babybaluga32 Posted January 30, 2011 Share Posted January 30, 2011 Would a like year legacy 5mt be strong enough? Clutch aside Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted January 30, 2011 Author Share Posted January 30, 2011 so this is my idead so far: Wrx td04 turbo Wrx fuel pump Wrx injectors Ej22t heads Ej22t intake manifold Will a wrx header work with the ej22t heads?? How does all that sound so far ^^ Link to comment Share on other sites More sharing options...
babybaluga32 Posted January 30, 2011 Share Posted January 30, 2011 You will need a new intake manifold. Our's are like 2 inch's wider. It can't be from an ej22t, or any phase 1. The header will most likely be taking the route of the turbo crossmember, so no probably not, and wrx's are dohc .. Well at least some Link to comment Share on other sites More sharing options...
Baddog Posted January 30, 2011 Share Posted January 30, 2011 I read somewhere a Subaru 5 speed is well....a Subaru 5 speed. Regardless of it being a WRX or Legacy 5 speed. Link to comment Share on other sites More sharing options...
babybaluga32 Posted January 30, 2011 Share Posted January 30, 2011 WWWHAT!!!! Realllllly? I have not heard such a thing!. That would be awesome.. Ive heard the the SVX(?)'s trannies would die if you pushed 240 hp ... Would legacys and wrx;s be the same and then It jumps in beefyness with the sti? Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted February 2, 2011 Author Share Posted February 2, 2011 Okay so I'm guess I'm still confused, can I use ej22t heads on my block? If so what intake manifold will I run? Also what about an exhaust manifold?? Link to comment Share on other sites More sharing options...
babybaluga32 Posted February 2, 2011 Share Posted February 2, 2011 The ej22t heads are not as wide as as your current heads, which means your intake manifold will not work on the ej22t heads. Your intake manifold is a phase 2 manifold, so it has more sensor ports, and is wider. Link to comment Share on other sites More sharing options...
babybaluga32 Posted February 2, 2011 Share Posted February 2, 2011 Whats an exhaust manifold? Headers? They would have to be for a non turboed car, unless you get a turbo crossmember. Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted February 2, 2011 Author Share Posted February 2, 2011 So how would dual port ej22 Heads handle boost? And can I use the intake manifold from that motor? What about the header?? Link to comment Share on other sites More sharing options...
babybaluga32 Posted February 2, 2011 Share Posted February 2, 2011 the only dohc ej22 heads ive seen were phase1 and you cant use them either.. or i would be, cause I have them! I have absolutely no idea if there ever was a phase 2 ej22 head. Look on your intake mani, on the throttle body there with be a sensor. On the phase ones there isnt. Ill take a pic tomorrow Link to comment Share on other sites More sharing options...
babybaluga32 Posted February 2, 2011 Share Posted February 2, 2011 thta ws dohc! Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted February 2, 2011 Author Share Posted February 2, 2011 Oh okay, so I'm pretty much stuck using my heads and manifolds?? Link to comment Share on other sites More sharing options...
babybaluga32 Posted February 2, 2011 Share Posted February 2, 2011 ej25d heads and a stock header for it, or unequal header... non turbo of course. Besides that, im not sure what will work. Link to comment Share on other sites More sharing options...
babybaluga32 Posted February 2, 2011 Share Posted February 2, 2011 they're dohc phase 2 Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted February 4, 2011 Author Share Posted February 4, 2011 Will those heads swap over with no problem?? And will I need to use the intake manifold from the ej25d?? Link to comment Share on other sites More sharing options...
babybaluga32 Posted February 5, 2011 Share Posted February 5, 2011 I've been told they will, but I honestly haven't put them on, so I'm not sure. And I think you can use your manifold because phase 2's are interchangeable... Not sure though!!!!!! Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted February 5, 2011 Author Share Posted February 5, 2011 uhg, im confused, i think i will just run my heads and have a custom header and dp made.. lol Link to comment Share on other sites More sharing options...
babybaluga32 Posted February 5, 2011 Share Posted February 5, 2011 That would be a million times easier, and its what I did too Link to comment Share on other sites More sharing options...
babybaluga32 Posted February 5, 2011 Share Posted February 5, 2011 Id you get a matching size catback exhaust you can just buy a dp from ebay Link to comment Share on other sites More sharing options...
Zues Marine Posted February 6, 2011 Share Posted February 6, 2011 Would a like year legacy 5mt be strong enough? Clutch aside yeah like jason said, all subaru motors and trannys will bolt up to all other subaru motors and trannys..even an sti 6 speed and the legacsti 7 speed Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted February 6, 2011 Author Share Posted February 6, 2011 ohhh i want a 6 speed tranny = DDDDD Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted February 11, 2011 Author Share Posted February 11, 2011 Is there different types of injectors that come factory on wrx's?? If so which ones do i need?? Link to comment Share on other sites More sharing options...
joepaco Posted February 11, 2011 Share Posted February 11, 2011 my 1998 is single port head and is turbo you need to make a custom exhaust for it thats what i did im running only 6psi right now on 10:1 comp i have a 2.5L block with 2.2L heads Link to comment Share on other sites More sharing options...
babybaluga32 Posted February 11, 2011 Share Posted February 11, 2011 Topfed lightblue Wrx injectors 02-05 (maybe 07) Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted February 11, 2011 Author Share Posted February 11, 2011 schweet. So those fit right into the stock fuel rail? Or do i need an aftermarket one? Link to comment Share on other sites More sharing options...
