PearlBlueGT Posted April 30, 2011 Author Share Posted April 30, 2011 Heads are at the head shop getting new valves put in. Also cam gears are getting replaced as old ones cracked. Subarus are so cheap, they are no better than domestic cars Link to comment Share on other sites More sharing options...
PearlBlueGT Posted June 6, 2011 Author Share Posted June 6, 2011 Got car back last night. Runs great. New timing belt Rebuilt heads All new gaskets, spark plugs, oil/filter HOWEVER car STILL has CEL with P0021 and P0011 codes!!!! I'm just so pissed now, spent so much time and money on it and still has CEL. Btw I installed new OCV valves from Fredbeans Link to comment Share on other sites More sharing options...
ehsnils Posted June 6, 2011 Share Posted June 6, 2011 Stupid question: Did you clear the codes? And then - did you check any filter related to the oil feed for the camshaft timing? There shall be banjo bolt filters for them too, and if you get the problem the turbo banjo filter needs check too. Another step is to check the oil pressure - maybe the oil pump is weak or going. Or there is an oil leak in a strange location. Even a bad oil pickup tube. Or a blown bearing somewhere. Not all stuff that happens in an engine gives a definitive noise right away. I can think of a massive amount of reasons to why you get the codes, and installing an oil pressure gauge would at least help to reveal if you have a general oil pressure problem. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted June 6, 2011 Author Share Posted June 6, 2011 All of the banjo bolts were replaced also, forgot to add that to the list of parts replaced. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted June 10, 2011 Author Share Posted June 10, 2011 Is it possible to have P0021 and P0011 due to lower octane fuel? Link to comment Share on other sites More sharing options...
1454 Posted June 10, 2011 Share Posted June 10, 2011 No, Those are cam codes. Who did the timing job? I would make sure the cams are in the correct positions, as that is one thing that would cause both codes. I've never seen both sensors go out at once. That's where I would start. Link to comment Share on other sites More sharing options...
1454 Posted June 10, 2011 Share Posted June 10, 2011 Also, you can try this. http://www.iwsti.com/forums/2-5-liter-litre-factory-motor/150610-p0011-p0021-fixes-people-have-run-across.html Link to comment Share on other sites More sharing options...
PearlBlueGT Posted June 11, 2011 Author Share Posted June 11, 2011 also have P0459 code Link to comment Share on other sites More sharing options...
PearlBlueGT Posted June 11, 2011 Author Share Posted June 11, 2011 No, Those are cam codes. Who did the timing job? I would make sure the cams are in the correct positions, as that is one thing that would cause both codes. I've never seen both sensors go out at once. That's where I would start. Mechanic that I know did the job. He has shop at home and does side jobs after work. Link to comment Share on other sites More sharing options...
ehsnils Posted June 11, 2011 Share Posted June 11, 2011 also have P0459 code That's the purge valve for the gas tank evaporation. Just for the sake of it - check your battery voltage, since if that's too low you get all kinds of strange things happening. A bad battery is the root of all evil. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted June 11, 2011 Author Share Posted June 11, 2011 That's the purge valve for the gas tank evaporation. Just for the sake of it - check your battery voltage, since if that's too low you get all kinds of strange things happening. A bad battery is the root of all evil. What the reading should be at? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 11, 2011 I Donated Share Posted June 11, 2011 What the reading should be at? 11.5-12.5ish with car off, 13.3-14.3ish with car on. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted June 11, 2011 Author Share Posted June 11, 2011 Battery has 12.6V disconnected so I don't think that's battery Link to comment Share on other sites More sharing options...
PearlBlueGT Posted June 11, 2011 Author Share Posted June 11, 2011 Old heads were so worn that you could take cams and they would move on the head, I bought heads from member on this site, had them checked by head machine shop, milled, new gaskets all way around. Car runs great now and everything works as it should except for damn CEL. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted June 20, 2011 Author Share Posted June 20, 2011 Update. Engine developed rod knock and died on me yesterday Link to comment Share on other sites More sharing options...
Kingfisher Posted June 20, 2011 Share Posted June 20, 2011 I knew it was the gas cap! Sorry to hear about your misfortune man. Hopefully you can get it sorted out without breaking the bank. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 20, 2011 I Donated Share Posted June 20, 2011 This sounds like a sucky situation... but of course, it's one of the reasons you need to check any red flags on the car (like a CEL) before you buy. If my car had had all those codes when it was sitting on the dealer lot, I would have run away as fast as I could. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted August 5, 2011 Author Share Posted August 5, 2011 I've found short block for $1500, I'm considering pulling engine out and swapping everything onto it. How hard would this be? Link to comment Share on other sites More sharing options...
bmx045 Posted August 5, 2011 Share Posted August 5, 2011 piece of cake Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted August 5, 2011 I Donated Share Posted August 5, 2011 Longblock is easier. Link to comment Share on other sites More sharing options...
bmx045 Posted August 5, 2011 Share Posted August 5, 2011 Longblock is easier. this Link to comment Share on other sites More sharing options...
PearlBlueGT Posted August 5, 2011 Author Share Posted August 5, 2011 I already bought heads and they were checked and are in good shape Link to comment Share on other sites More sharing options...
ehsnils Posted August 5, 2011 Share Posted August 5, 2011 OK, then it's "simple", the hard thing is to do it in the right order. But if you are taking apart the old engine then it's at least easier i you make notes or have a good memory. Link to comment Share on other sites More sharing options...
burnout8488 Posted August 6, 2011 Share Posted August 6, 2011 Subarus are so cheap, they are no better than domestic cars Come on. Your mechanic himself said the "idiot" previous owner had the timing belt on wrong, obviously your car was beat on by the previous owner if the engine just started knocking as well. It's not Subaru's fault at all. Link to comment Share on other sites More sharing options...
ehsnils Posted August 6, 2011 Share Posted August 6, 2011 Come on. Your mechanic himself said the "idiot" previous owner had the timing belt on wrong, obviously your car was beat on by the previous owner if the engine just started knocking as well. It's not Subaru's fault at all. Only fault by Subaru there was that they built an engine with a timing belt. Link to comment Share on other sites More sharing options...
