babybaluga32 Posted January 24, 2011 Share Posted January 24, 2011 You don't need to have a custom header made if your keeping your sohc header... And custom up pipe, you'll need to buy the flanges, Then take it to a shop and have them bend it.. You might be able to find one online, but I'm sure it would be pricey! I don't think I would ever pay anything more than 50$, it would be 100+ probably. It's a manual, I'm just a really fast shifter!! Actually its not it's an auto and it blows Link to comment Share on other sites More sharing options...
babybaluga32 Posted January 24, 2011 Share Posted January 24, 2011 The placement and bends of the up pipe are really important. I don't have any brackets for my turbo, its just held up by the uppipe. What I did before I got bigger exhaust was just take the cat off and made a 1 7/8ths downpipe flange and welded flexible exhaust tubing on... If that makes sense Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted January 24, 2011 Author Share Posted January 24, 2011 Um have any pictures of what u were trying to say?? Lol Link to comment Share on other sites More sharing options...
subydrift Posted January 26, 2011 Share Posted January 26, 2011 Here is what you may be looking for. It is a aftermarket turbo parts list done by Subachad with Unique Motorsports. He has all of the parts he used with part numbers and a manufacturer. You can use a stock WRX turbo with the up and down pipe that he has in his list (check for the links) from Unique Motorsports. They will bolt up to your header. http://www.uniquemotorsports.com/subachad/mods/turbo_parts.htm Link to comment Share on other sites More sharing options...
Zues Marine Posted January 26, 2011 Share Posted January 26, 2011 you can get stock wrx turbos for was less than $300 tho... more like $100 Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted January 26, 2011 Author Share Posted January 26, 2011 sweet thanks for the link man. Does anyone know were i could come up with a flange for a factory subaru turbo so i can have my own uppipe made and downpipe?? Link to comment Share on other sites More sharing options...
subydrift Posted January 26, 2011 Share Posted January 26, 2011 If you are going to for sure be going with a factory WRX turbo then you can just go get the exhaust gaskets for the up-pipe to turbo and turbo to down-pipe and use those as your templates and cut them out of some 3/8" thick steel. Then use the gaskets when you install your turbo. That's what I did with my old turbo Impreza L project. Worked great. Or just try and find some Subachad pipes and then all the guess work and fab is done for you and you know the turbo will fit with all clearances. Link to comment Share on other sites More sharing options...
babybaluga32 Posted January 26, 2011 Share Posted January 26, 2011 ^^^ I made mine like that Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted January 27, 2011 Author Share Posted January 27, 2011 i found a stock td04 for $100 shipped with no shaft play. Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted January 27, 2011 Author Share Posted January 27, 2011 Also i found this turbo at a local picknpull it has a very tiny amount of shaft play and i was offered the turbo, uppipe, and exhaust manifold for $50. Is this a good turbo/deal?? And also will it be able to run 8 psi?? Here are some pictures, sorry there cell pics. http://i68.photobucket.com/albums/i23/snyder729/photo.jpg http://i68.photobucket.com/albums/i23/snyder729/photo4.jpg http://i68.photobucket.com/albums/i23/snyder729/photo2.jpg And this is the motor its on: http://i68.photobucket.com/albums/i23/snyder729/photo3.jpg Is that motor a single port or a dual port??? ^^^^^ Link to comment Share on other sites More sharing options...
Baddog Posted January 27, 2011 Share Posted January 27, 2011 Did the EA82 motors ever come turbo'd? I think they did was that off a GL? Link to comment Share on other sites More sharing options...
babybaluga32 Posted January 27, 2011 Share Posted January 27, 2011 The turbo should have a serial number on it and start with vf something something. The up pipe will not work but you could do what I did with it and saw off both ends! Whhhaabam! 2 flanges right there. And I would think about buying an external waste gate, it looks pretty old and probably rusty.. Link to comment Share on other sites More sharing options...
babybaluga32 Posted January 27, 2011 Share Posted January 27, 2011 The downpipe screws look stripped and if there is only 4 bolts, you will have to make a custom flange for it.. But you would anyways for your exhaust size. A gasket mig be really hard to find. Google that car and find out what it is Link to comment Share on other sites More sharing options...
babybaluga32 Posted January 27, 2011 Share Posted January 27, 2011 As for running 8 psi.. Probably, mine could do 13 maybe more. Link to comment Share on other sites More sharing options...
subikid90 Posted January 27, 2011 Share Posted January 27, 2011 Did the EA82 motors ever come turbo'd? I think they did was that off a GL? Yes EA82 did come turbo'd, my grandpa had one back in the day -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted January 27, 2011 Author Share Posted January 27, 2011 yeah its off a 90 gl wagon i believe. Link to comment Share on other sites More sharing options...
KuNomn Posted January 27, 2011 Share Posted January 27, 2011 ugh, I wish my GL was turbo'd. That would have been so much more fun Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted January 27, 2011 Author Share Posted January 27, 2011 lol arnt all cars better turboed then n/a =p Link to comment Share on other sites More sharing options...
babybaluga32 Posted January 29, 2011 Share Posted January 29, 2011 If you ever have any random yass questions and need a swift response, email me. Hypothetically this guy raced a yonda yivic, all I know is it have shafty yass exhaust- it sounded good till like 3000, then It made me want to puke. It looked nice though, with fog lights?.....! There was massive ownage. Hypothetical ownage, that is. From 3rd ... from 2nd, and of course 1st. I <3 my new injectors soooooo much.. I got all 4 spinning in 2nd. ohhh and btw the chiefs kicked ass tonight!!!!!!!!!!! Best hockey game ive ever seen in person! Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted January 29, 2011 Author Share Posted January 29, 2011 when u gunna manual swap fool? ^^ Also pm me your email Link to comment Share on other sites More sharing options...
babybaluga32 Posted January 29, 2011 Share Posted January 29, 2011 When i come up with an extra 1500$! Maybe a couple years! Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted January 29, 2011 Author Share Posted January 29, 2011 just go steal a manual legacy and swap the parts real fast like and return it =D They will never know lmao. Link to comment Share on other sites More sharing options...
babybaluga32 Posted January 30, 2011 Share Posted January 30, 2011 I think if I was to go that far, i'd just steal an sti Link to comment Share on other sites More sharing options...
Zues Marine Posted January 30, 2011 Share Posted January 30, 2011 dude, you can get all the stuff to 5mt swap for roughly $600 around here Link to comment Share on other sites More sharing options...
babybaluga32 Posted January 30, 2011 Share Posted January 30, 2011 Wrx? Link to comment Share on other sites More sharing options...
