio cable through the little cutout in the edge of the armrest cubby. I just throw my iPhone in the cupholder when I'm using it. Link to comment Share on other sites More sharing options...
