bama16 Posted April 3, 2011 Share Posted April 3, 2011 i have an 08 gt that was hit in the side at low speed. thanks here's a pic... http://i33.photobucket.com/albums/d74/bama16/IMAG0003.jpg?t=1301877455 Link to comment Share on other sites More sharing options...
PearlBlueGT Posted April 4, 2011 Share Posted April 4, 2011 Looks fixable and I doubt its totalled. I've seen cars get fixed with more damage to them. That's why body shops have frame racks. it really depends on how many hours to fix it vs ACV actual cash value of the car Link to comment Share on other sites More sharing options...
IDRVSLO Posted April 4, 2011 Share Posted April 4, 2011 Worked at a body shop for 5 years, fixable...yes. They do replace those pillars. I am not to familiar with the Legacy but there is a seam on most cars where it is welded in. You are good, should be a 2-3 week repair barring any setbacks....possibly quicker. Scott G [ Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 4, 2011 Share Posted April 4, 2011 Ouch! Ive had two cars that saw action on the frame jig they never were quite right again. Link to comment Share on other sites More sharing options...
longislander1 Posted April 4, 2011 Share Posted April 4, 2011 There's an article about fire departments being unable to cut through the B-pillar because it has so many layers of steel in it. I would try to find a body shop that has some expertise with Subarus. Otherwise, your car may never have the same structural integrity. On other brands with similar damage, I've seen insurers total the cars. Link to comment Share on other sites More sharing options...
TooBigToFit Posted April 4, 2011 Share Posted April 4, 2011 There's an article about fire departments being unable to cut through the B-pillar because it has so many layers of steel in it. I would try to find a body shop that has some expertise with Subarus. Otherwise, your car may never have the same structural integrity. On other brands with similar damage, I've seen insurers total the cars. Oh it's possible to cut through it. I was holding a section of the B pillar (from a 3rd? gen Outback) just yesterday at a vehicle extrication class, and for its size, it was heavy! Layers of steel and rebar. There wasn't too much dead space inside. I was told they were *just* barely able to cut through it. Anyways, the article you speak of is available from Subaru, at the following URL: http://www.drive.subaru.com/Sum06_WhatsInside.htm It gives insight as to how the structure is designed and put together, with specifics given to the ring structure. That said, I would personally echo what long islander said. If you can't verify that the frame will be as strong after the fix as before the accident, I would instead part out or sell your car and start anew. To do otherwise would be like sky diving with a questionably functioning parachute. Link to comment Share on other sites More sharing options...
ehsnils Posted April 4, 2011 Share Posted April 4, 2011 Since all damage seems to be on the pillar and nothing on the bottom plate or at the roof it's probably possible to fix - given that you find the right shop that's willing to replace the pillar. I would recommend that you try to replace it. And you may even find a donor car at a junkyard from which you can cut out a donor pillar. Make sure you have them cut it out with some excess material at both ends. Even better if you can get doors too from a donor car. Just make sure that there aren't any seatbelt tensioner or stuff like that in the pillar. Trying to pull the pillar right again is probably futile. Link to comment Share on other sites More sharing options...
PoisonousBeef Posted April 5, 2011 Share Posted April 5, 2011 Hopefully they will total it, you will get a check and you can move on with your life. Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 5, 2011 Share Posted April 5, 2011 I'd hope for a total if I ever had damage similar to that. Speaking of totaling, is there any compensation due to rarity of vehicle? Finding an equivalent replacement for some of the more rare Subarus (like an 05 GT Wagon with a 5MT) is almost an impossibility. Do insurance companies take replacement difficulty into account, or is it simply a cash transaction? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
IDRVSLO Posted April 6, 2011 Share Posted April 6, 2011 Straight cash transaction, they see dollars not difficulty. BTW OP.....can you take a picture of the inside looking between the pillar and the seat. To those that say these can not be cut....I have replaced them, it can be done. Good luck with the fix, I wish you the best! Scott G [ Link to comment Share on other sites More sharing options...
planelazy Posted April 6, 2011 Share Posted April 6, 2011 If it is totaled.. .. dibs on the rear tail lights and reflector inserts Link to comment Share on other sites More sharing options...
Montana Posted April 6, 2011 Share Posted April 6, 2011 We had a 1988 Subie wagon that was rolled and declared totalled. The roof pillars were bent like that at the passenger door, and the top rear of the roof was dented. The glass was all intact. The adjuster pointed out to me, under the hood at various points, the sacrificial body points that showed paint flaking from deformation from the impact. He explained how the body is supposed to "banana" to let the engine run under the cabin area instead of into the driver's lap. About a year later we got a call from someone across ths State who had bought the car. They were having some transmission issues. They didn't know the car had been rolled and totalled. Link to comment Share on other sites More sharing options...
.blackgt. Posted April 11, 2011 Share Posted April 11, 2011 If you do end up totaling (somehow), dibs on the hood if its in nice shape, and passenger front fender. Link to comment Share on other sites More sharing options...
alaskajoel Posted April 12, 2011 Share Posted April 12, 2011 If it is totaled.. .. dibs on the rear tail lights and reflector inserts If you do end up totaling (somehow), dibs on the hood if its in nice shape, and passenger front fender. :lol: Link to comment Share on other sites More sharing options...
IDRVSLO Posted April 25, 2011 Share Posted April 25, 2011 Supplemental claims can still total the car. [ Link to comment Share on other sites More sharing options...
